Question about Acer Ferrari 3200 Notebook
Acer Ferrari 3200... Black Screen !
Do startup...or make the same sound all the time. Media Activity light starts to blink but stop after a few second. Have tried System CD and Recovery CD and they do start but nothing screen all the time and nothing I can do !
Anyone have a solution ?
Hello, how can i get my Acer Ferrari 3200 to see the full 320 Gig Hard drive, at the moment it will only see 128 gigs.
Open your partition manager. Check if there are partitions other than the 128Gb detected. If there are others, you can create a new partition for those unpartitioned space
Apr 27, 2011 | Acer Ferrari 3200 Notebook
(ACER ferrari 3200)earphone and disc drive
The headphone jack is soldered directly to the motherboard. finding a new one and getting it soldered on is the only option. As to the dvd I would remove it (one screw holds it in either on the bottom or under the keyboard) finding the model number and ordering a new one on ebay
Jul 15, 2009 | Acer Ferrari 3200 Notebook
Acer 8100 Travelmate - blank screen
Acer Ferrari 4000 "power on" blank screen, fan is running but no beeps, no activity in/from the HD. No reaction on a F8 start up (no Bios set up). It charges the battery OK.
KR Steen Larsen
Dec 08, 2008 | Acer Ferrari 4000 Notebook
Acer ferrari 3500 problem
Your video card in the laptop is failing. If you remove it, reapply new thermal paste and clean it all out while you are in there it may be fine.
Heat will cause all of your stated issues, as well as doing damage to the video card.
Laptops have a habit of building up dust and hair on the fins of the heatsinks causing them to bocome blocked and should be cleaned every 6 months at least.
Oct 11, 2008 | Acer Ferrari 3200 Notebook
Laptop won't start.
connect yr system to an external Monitor(CRT) if it comes up then yr problem might be from the inverter,backlight,screen etc.
but if it doesnt come up then yr VGA card may be damaged.
NB:u must be sure ur system is up n working by pressing the caps lock key to check if the caps lock led will light up. if it doesnt lite up then yr system isnt up n running . what yu do at this atage is to replace the ram n or processor then it should display normal.
hope this helps
thank u
May 31, 2008 | Acer Ferrari 3400 Notebook
Acer ferrari display problem
If you mean like squares of pixels then it will be the video memory on your video card failing or over heating.
Check the video card and make sure it's not clogged with hair and dust etc and reseat it. Also use good thermal paste when you put it back together between the heat sink and the GPU.
If that fails to improve things then a new video card will sort it right out.
You could always send it to me.. I have a thing for Ferrari's ;)
May 23, 2008 | Acer Ferrari 3200 Notebook
Acer ferrari 3200 pc notebook problem
Hello. Vista needs a repair. You will want to start by putting in your own vista disc or borrowing one from someone. If your laptop isn't booting from the disc, then enter the bios (by hitting f2 or f12 usually) at bootup and select the DVD/CD rom drive to boot first. When the vista disc loads you will want to select recovery tools. Then select "startup repair". That should fix your problem.
Apr 12, 2008 | Acer Ferrari 3200 Notebook
Acer 3200 Ferrari !! Urgent
 First I would try a system restore to before the point when you first started getting the blue screen,it could possibly be a driver update conflict.
Mar 25, 2008 | Acer Ferrari 3200 Notebook
Acer Ferrari 3200 Notebook Logo
217 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
