Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
Hoshizaki Flaker Gear Motor Part
I need a part for the gear motor (auger drive transmission) for a Hoshizaki F650-MAE Ice Machine (Flaker). The company wants to sell me a new motor and transmission for $1700 but all I need is a small gear wheel made out of nylon composite (designed to wear out) that is easily replaceable. Help!
  • 1 more comment
  • kettnerequip Feb 20, 2009
    I am looking for the first gear of a speed-reducing gear motor from a Hoshizaki Flaker Ice Machine model F-650MAE. This same gear motor would probably be used in several different flaking models and the ice auger mechanism is basically the same in several models. The gear is nylon or fiber and is 2 & 1/8" in diameter, 1/2" thick, and has a hole in the center with a key way. The 62 teeth are angled. The company will only sell me a complete gear motor assembly, motor and all but due to the age of the machine, the cost simply is not justified. Someone, somewhere, must stock this gear, know where I can get one, or point me to someone that has a pile of used machines. Any help would be seriously appeciated. Thank you.
    Um, I'd like to thank everyone who has directed me to parts warehouses and Hoshizaki itself but this, unfortunately is not helping. I know I can purchase a new gear motor and have had many of you point me in that direction. The thing is this; the gear motor drive was made to come apart and the fibre wheel was made to fail or break so that the rest of the mechanism did not. Therefore, it should be available somewhere.
    One expert told me the gear motor is not serviceable; um, I'm not into HVAC or appliances and I had the gear motor out, apart and properly diagnosed in 1/2 and hour.
    So, thank you everyone that has tried so far, but what I really need is a gear supplier or a source of used parts. Hoshizaki and other new parts dealers and websites just want to sell me a $1700 part...which is way to much for a $1000 machine!
    As for the machine shop - I'm still trying that too but the only shops willing to take the project on are telling me it will be 4 - 5 hours in setup alone.
    Please! A link to a website that will sell me the complete assembly for $1700 is NOT a solution! A source for used parts or the actual gear would be. Thanks boys.
I expereinced the same problem and the only solution I could come up with was to have the gear fabricated. I made a few fro backup. I haven't used any in the two years since i fixed mine. I can sell you a replacement gear or you can send me the gear box and I will install the new gear for you. This same gear box is used in a number of Hoshizaki flakers. Typically symptoms are noisy gear box and jerky auger, or motor spinning but no Auger rotation. Cause is typically scaling/ calcium build up in the evaporator tube. The extra torque stips the gear.
Call me if I can help James 580 799 2873
Posted on Nov 14, 2011
  • james chopping Nov 14, 2011
    I ran into exactly the same problem. Faced with a $1700 repair bill, my solution was to have a new gear made. I had several made, my Hoshizaki flaker is still running strong 2 years later with the new gear. I can either sell you a gear or repair your gear box.
    The same gear box is used on a number of flakers. Symptoms are a noisy, popping gear box, irregular or no auger rotation when the gear motor is spinning. The problem is caused by calcium / scale build up in the evaporater cylinder, which requires more torque to overcome the extra resistance and the nylon gear in transmission gives up first. Repacing the the gear box is simple, replacing the gear inside the box is bit more work but do-able with just an allen wrench and average handy man skills. It is filled with oil so it does make a bit of a mess. Call me if I can help James 580 799 2873
    Director Badge:
    Uploaded 100 video answers.
  • Hoshizaki Master
  • 488 Answers
here is video how to replace gear box assy on hoshizaki ice machine
Posted on Jun 09, 2016
HELLO AND GOOD DAY!
Don't give up! I had the same problem witht a Scotsman I had, and was told I had to replace the whole transmission, but I kept looking and found that the parts could be ordered, and finally found an outfit that would order the gear I needed. I was able to put the gear drive back together as good as new.
Posted on Apr 05, 2010
    Scholar:
  • 164 Answers
There are several options available to you.
Look on the net for restaurant supplies / used.
Or go online to a place like this.
http://www.katom.com/hoshizaki-parts-request.html?gclid=CPnE48DA8ZgCFR2dnAodwATw1Q
Mastersage
Posted on Feb 23, 2009
    Sergeant:
  • 326 Answers
  • 423 Answers
I agree with Benimur. They make that unit so it is not serviceable on purpose. Part of their philosophy of "no parts to wear out". You are going to have to get if fabricated and either pay that price, or buy an entire new assembly. Bottom Line.
Rob
  • 15,935 Answers
Use THIS contact form to inquire about a replacement gear.
Any gear fabricating company will be able to help out with the gear as long as it is in tact and proper measurements can be taken.
I have used THIS company before to machine a metal drive gear for a replacement to the plastic one on my R/C vehicle. But it requires you to take the proper measurements!! They have a great "CAD" program that you can design the gear yourself.
