Question about GE JGBP28 Gas Kitchen Range
GE gas range igniter continues to spark, won't shut off.
GE gas range - Profile, igniter contiues to spark and won't shut off. I unpluged it and left it until I get some help.
  • Anonymous Mar 04, 2009
    Water along left side of range off countertop got into connector between front switches on knobs and igniter module just inside the stove. Disconnected there and dried with hair dryer. Problem solved. The above fixya lead me to the problem. Thanks, great site
  • 1,543 Answers
Often times, just leaving the range unplugged for a time will solve the problem, which is most often caused by water or a cleaning agent getting into an igniter switch behind a burner knob. After the switch drys out it usually starts working again. In the mean time, you can still use the burners by lighting them manually with one of those long lighters, but you will not be able to use the oven or broiler without electricity. If the range continues to spark after being left unplugged for more than a day or two, you will have to determine which switch behind the burner knobs is causing the problem. Please don't bother rating, as anything but a Fix-Ya will lower my score. Thanks.
Posted on Feb 18, 2009
Electric spark starter on one of the burner runs continuously
check the spark head on that particular burner first for dirt,they all need to be clean to recognize the flame after ignition and sense the flame to shut off the sparker module after ignition,and if not you will need to replace the spark module that fires the sparkers itself,but try cleaning sparkers and underneath where the wires connect to the sparkers first for contamination,its cheaper than starting to replace parts
Dec 31, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
My GE profile gas range keeps clicking all the time, this happens right after we have cleaned the gas range. And usually it goes away after a few hours. But this time around it refuses to go and it is very...
You are getting water into the range when cleaning causing the igniter switch to short out. The reason why it goes away after a few hours is because the water finally dries up. When cleaning the range refrain from using so much water. You will need to leave the range unplugged until the water dries up again.
Sep 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove Ignitor makes tik tik sound and the sparks continuously
may be a loose wire on the spark ignitor ceramic or if you run via main electic it may be your spark generator
May 14, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
The ignition spark for my gas stove won't stop flicking....
Jan 16, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge gas kitchen range 2 igniters work and 2 don't
Lift top upward & look under, you'll probably see small wire(s) running to ingnitors, see if perhaps wire fell off side not working.
Dec 10, 2008 | GE Profile Spectra JGBP85 Gas Kitchen...
Dcs range igniter
Our GE range Profile, the igniter continues to spark with it on off. All four burners igniter contiues to spark. We have it unpluged at the moment, but it seems like it needs to reset or something. Will it stop when we plug it back in? I am not at home is why I ask this question, or I would plug it is an find out. Any help?
Aug 18, 2008 | Kitchen Ranges
GE Profile - One of the igniters continually clicks...
Hi Mike,
The Dial/Swiitch Has A Fault, Or The Igniter Electrode is Touching, or too Close To The Contact Area.
Try Turning the faulty switch, left or right Gently.
Could be grease/dust arcing the Contact.
Broken Or uninsulated Wire Under The Ignitor, arcing against metal surface.
Mike @ Compurepair.
Feb 28, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
GE Profile Gas Range Igniters working but gas takes a while to start flowing
HI thanks for your question. the igniter is the cause for this problem. the heat from the glow bar is just not hot enough to ignite the gas. i would replace the igniter. thanks
Nov 26, 2007 | GE Profile JGSP48 Gas Kitchen Range
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE JGBP28 Gas Kitchen Range Logo
1,736 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
