Question about E-Machines eMachines Desktop PC
Sky box saying no sattelite signals
Sky box just moved upstairs all channels r receiving only one channel not saying no sattlite signal it was coming downstairs
  • Anonymous Apr 23, 2009
    No satellite signal is being recived
    Sergeant:
    Champion:
  • 357 Answers
Check the coax connector and the cable, try anoter cable if you have one available.
Good Luck.
Posted on Feb 22, 2009
How can I fix a no signal message on my sky+hd box
If you receive some channels and not others here's what to check.
Has your dish moved? has it been windy?
Turn off the sky box at the wall and check the two cables coming in from the dish. Unscrew the two "F" connectors and check there is a bit of cable sticking out of the end, if it's not long enough you will lose some channels. if you strip the cable back and make them too long then you will not get the plug back on. Be careful here as the middle cable must be straight to fit in the hole and the outer braiding must not touch the center cable. Make sure the box is off at the wall when handling this cable as there is up to 18 volts on it.
Because you say "it powered on again" i'm thinking your box has a power supply problem. When they were made they did not use good quality parts so there is a repair kit of 15 capacitors that usually need changing. Let me know if you can't get it sorted as i have done these before.
Sep 16, 2014 | Televison & Video
Sky box has no signal. Sometimes channel is coming. Bur most of the time no signal.
Sattelite dish out of line?
Go into skybox menus and find out the signal strength
Jul 31, 2014 | Televison & Video
I have a panasonic viera 42 in plasma. It has a built in freeview receiver. It is in the bedroom and receives a signal through a booster from the main sky box. I can get free view channels on it but can't...
switch tv to analogue tv and auto tune on tuning menu making sure sky is on. It should find it around channel 69. If quality poor then change output frequency to a lower channel. You do this with sky menu and instruction book. Info is changing RF output in book, or google it.
Apr 30, 2014 | Panasonic PV-M1349 Combo
I live in Tahiti and have a coship N6760B digital set top box decoder with sky pacific smart card. I have a 2.3 metre satellite dish with Cband lnbf. From the digital meter point of view I got a really...
Jason478. I would be surprised you are picking up the signal from the Spot beam which Sky Pacific uses. I do not believe even the spill is reaching Hawaii. Best to get a refund of your money as you will definitely loose the signal when the replacement satellite kicks in on Dec 2011. Be careful of the Sales people in Sky Pacific. http://www.intelsat.com/flash/coverage-maps/sat_foot.html?sat=IS-701%20at%20180%BA%20E&display=map&spot=0
Jun 25, 2011 | Coship CDVB2000E
Can record Sky programmes but not view live.
You must connect up the TV to the SKY box, via Audio Visual cables too, in order to watch, recorded programs. You need to hook, up, Component, HDMI, or Composite, You select it by an EXTERNAL channel.
Connect the cable running from the wall into the "In" port on the Sky Box HD receiver. This cable brings in the signal to your receiver. Make sure the cable is securely fastened to the receiver, otherwise you might experience image and audio issues.
Attach an HDMI cable into the HDMI port on the Sky Box HDTV receiver. The HDMI is a single cable that provides both HD audio and video signals.
Plug the other end of the HDMI cable into an available HDMI port on the HDTV.
Power on the HDTV and the Sky Box HDTV receiver. Press the "HDMI" button on the TV's remote control. This will display the cable contents of the HD receiver onto the television.
May 08, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Nikkai 2727 Video sender will not send signals from my sky+ box. The scart lead is plugged into the Video out, but even when i plug it into the TV out it still doesnt work. I know the Transmitter and...
check that you have the sender plugged into the sky box and the receiver into the required tv and not the other way round. The wrong way round still allows the controller to change channels but you will see nothing also ensure that both sender and reciever are on same channel 1 to 4
Jan 24, 2010 | Panasonic Televison & Video
Hi, I have a digital tv plugged into an extension cable in an upstairs (Toshiba) bedroom; it works perfectly - receiving all channels. I have a digital tv downstairs (Samsung) where it seems the wall...
Hi Fiona
Somewhere along the line from the aerial there must be a signal splitter that feeds the upstair and downstair terminals.
Try to find that splitter and switch the output to see if the problem goes from up to downstair.
If it does switch then you know the problem is with the splitter block, and if it stays the same then the problem is with the cable and/or the connectors that run downstairs.
Also the reason you get a pixellated(snowy) picture is because of signal loss during the length of the cable you ran downstair.
If running a cable downstair becomes the best option to fix your problem , then you could buy a cheap 10db signal booster/r.f amplifier to correct the signal loss and a cable splitter to feed both tv`s
That booster would be installed upstair in your case(near the source of the signal to be amplified).
I could send you a small diagram if need be. Hope this will help and Merry Chrismas
Dec 14, 2009 | Televison & Video
Hi, i have just bought a logik wireless av sender so send my sky signal to the tv in the bedroom. the instructions in the manual are very basic and i cant get it to work. any ideas. on the tv in the...
Red and white are only Audio ports.
IF there is a scart port plug your av receiver into the scart. Take note on which number your on ie channel there should be several numbers you can choose on your tx/rx then go down stairs to your sky box and ensuring that you are on the same number as the one upstairs.
Then just plug it into the back of your sky Box.. the number on your sender are incase your getting interfearance from other sources in the home. have a play with this and see what works best
Hope this Helps
Little Dish Fitter
Aug 22, 2009 | Televison & Video
Sky upstairs
Yes on the back of the box there is a RF2 output...
run a coaxil aerial cable from there to your required TV, you then need to tune the 2nd tv to the sky box.
You can also buy a 'Magic Eye' and a 'extra remote' this will allow you to change channels from the second destination with only 1 digi box.
Down point is that you have to watch the same channel on both tv's.
a second card and box and a dual LNB will allow you to watch seperate channels.
Jul 20, 2008 | Televison & Video
E-Machines eMachines Desktop PC Logo
141 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