The Gear I purchased from them was $89 (plastic replacement was $25) and about 1.5" dia.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 20, 2009
    Sergeant:
  • 250 Answers
As that only part ,the gear which you require is not available but you will have to get whole motor unit but that is too costly.trhe option to try out is local repair center as they have all the parts in spare and also provide you if you explain the exact part or at the junk shop you can get but the same unit is very much difficult to get there as when you require.but the local repair shop near your area will provide you that.
    Genius:
  • 1,011 Answers
Sir,
Click this link for your part number
An auger type ice making machine including an upright cylindrical evaporator housing, an auger mounted for rotary movement within the evaporator housing to scrape off ice crystals formed on an internal freezing surface of the evaporator housing and having a lower end portion drivingly connected to an upper end portion of an output shaft of a drive mechanism, wherein the lower end portion of the auger is in the form of either a columnar portion or a cylindrical portion, while the upper portion of the output shaft is in the form of either a cylindrical portion or a columnar portion, and wherein the columnar portion of the auger or output shaft is coupled within the cylindrical portion of the output shaft or auger for drive connection between the output shaft and the auger.
thanks good luck
  • Asfiya Ahamed
    Asfiya Ahamed Feb 21, 2009
    It mean do u want to buy the used parts? i am right. or u want to sell the whole assembly clarify me
    Genius:
  • 2,035 Answers
  • 564 Answers
Hoshizaki Parts
http://www.icemachineworld.com/?aw&1
Here is what you need. Just click the Link Above. Please Rate My Response! Thanks!
PREM
    Scholar:
  • 140 Answers
I have been to the Hoshizaki training classes in the past. Yeah, they try to sell you everything.
Sorry for your luck but they will not offer tranny part as peices. You have to buy the whole unit.
From now on out; SAVE all the parts your strip from a Hoshi and store them "just in case". You never know what parts you are going to need.
You have a couple of options, you either find local Hoshi dealers in your area and see if they have scraped any parts that you need. Most of the time they will give them to you for free; just for asking.
-or-
You can have the part manufactured. At the tune of $1,700.... you can get someone to make the part much cheaper.
Even if you use a premo company like Rush Gears Inc. They don't charge $1700.
You may also try these suppliers.
Rushgears.com out of Fort Washington, PA
K2plasticsinc.com from Bergen, NY
abapgt.com from Manchester, CT
Hope this helps and good luck with your repair.
    Brigadier General:
  • 8,619 Answers
Hi!
Please see the link---
Hoshizaki Gears
Also, you can get them at--
Hoshizaki
Please contact them for Parts of your Hoshikazi Ice Maker--
Phone: (510) 357-2500
  • 547 Answers
Http://www.hoshizakiamerica.com/ please go here to find part's thank you for useing fixya please rate me
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
May I offer an alternative? If you still have the broken nylon gear, then a replica can be machined. It could be made out of nylon composite, teflon or even brass. You need to locate a "Machine Shop" with a Milling machine (with indexer) and a lathe. The machine shop could take the measurements of the broken gear and replicate on a block of raw material. It may be expensive but to my thinking nowhere near the $1700. Additionally, you could ask the shop to make several as spares or share with others with the same problem.
Good luck and thank you for using FixYa.
Posted on Feb 19, 2009
  • Louie  Role
    Louie Role Feb 20, 2009
    Or try here.
  • Louie  Role
    Or even here. To help you identify the part number, exploded parts diagram is here.
  • 544 Answers
when the gear motor is damage it cannot be repair only solution is to replace..
but if you unit is new and still on warranty period try to send or call the technician of the store where you the unit.....
but if it is not? try to look to a surflash shop who are selling a second handed spare parts but be sure that it is in good condition and still working.
hope my suggestion will help you to decide.
thanks,
    Brigadier General:
  • 3,614 Answers
Go HERE
  • 350 Answers
Dear kettnerequip,
RE: Hoshizaki F650-MAE Ice Machine (Flaker) Part for Gear Motor
DON'T GIVE UP UNTIL YOU TRY CLICKING ON THIS SITE @ http://www.emachineshop.com/
You give them the specs & they'll cut it for you at probably the best price on Earth!
jackiaria
Tuesday 02-24-2009 11:19am EST (USA)
Posted on Feb 24, 2009
    President:
  • 1,902 Answers
The small gear is not something that you can just order through any company. You will need to replace the motor and the transmission which can be ordered here.
There is also a number on there that you can call and talk to hoshizaki themselves
  • 1 more comment
  • Jeremy Reddick
    Jeremy Reddick Feb 20, 2009
    I work on Hoshizaki everyday in and out. This is my specialty I am sorry to tell you this but there is not a way to just replace the gear unless you have one specially made or order what I posted to you for 465 dollars and install the whole system. I know it comes apart. The problem is though is that Hoshizaki did not make parts to fit this and there is not a company besides a skilled shop to make the actuall gear.
