Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Kenmore side by side icemaker
Won,t  distribute ice through the door crushed or whole i can hear the motor but nothing comes out! worked fine and then one day nothing
  • 1 more comment
  • muchtone2000 Feb 18, 2009
    Thanks. I did push the switch to see if it was moving at all and it moved not even a inch and then stopped
    non-IDI
    no it will spin unless i hold it then it doesnt spin the coupler just the motor
  • 3 Answers
Your product is an IDI (In Door Ice the bucket is in the door) or a Non-IDI? By the way, you mention the Ice maker. The thing is that if the ice maker is not runnning then you don't have ice to dispense and obviously the fact that the motor is working or not is irrelevant. So that's why I suppose that the problem is not the ice maker but the trajectory of the cubes from the bucket to outside of the door.
In the Non-IDI sometimes it happens that the safes in the bucket jump the locks were the bucket resides so the auger motor (the one that move the shaft so you get the Ice) is still running but you can't get ice because the bucket is not in the right position. Just try to relocate the bucket.
You can see if the motor is moving the shaft pressing the light switch that is at the top of the freezer. Then dispense, when you press the switch the main board thinks that the door is closed so you can dispense and see if the motor is moving the shaft.
Other failure mode is the flapper door, it depends if the dispenser works with full electronics or if it's an electromechanical dispenser. Full electronics dispenser use a stepper motor to move the flapper door so the failure is that when you press the pad and the flapper door is closing, if you press it again then it get stucked, the motor dispense but the flapper door is closed. With electromechanical dispenser, maybe is the dashpot mechanism.
If any of these solutions couldn't fix your problem please tell me. I think that I can solve this particular problem.
Posted on Feb 18, 2009
  • antonio_f5 Feb 18, 2009
    So... your product is an IDI or a non IDI?
    This is important because in the IDI the chamber were the ice gets crushed when it crushes the ice a lot of times there's like walls of ice inside the chamber and the shaft stop moving because of these walls, the thing is that the motor is forced by voltage and to protect itself from overheating a thermal fuse is activated so you can use the motor when it get normal temperature. So maybe you need to put the bucket outside for a while to melt the ice walls.
    In newest models there's a heater that melts this ice walls but I understand that this solution is from models like 6 months old.
    Also in the case of the non-IDI when you dispense to many times or by too long time the motor gets hot and the thermo-fuse disconnect the current.
    if you remove the bucket and you dispense and do the pressing the switch thing, the motor also starts to work and then stop?
Ice not dispensing through the door and I dont hear a motor
Ice Maker Not Dispensing Ice ' ThriftyFun
www.thriftyfun.com/Ice-Maker-Not-Dispensing-Ice-4.html
Question: Kenmore Refrigerator Will Not Dispense Ice Through the Door. My Kenmore... I don't hear the motor or the crushed ice. What do I do? I have a nearly ...
Ice maker is not dispensing - Checking auger motor & ice ...
? 5:33
https://www.youtube.com/watch?v=Uk83V-fA8Pk
Jul 1, 2013 - Uploaded by ApplianceVideo.com
Ice maker is not dispensing - Checking auger motor & icebucket - Maytag, Whirlpool MSD2550VE502 ... Don't like this video? Sign in to ... The Geek - Maytag French Door IceMaker Replacement - Duration: 25:28.
Ice Dispenser Repair Guide - Appliance Repair Guide
www.appliance-repair-it.com/ice-dispenser.html
Feb 09, 2016 | Refrigerators
LG ice maker will not dispense cubes without crushing them
Check the evaporator system, that release the cubes, when that does not work the cubes stay stuck inside.
Oct 31, 2008 | Refrigerators
I have a Kenmore side by side, not sure the model, but it's probably 10 years old or so. It has an ice maker with water, cube and crushed ice dispenser. The ice maker works fine, but it will not dispense...
Most of the time the bin has been removed and not put back in properly. When this happens ice blocks the drive motor. Remove the bin and turn the auger by hand make sure it will turn and is not jammed. Now with the bin out push the light button in that turns the light out and have someone push the button for ice while the door is still open the motor should turn in the back make sure thereis no ice blocking it. If it turns nothing is wrong with the motor. The clicking sound is usually the motor jammed by ice or the auger not engaged on the motor. hope this helps good luck
Aug 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Hi, i have a kenmore elite side/side w/ice maker and water disp
take a blow dryer( nothing else) and put it on high.
you can have some trapped ice or even some food. get a flashlight and take a look. use tongs to remove anything!
Mar 18, 2009 | Refrigerators
Ice dispenser will not switch back to cubed from crushed
Had the same problem, dispenser stuck on crushed ice, even when cubed ice is selected.  There is a magnetic switch behind the panel where the motor for the ice dispenser is.  It gets water in it and freezes so it is not free to go up and down.  It is always down for crushed, but for cubed ice, the magnet pulls it up.  when it's frozen with ice, all you'll get is crushed.  You'll have to defrost it.  You can defrost the whole freezer, but better to just remove the ice dispenser and defrost that. Three 1/4'' bolts hold secure it.  You'll have to unplug the wires from the back of the freezer to remove the unit. The just let it defrost and dry. You can remove the switch from the panel and dry it out too.   I've had to to this several times and am looking for a solution to keeping water out of the thing so it won't freeze again. Has anybody solved that?
Mar 15, 2009 | GE Refrigerators
Icemaker makes ice; door dispenser cranks, but no ice dispensed
sounds like either the dispenser motor is bad or the dispenser yoke is stripped. remove the bucket from the freezer. you will see a u shaped yoke in the rear of the disp area. this should be fairly hard to turn by hand if it turns easily then the motor gears are bad if the yoke slips on the motor shaft then you have a stripped yoke. hope that helps. peyton...
Jan 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker works fine, only dispenses water
make sure that the ice shoot is not clogged up with ice or the in the ice basket where the ice goes through. Sometimes the ice can be stuck together and jam and nothing will come out.
Nov 25, 2008 | GE GSS25JEMWW Side by Side
Icemaker won´t work
if you got 110 volts to ice maker. try jumping out the T & H ( a small insulated copperwire) . this will cause the ice maker cycle, if this does nothing replace the ice maker.(entire assy cheaper then the parts). remeber you might have to shut the door switch to get the 110v. some machines run the power through light switch
Mar 04, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
351 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
