Question about Kenmore Dryers
Kenmore 90 series gas dryer
Set timer at 60 min, it heats up for about 5 mins then whole dryer shuts off. wont start till it cools down?
  • 70 Answers
The trouble is actually with the start bearings in the drive motor,I bet you have a small hummmm or GRRRRR right at the start, as if the unit wants to hesitate.
Anytime you have a dryer that starts then shutsoff and must "cool" down, it is the motor.
Posted on Feb 19, 2009
I have a LGR5636EQ3 Maytag dryer that will not heat up and the timer is not keeping correct time. Dryer will run but longer than preset time and no heat. No click noise when started. I had dryer set at 60...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 13, 2010 | Kenmore 73952 Gas Dryer
Gas dryer runs for 30 mins then shuts off.
This is a common problem that is not a good one. But the motor is goin bad. If you try to start it you will hear like a hum then start. Motor is going bad and over heating and shutting down on overload. Sorry. Hope this helps.
Jan 31, 2010 | Kenmore Dryers
Have a 90 series kenmore dryer, won't always run. replaced the motor about 6 months ago, and now it will sometimes run, sometimes not. It gets hot, and will run for a bit then shut down, then start up...
If the timer is not advancing but is ticking that could be the problem. A dryer achieves a set temperature and stays there for a certain amount of time during a cycle. If the time never changes it may just keep heating up until the heat sensor shuts it down. If it is starting and shutting down its likely still related to the heat sensor.
Dec 07, 2009 | Dryers
TIMER PROBLEM??? I have a Kenmore Elite Mod# 110.63932101. You can set the timer for 60 min's and watch it spin all the way down, beep & shut off in about 5 min's. Everything seems to be operating fine...
The operating thermostat controls the timer and should open and close the circuit as it senses heat during the dry cycle. If it fails to open it will just keep the timer 'energized all the time and run straight through and go off. Change the 'operating thermostat'
Jul 09, 2009 | Dryers
90 series kenmore elect. shuts off
are u sure it does this only in that cycle? if so the only thing i can think of is a timer, inless the thermostat is shutting it down because the element is getting too hot.... whirlpoolpartssurplus.com mark ... give me a call free
Jun 26, 2009 | Kenmore Dryers
Dryer heat turns off after about 5 min- dyer will remain running but no heat
HI, After the heat shuts down, do you hear a click like it is trying to heat again but then get no flame. The most some problem is the coils on the gas valve go bad and will not reopen after they have heated up.
Remove the cap on the front lower left panel. After dryer has ran and heat shuts down, watch and se if the ignitor glows again (you will hear a click) and the ignitor shuts off before a flame. If this happens, change the coils on th gas valve.
Here is instruction: Normal 0 UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
Jun 01, 2009 | Dryers
Loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Apr 10, 2009 | Kenmore 62602 Electric Dryer
Kenmore dryer 70 series flame ignites, but goes out after 5 mins
If it's gas, the coil valves get weak and are unable to hold themselves open when hot. First, check the exhaust vent. If it's clogged, it can't remove heat and it will shut off prematurely. Most likely the coil valves though.
Mar 03, 2009 | Kenmore 63942 Dryer
Kenmore 90 Series Gas Dryer that drys for 10 mins & shuts off...
Check the vent pipe going to the outside of the house, including the vent louver, to make sure the pipe is not partially or fully clogged with lint.
Your symptoms are a classic description of reduced or no airflow from the dryer.
Jan 09, 2009 | Kenmore 62802 Electric Dryer
Dryers Logo
110 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
