Question about Kenmore 30464 / 30465 / 30469 Gas Single Oven
Filling in the gaps between the kitchen counter sides and stove
I have a Kenmore stove and there are gaps between the sides of the stove and the kitchen counters. The food keeps falling into the gaps when I am cooking. I looked up some "gap fillers" online, but they were all made of plastic and looked pretty cheap on the photos. I have a newly remodeled kitchen with green granite counters and the stove is black; and I want to find some gap fillers that would look very tasteful and top-notch.
  • 3 more comments
  • snow_and_spa Feb 19, 2009
    Sorry I've selected an incorrect model number. The oven is a Kenmore gas range, model 790.
  • scrappy19 Mar 16, 2009
    ditto - black granite counter top and blank range at exact same level
  • DRRXR May 11, 2010
    Is the gap constant? How wide is the gap?
    One more thing; is your counter top above or below the edge of your oven?
    You just want to fill the gaps at the top on both sides? Is this your oven? http://www.viewpoints.com/images/review/...
  • 68 Answers
Stove Buddy crumb bumper makes a black one that is a heavy duty non metal-can handle 500 F but is not cheap like the kleen seam--
Posted on Mar 03, 2010
My broil HAS NEVER WORKED. top element does not heat up even after the control panel was changed.
Search Results
    Gas Oven Broilers - Do Any Really Work? - Chowhound
    www.chowhound.com/post/gas-oven-broilers-work-923543
    Nov 8, 2013 - but do want to say that I broil in my Breville Smart Oven and it's great.... I have never had a gas stove in any home I've ever lived in, always ...
    Kitchen Basics: How To Use Your Broiler ' The Kitchn
    www.thekitchn.com/kitchen-basics-how...
    Apartment Therapy's The KitchnMar 31, 2010 - Every oven that we've ever come across has some kind of broiler - it's the same device as heats your oven for baking or roasting, after all.
    I have a Kenmore electric range; model 920/9285*. The ...
    www.shopyourway.com > Manage My Life > Questions
    The oven and broiler on my stove won't heat up. Was working ... Having a Oven not working can be rather disappointing as well quite a concern. I have taken the ...
    Top or Bottom Broiler? [Archive] - CookingLight.com Community
    community.cookinglight.com > ... > Food > Popular Threads Archive
    Sep 3, 2002 - 24 posts - ‎7 authors
Jan 27, 2016 | Stoves Ovens
Kenmore Oven and stove not igniting
If both top and oven are not igniting, then most likely you need an ignitor board. I should be located behind the left side of the console as you are looking from the front of the stove. I will look it up to be sure. There should be a tech sheet on the back panel of the stove to help in checking the boards.
Thanks/Mike
Dec 02, 2007 | Ovens
Where can I find an electric range with depth less than 28 inches
Bertha, most stoves are going to be anywhere from 26" deep to 29" deep. Most any stove that I have used or worked on has never been a counter depth stove unless it was a slide in or a drop in stove. When I went to GE's website, I did not many stoves that were less than 28" deep until I got up to $1000 in retail pricing. The only one under that price that was less than 28" was also only 24" in width. Hope this helps!
Dec 08, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore oven 317b6034
It sounds like the heating element is faulty. If it has a short, it will have a damaged place. A short causes a build up of amps until it can't take anymore and then a action will happen like a fuse blowing, which it the noise you hear. You can get replacement elements on Amazon fairly cheap. To fix, unplug the stove. Lift and tug on the element to pull it out of the socket. It is usually easy.
Rich Long
Jan 26, 2014 | Kenmore Ovens
How do you light the pilot on a Kenmore gas oven?
we have a kenmore stove in kitchen and it has a ignitor that glows for oven. if the oven will not work check out the ignitor for oven. just remove bottom cover of oven, then you will see it. this is for electric ignitors.
Feb 10, 2012 | Kenmore Ovens
My stove is flashinang and beeping f1....model number 790.94859301 whats it mean ...is my kitchen gonna go boom
that code says you have a problem with the clock assy. and it also has a computer board built into it,the part number is 316557511 and it's around 100 dollars.you can try unplgging the stove for 5 minutes and plug it back in,if the code comes back change out the clock assy.
May 11, 2011 | Kenmore Ovens
I own a Kenmore stove model #639539J2. The glass
yes. open the oven door to the first "click". it kind of stops about a quarter of the way open. most ovens you grab both sides of the oven door and pull up. some models have a couple of screws you have to take out before you can remove the oven door. then lay it down with the insie of the door facing up and take out all the screws holding the oven door together. some may be on the sides or the top and bottom of the door. when apart, clean first with easy off, then clean several times with windex till streaks are gone. assemble door in reverse and put back on stove.
Oct 10, 2009 | Kenmore Ovens
Kenmore 30464 / 30465 / 30469 Gas Single Oven Logo
3,447 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