  • Jeremy Reddick
    I would also like to know where they got the 1700 dollars to replace this part. Also I know that Hoshizaki is not selling the part for 1700 dollars. I believe that the company working on your unit is just trying to get money out of you. I replace the motor and the trans for 750. I know that is still alot but at the same time the unit is worth it when it comes down to it. I use a local shop to have my gears made out of a teflon composite for longer lasting.
  • Jeremy Reddick
    http://www.partstown.com/is-bin/INTERSHO...
    This is a link to all the gears that you can buy for Hoshizaki
  • 19,396 Answers
You can find used and rebuilt parts from company below:
Alternative Parts & Equipment
You will need to contact them, if this is a single gear they can rebuild for less than rrp.
I have a Hoshizaki F-800MAF flaker ice machine an it keeps flushing an we have to clamp off the flush tube to make ice, what could the trouble be
There is a "Dump Valve" that is stuck or has trash in it. Follow the small tube from the pump to the white plastic valve that looks kinda triangular with 3 screws. Remove the screw carefully as this is spring loaded. There should be a black rubber piece that is a seal. Pay attention to how it assembles. The spring presses the seal against an opening. Look for something that may be allowing this not to seat.
Oct 01, 2017 | Hoshizaki Freezers
Hoshizaki Model KM 630 MAE
Look for a stuck float switch. unit fills with water for 1 minute, then the board "looks" at the float to "see" if there is enough water in the unit to run. If float switch is stuck down, it tells the unit there is not enough water and the unit stays in the fill cycle causing the sump to overflow and send water down the drain constantly. Compressor will not run till the board senses that there is enough water to run.
Jun 25, 2012 | Hoshizaki Freezer Commercial Ice Machines...
KM-500-MAE Hoshizaki Problem huge cubes, alarm code three beeps
Might need to clean float switch, or water inlet valve bypassing water. Deep clean Hoshizaki.
Sep 30, 2010 | Hoshizaki Commercial Freezer KM-500MAH
KM-500-MAE Problem huge cubes,alarm code 3-beeps
excessive freeze cycle=60 minutes. In almost every case, it's the water valve (sometimes called the fill valve) is leaking water continually into the sump. Turn machine off and see if you can still hear water running into the unit. If so, it the valve leaking. Just replace it.
http://www.hoshizakiamerica.com/manuals/KM-500M_E_serv.pdf
Go to this site and download you copy of the service manual. It has lots of good stuff.. Let me know if I can be of any further help.
Sep 30, 2010 | Hoshizaki Freezer Commercial Ice Machines...
WHAT IS THE CAPACITY OF MODEL F-450BAE FLAKER
It is to produce 450 pounds of ice in 24 hours under ideal conditions. Manual says anywhere from 345 to 440 depending on factors of water temp., ambient temp., and system pressures.
Hope this is what you are looking for.
Mar 03, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki condensor fan motor is not working
Too long to explain sequence here. but in the harvest mode the fan will not be running. go to hoshizaki.com you will find every thing you need very helpful site . and a clean machine is a happy machine. hope that helps Tom
Jun 28, 2009 | Hoshizaki Freezer Commercial Ice Machines...
GE S/S Refrigerator model GSS20IEBWW auger not turning
Take a hair dryer and heat the auger drive gear. These will sometimes get moisture on them and freeze up.
Turn the refrigerator off first. Then remove the ice bin. The "U" shaped drive will be in the back.
After you have heated it thoroughly, try to move the gear manually. Resume power and try it again.
May 19, 2009 | GE Freezers
Hoshizaki ice machine KM500-MAE not sending water to harvest
I would not change the pump. If it runs for 3-5 minutes and stops, it has to be a control. The control board runs the freeze cycle for the first 5 minutes. This prevent "Short Cycling" of the freeze cycle. The board looks at the float after the first 5 minutes for the proper water level but should not effect the pump. If the pump does not run in the wash mode, check out the "Power/ Wash" switch. I would start there before I go spending hundreds on pump motor or control board. You may be able to get by on a $20 fix! Do this and get back to me. We will get it going.
Good Luck
May 06, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki ice machine with constant beeping every 3 seconds
Most likely(50% of the times) Your Ice machine need a real cleaning. not just run clean cycle with ice machine cleaner. every 6 month call HVAC-R guys - machine will last half time longer if u schedule proper maintenance with them. I have seen It all: people try to call "friend", or someone who "knows" how this machines work. Real clean would take up to 3 hours for people who know what they doing. Here is one of my videos, when 3 beeps - long freeze cycle is not common and all others would offer You to get a new Ice Machine. Bill to the owner was 950$, New Machine 3450$ plus labour to install 600$.
Jun 23, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
1,256 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
