Question about Lexmark X3470 All-In-One InkJet Printer
I moved my computer and lexmark3470 to another room. suddenly i hook it back up [ports work fine} the three buttons on the left won't move up and down, and the printer keeps saying theres a computer jam when there is not. The blue dot alingment came out fine, so how can there be a paper jam? also, i could never get this scanner to scan stuff onto the computer. it only prints and scans what you already have. thanks for any help
    Genius:
  • 2,035 Answers
If it shows false paper jam error try these steps :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Mar 31, 2009
When using a design in Cricut Craft Room, and select cut, my Expression 2 begins, but does not complete, the cut. The arm moves to the paper and then makes a croaking sound and then nothing.
Search cricut.com for support faq go to expression 2 search format and reset. Watch the video on format and reset and do as it says. Calibrate when it's finished. If this doesn't work re download ccr after deleting it from your computer.
Jan 10, 2016 | Provo Craft Cricut Expression 2 Electronic...
I moved my PC from one room to another and now the mouse won't sync with the USB connector. What do I do?
Hi, reconnect the usb to another port on the pc, check your users manual that you are pressing the buttons in the correct order, and that the mouses batteries are not empty.
if the problem comtinues try another mouse as we can't do other troubleshooting without a working mouse to use the computer with.
Jul 07, 2011 | Dell Computers & Internet
I moved my pc across the room and when i hooked
It could be due to static
do the folloeing
1) Unplug all the cables including powercables
2) press and hold the power (On/off) button for 30 seconds on the front tower which will release all the static.
plug back the cables do the same with monitor
and then check it should work
May 10, 2010 | HP Hewlett Packard Pavilion Slimline...
My mouse was just working and all of a sudden it stopped, I changed the batteries, reset the small button on the bottom and also pushed the button on the plug in portion. Help Allen
I have a miscrosoft wireless laser mouse 6000, and it also stopped working on my laptop. I changed the battery, still not working. I tested the battery in another device, and it was good. I moved the mouse to another computer, and it did not work. The light on the usb connector was lit. [No changes at all to my laptop.]. It seemed like there was no power to the mouse, and I looked at the contacts inside the mouse. The contact just inside the battery opening appeared to be bent down away from the contact on the battery tray. So, I pulled it up a little so it would connect when the battery drawer closed, and (after tweaking it a couple of times), it finally worked!
Dec 08, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
Keyboard not working-no power
Double check in the ends of the plug to make sure you did not bend or break any pins when you plugged them back in.
If you did then it is quite possible you need new and that you should also check the sockets on the back of the computer to make sure they are not damaged either.
Aug 17, 2009 | HP Computers & Internet
I moved, and now my speakers won't work
check for the power button is on behind the woofer or speaker,if ur speakers does not have switch hten select the volume control optin and click the properties and check the sounds by clicking the speaker images in that window.if u have problem again,askme through fixya again.
Aug 16, 2008 | AOpen MS-810 Computer Speakers
No sound from a sony stereo receiver.
Hi there
Have you checked that the speaker on/off switches have not been bumped also. They are often at the left hand end of the amp next to the power switch and easy to turn on. A Tape monitor switch engaged will also give you those symptoms. Check them out and get back to me here if you cant find the problem
regards
Graeme
Apr 06, 2008 | Audio Players & Recorders
Loss of ram
Does the computer have 2 video ports on it - meaning does it have on-board video and someone added a video card?
If so, once you moved it, you may have hooked it back up to the on-board video port instead of the card. Most on-board video used 32mb of memory, which would explain the memory loss.
I hope this helps.
Jan 10, 2008 | Computers & Internet
Lexmark X3470 All-In-One InkJet Printer Logo
145 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
