Question about Canon PIXMA MP470 All-in-One Printer
Alignment Every time I print something off the internet the bottom of the page is cut off. It does not do this with Word. How do I fix it?
    President:
  • 2,692 Answers
The way that I fix it is to download and save the internet page(copy and past only the pic or words) into WORD , then print the file.
Posted on Feb 18, 2009
Alignment off
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, please try this approach:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 2600 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Align to fix blurry edges. Your printer will then print a page and aligning your print cartridges. Try to print a document again to verify that the problem is fixed.
Dec 11, 2011 | Lexmark X7170 All-In-One InkJet Printer
Lexmark C920 color print is faded on bottom of page
Quite possible something happened to the printheads.....especially the Magenta one. Might have been 'bumped' out of alignment. They might just need to be wiped clean with a toner cloth. They are usually right above the toner cartridges. Have you tried a color alignment adjustment in Config mode?
Mar 12, 2017 | Lexmark C920 Led Printer
HP Photosmart 7960: This might be an alignment problem, but do not know how to take care of it. Problem: When printing, it leaves around 1.5 inch space to the top of the page and cutting the bottom of the...
before you print you must go to print properties. then customize your settings. go to effect settings and select your paper size and fixed that. under that select scale to fit it you have that option. then click ok
Nov 30, 2009 | HP PhotoSmart 7960 InkJet Printer
X2480 unable to bypass print/scan of alignment page
Here is the way I bypass the alignment when I get a new cartridge: When the screen comes up that is asking for it, it does not have the option to "cancel" the printing of it. I just take the paper out of the printer and press "print". Since there is no paper in it, it cannot print. This will make the same screen come up again, but this time it has the "cancel" option. Now, every time I want to print something out, the screen that wants to print a alignment page comes up, and I just click on "cancel" - after that I can do my printing. This is a bit annoying, but it saves me some ink.
Mar 23, 2009 | Lexmark X2470 All-In-One InkJet Printer
PRINTS TEST PAGE WHEN TURNED ON
Actually its not my solution... see http://forums13.itrc.hp.com/service/forums/bizsupport/questionanswer.do?admit=109447627+1235819514435+28353475&threadId=932709
"Holly" posted something that worked for me:
Holly Jul 6, 2005 07:09:59 GMT Unassigned Hello!
This is something you can try. Sometimes the printer doesn't understand that the alignment page you are scanning is for it to read, therefore you have to do a 'standalone alignment' on the unit before it actually does understand. Here is how you do it:
1. Hold Cancel and On, then release.
2. In sequence, press Cancel, Resume, Paper Type, Color Start Copy.
3. Another alignment page will print out and this is the one that you should actually put faced down in the scanner glass and press Scan.
^Hopefully that will be the last and final time that the alignment page prints out!!
Feb 24, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP 1410v will not print.
The printer is printing an alignment page. Take that alignment page and put it on the scanner part of the printer and then press the scan button, that will align the print heads
Nov 12, 2008 | HP PSC1410 Printer
Test and scanning the alignment page
we have a link on how to fix your own printer through this link(check for search box further down page)
Mar 08, 2008 | Lexmark X2470 All-In-One InkJet Printer
The C4280 will not scan in the Alignment Page
I have had the same problem. When I was trying to fix it, noticed that my color cartridge was almost empty. I understood the alignment page was not prepared well. After changing cartridge, I prepared a new alignment page, then tried it and it worked
Jan 21, 2008 | HP Photosmart C4280 Aio Printer
HP Deskjet 6122 alignment issues
Have you set your paper size in the printer and adobe or whatever you use to A4, it sounds like you have A5 set as default print size. Apologies if this is not the case but it won't be the first time a printer has changed settings.
Jan 12, 2007 | HP DeskJet 6122 InkJet Printer
Canon PIXMA MP470 All-in-One Printer Logo
242 people viewed this question
old marine
old marine
