Question about Toshiba e-STUDIO 150 All-In-One Laser Printer
Vista on a Toshiba E Studio 150
Will a Toshiba E Studio 150 work with Vista?
    President:
  • 2,692 Answers
Yes.  I found a combined VISTA driver link to a E-Studio 150  Copier/Scanner?
http://www.copiers.toshiba.com/support/controllers/e-studio150.shtml
Posted on Feb 18, 2009
I have a Toshiba e-studio 150 copier. L-1 error code flashing
hi there is problem L-1 means that u have problem CCD MCU Harness Disconnect
May 12, 2010 | Toshiba E-Studio 161 Copier
Toshiba e-studio161 - windows7 64 bit
For Vista there is only a 32-bit driver. I've already tested, it doesn't work
Dec 09, 2009 | Toshiba e-Studio 161 Copier Copier
Can the toshiba e-studio 150 print double sided?
yes you can print double side manualy
first time print your lowaer cassate after print another side is your copier right single sheet pass print side
thank you
Tareq
Jul 31, 2009 | Toshiba e-STUDIO 150 All-In-One Laser...
Toshiba e-studio 150, Problem H4
This is a fuser related error - the fuser is not warming up within a specified time frame. It could be the heater lamp or a thermostat/thermistor that is not working, possibly a bad fan. You can cancel the error code (hopefully the error does not come back) by going into sim mode. press the following keys one after the other "clear" "density select key" "clear" "density select key" then enter 14 and the copy start key. then restart the copier. If error code persists you could remove the fuser unit and look for any foreign matter inside the fuser. dirty thermistor or thermostat can cause this too.
Hope this helps
Apr 05, 2009 | Toshiba E-Studio 161 Copier
Drivers for TOSHIBA e-studio 161 MFP for VISTA 64 Bit O.S.
What kind of interface u're using ? USB cable or network cable?
if USB cable, currently only support until Vista 32bits.
But if running networking, Vista 64bits is supported.
Mar 31, 2009 | Toshiba e-Studio 161 Copier Copier
Problem with Toshiba e-studio 280- need vista 64 bit driver
You update your copier driver for 64 bit windows suppoted.www.toshiba studio 161.com
Mar 11, 2009 | Toshiba e-Studio 161 Copier Copier
Installation of e-studio 350
U need to confirm the driver support Vista 64bit.
U can obtain the driver at:
http://www.copiers.toshiba.com/support/controllers/ebridge350-450.shtml
Jan 19, 2009 | Toshiba e-Studio 350 Copier
Error code L
L signal is scaner lock
please chack your copier left side copy board under lock unlock mark
Thanks
Tareq
Mar 05, 2008 | Toshiba e-STUDIO 150 All-In-One Laser...
Hi you have a fuser problem. The fuser does not heatup normaly. Sometimes it can besolved with the following code. Enter Sim mode. "c" - Auto/text/photo - "c" - Auto/text/photo - 14 -start - 00 - start. To exit sim mode press clear all. Turn the machine off and on, check operation. If that does not work check the Termosters, termostats, and heater lamps and wiring harnes.
Hope it helps
Feb 19, 2008 | Toshiba e-Studio120 Copier
Toshiba e-STUDIO 150 All-In-One Laser Printer Logo
709 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
