Question about Ruud UBHC Air Conditioner
Replacing the fan motor on RUUD model # UHBC-21J14SFC
Will i have to disassemble the entire unit to relace the motor or will i be able to remove it with minimal trouble?
  • 3 Answers
Remove control make sure make diagram where motor wires go on board. some models have 2 screws to pull out entire blower assemebly
Posted on Feb 19, 2009
What is the tonage looking for the tonage
It will usually be in the model number on the unit. You will have to supply the model number and possibly the serial number for us to see. Thanks!
Sep 01, 2014 | Heating & Cooling
What size capacitor does the out door fan motor require on a RUUD Model number UPMC-042JAZ
call your local ruud dealer and have him cross reference model number or look on fan motor itself, if original then cross reference ok, but if it has benn replaced look on the fan itself
Jun 19, 2014 | Ruud Heating & Cooling
Exterior fan motor replacement
i would replace its run capacitor first.
Jul 04, 2013 | Ruud UAMB Air Conditioner
My 4 year old Ruud home a/c compressor stopped working. inside fan blows but compressor won't turn on...what can I do prior to calling the gas company who installed the unit...
Ruud parts warranty from factory is 5 years, the capacitor has possible gone out, it will be in the contol compartment on the out side unit and is a dual run capacitor that controls the compressor and fan motor. Recommend if capacitor is bad to replace entire capacitor. As Stated above the parts are under warranty if under five years old. To verify age the date code is in the serial number after the "F" **** week/year of manufacture. Also outside unit has independent power supply so check fuses if any and circuit breaker.
Aug 21, 2011 | Ruud UBHC Air Conditioner
I have a RUUD central air conditioning system, model NBHC-18J20SFA. The cooling function is not working. The fan on the outdoor unit is not working. When switching to COOL, the compressor works for a few...
sounds like the outdoor fan motor and/or capacitor needs replaced. The compressor will run for a short time because the fan is not pulling the heat out of the system, it can cause damage to the compressor if the fan is not repaired, Ruud used a 3uf capacitor rating for the outdoor fan motor, if the motor has been changed make sure the proper capacitor is also changed for the new motor rating.
Jul 05, 2011 | Ruud UBHC Air Conditioner
My ruud serial number 5427 M1496 07992 Model UAKA-024 Jaz Is not blowing cold air. I started the unit inside the house then went outside to see if the fan is working on the outside unit and it is...
1) Replace both fuses if there are any out by the unit
*also make sure the breakers are not tripped. there will be two
2) if you get the unit running inspect the outdoor coil under the outside fins to see if the coil is stopped up with dirt,grass, etc.
*if the coil is dirty, disconnect the unit from power, take the 4 screws out on the top of the unit that hold the fan motor assembly in place. Carefully set the entire motor, blade and assembly off to the side and be careful not to pull the motor wires loose. With a water hose and sprayer, carefully wash the condenser coil from the inside out. You will see a lot of debris on the outside fins you will have to wash off. Be careful not to have so much water pressure that you bend the aluminum fins on the coil itself.
** many times if the coil is stopped up this will cause the unit to overheat and trip breakers
Apr 13, 2011 | Ruud UAPA024 Air Conditioner
I have a ruud rcha 36a2g heat pump from 2004. What is the seer rating and tonnage of it? Also inscribed uhbc-17jo6nfh
The unit is a 3 ton or around 36,000 BTU
It also is around a 10 SEER could be a abit more depending on the maych up of the coil and airhandler or furnace combination...
Heatman101
Apr 15, 2010 | Ruud Matching Split Air Conditioner
RUUD model URGG-10E31JKR GASS PACK purge fan and main blower
if the purge fan wont start on its own see if there is a capactor attached. if not replace it. more than likely you cannot lube the bearings in your blower motor. the new fans are not serviceable.
Oct 29, 2008 | Ruud Heating & Cooling
I have a Ruud Silhoulette Model #UGPJ-12EARJR Furnace. My Carrier A/C unit comes on but the fan blower motor in the furnace does not.
Could be a bad fan control board or the motor. Need to see if you have power to the motor from the board
Jul 06, 2008 | Ruud Heating & Cooling
Ruud UBHC Air Conditioner Logo
247 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
