Question about Splendide 2000S Front Load Washer / Dryer
We have a Splendide 2000 washer/dryer combo in our RV. Problem is, it is overfilling (water halfway up the door) and then starts draining out without agitating, and starts refilling again. The setting control knob doesn't move automatically. I can turn it off and manually move the knob to the end of the rinse cycle and it will agitate and then spin out and start drying. Solution??
IB4G2008
  • 3587 Answers
SOURCE: Washer doesn't agitate
sounds like your washer went mellow on you(doesn't get agitated, right)?
ok. enough humor.
sounds like there's a problem with the motor/belt/control board in that order
Posted on Mar 13, 2008
SOURCE: Washer fills, drains, & final spin
I had the same problem and ended up replacing the control board which solved it.  Contact Westland Sales at 800-356-0766 ext. 5 for tech support.
Posted on Jun 02, 2008
ginko
  • 19396 Answers
SOURCE: Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Posted on Nov 20, 2008
    • 17 Answers
    SOURCE: washing machine refills after spin cycle
    Can you hear the pump running if not the machine may be syphoning out, if the outlet is into the down pipe too far this can cause it to syphon. The outlet should only be into it by about 6". The machine will fill with more water on the rince than the wash cycle that will cause the problem. If you can hear the pump running the machine mite be over filling there may a blockage in the presure system if you take the lid off (making sure the powers turned off) you will find a round switch with a thin hose comming off it tace the hose and you should find a small bottle this may be blocked. Hope this helps you.
    Posted on Dec 22, 2008
    • 20 Answers
    SOURCE: machine fills and agitates, but won't drain
    Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
    Posted on Jan 19, 2009
    Plugged into bad electric, Washer/dryer combo does not power on now
    if your appliances all blew they may have been fuse protected, such as tv's and microwave have inside them. Power converter should be fuse protected as well. If the plug was wired incorrectly was it a fifty amp service or thirty? Does your power run threw a transfer switch? look there as well. typically voltage spikes threw ground circuits take out your electronics. Using ground fault interruption circuits and voltage protectors in between your plug and power supply will prevent most/some damage. many variables to pinpoint without input.
    Nov 11, 2012 | Splendide 2100 Front Load Washer / Dryer
    Splendide Model WD 802 . Would not drain water.
    I have a Splendid Washer/Dryer combo Model # WD802.
    The water is not draining. I have taken the filter out, cleaned it, still does not drain. Gets to the drain cycle and does not go any further. Same in every cycle.
    Anyone with suggestions for repair ? Thanks
    Aug 01, 2011 | Washing Machines
    Splendide 2000 S runs through cycle but water left in unit (hums)
    The drain pump is probably clogged. or drain hose is kinked. I have a trouble shooting guide if you are interested.
    Coach Tech RV
    734 777 6432
    Mar 23, 2009 | Splendide 2000S Vented Washer/Dryer
    Broken door handle on Splendid 2100 RV Washer/Dryer Combo
    The Splendide distributor in OR sells handles for about $45.
    Jan 27, 2009 | Splendide 2100 Vented Washer-Dryer
    I have a Splendide 2000 s vented washer and dryer. I started a load and there was water leaking all over my floor from the washer, so I immediately turned it off. Now I'm trying to get those clothes out...
    Unplug it. Door latch has thermal delay. Unplug, let cool 3 minutes, open door.
    After door is open, you can kill the delay: with door open remove rubber boot to access gap between door & drum, remove door catch from cabinet, glue, break or unwire delay parts & replace all. Do this with safety glasses, the spring holding rubber boot can be a bit jumpy.
    Your leak I know nothing of.
    Jan 26, 2009 | Splendide 2100 Vented Washer-Dryer
    WD200S overfills with water
    Sounds like the switch that detects the water level is malfuntioning, this can be caused by one of several reasons.
    I assume that the water stops running in if you stop the m/c, if it does not, then you have a faulty water inlet valve, which you would have to replace.
    I think you neede to call an engineer.
    Hope this helps.
    Please leave feedeback.
    Dec 07, 2008 | Splendide 2000S Vented Washer/Dryer
    Splendide 2000 doesnt work at all on wash
    I have exactly the same issue. The door normally locks, but doesn't do anything on wash.
    Jul 29, 2008 | Splendide 2000S Vented Washer/Dryer
    Splendide 2000S
    www.splendide.com
    1-800-356-0766 #5 (503-656-2280)
    503-722-9202
    service@westlandsales.com
    Monday-Friday, 7:00am - 4:30pm (PST)
    You may also want to try a RV retailer in your area, they may direct you to a used part.
    Jun 10, 2008 | Splendide 2000S Vented Washer/Dryer
    Splendide 2000S Front Load Washer / Dryer Logo
    1,042 people viewed this question
    Top Splendide Washing Machines Experts
    Philip Diggins
    Level 1 Expert
    Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
