Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag Nepturn TL FAV6800 Grey spots/debris on clothing
I first noticed small pieces/specks of a grey substance adhering to the interior stainless steel wash tub after completing a cycle. If I removed them with my fingernail while still moist, they would scrape off easily and had an oily texture when squeezed. If the grey substance was left to dry on the stainless tub, it would harden and I had to scrape and scratch to remove. The next load of whites I washed had these specks on all the clothes. Some I could scrape off while others left a grey mark on the clothing. I cleaned the tub as per manf. instructions and ran another load of whites only to find the grey substance on the clothing again. Has anyone experienced this? Any ideas on the source/cause?
  • Anonymous Mar 27, 2009
    maytag neptune error code uc
  • 335 Answers
Hello davidsonrepl,
I was waiting with someone with more experience to post back on your issue. I haven't experienced this issue it but I would not rule out a transmission seal failure causing your oily grey substance in the wash tub. If you want to investigate further you can get the Service Manual from here
http://www.fixya.com/support/r1655507-found_service_manual_neptune_top_load
take a look at page 38 and on and see if you feel OK with a tear down to the transmission.
Posted on Mar 01, 2009
How to clean maytag stainless steel finish on appliances
HOW TO CLEAN MAYTAG STAINLESS STEEL REFRIGERATOR:
Do not use abrasive or harsh cleaners such as window sprays, scouring cleansers, flammable fluids, cleaning waxes, concentrated detergents, bleaches or cleansers containing petroleum products on plastic parts, interior and door liners, or gaskets. Do not use paper towels, scouring pads, or other harsh cleaning tools.
How do I clean and care my stainless steel surfaces such as refrigerator or any other stainless steel made appliance?
NOTE: Just because a cleaner is a liquid does not mean that it is nonabrasive. Many liquid cleaners designed to be gentle on tile and smooth surfaces still damage stainless steel.
> Avoid Citric acid
-it can discolors stainless steel. To avoid damage to the finish of your stainless steel appliance, do not allow these substances to remain on the steel finish:MUSTARD,TOMATO JUICE,MARINARA SAUCE,CITRUS-BASED SAUCES,CITRUS-BASED PRODUCTS.
If you want to clean safe and keep the sparkling steel you can purchase STAINLESS STEEL WIPES this wipes is ideal for cleaning food spills,grime and stains leaving surfaces shining like new. This wipes is for stainless parts only make it sure this stainless steel wipes to come into contact with any plastic parts.BUT THE SAFEST WAY TO CLEAN STAINLESS STEEL SURFACES IS TAP WATER WITH CLEAN WHITE CLOTH.
Jan 26, 2011 | Maytag Refrigerators
How to remove spots on stainless cause from removeable protective plastic
The best and most inexpensive way to clean stainless steel is to simply dampen a lint free cloth with olive oil and wipe down the stainless steel piece.
Dec 24, 2010 | Maytag Dishwasher
We have a savin 4035sp copier and the automatic document feeder (on top of the machine) doesn't work. We don't have a service contract on it anymore - any suggestions?
Yes that helps. The most common cause of what you describe is a dirty or worn feed roller and belt. What I would suggest you do is get a cloth or very sturdy paper towel and some windex/glass cleaner. Take the cloth and spray an area on it with the glass cleaner. Open the top cover on the document feeder where the documents are fed in. You will see a grey colored roller called the feed tire. You can lift it up almost verticle and clean the tire by rubbing the damp cloth across it's surface. Just rotate it a bit as you clean so you get the whole surface clean all the way around. You may notice that the tire is a bit black and as you clean it, it will turn more grey. This is normal. You may also notice a black spot on your cloth from the dirt coming off the tire. While your there you can do the same for the feed belt which is kind of below the tire. It is like a small belt. Just kind of hold the belt while you clean it and then rotate the same way as the tire. Once done just lay the assembly back down, close the cover and this should solve your feeding issues. If not then you may be due for feed roller, feed belt and separation tire (the more white foam type roller)replacement.
Good Luck and please give me feedback if this works for you.
Thanks,
WheatlandServices
Sep 23, 2010 | Savin 8035e Copier
I am getting black spots (short black or grey lines) on clothing. The spots appear to be random. Maytag Model DE412
You left something in a pocket that melted in the heat and left those spots and lines. You will need to clean the inside of the drum thoroughly. Without knowing the source of the spot and lines, I can't tell you how to remove them without damaging the clothing.
Jim Hart
Jun 14, 2010 | Dryers
Grey spots on our white clothes after wash
do you use affresh to clean your front loader? deposits of soap and other such things can be stuck around the inside tub of your washer. try this porduct out it works great on all front loaders use hot water with the affresh pellet with no clothes and run the machine through a cycle this also helps with any stagnant water smells also have you cleaned out your pump lately. * note remeber to put the pellet on the inside of the machine not in the soap dispenser
Apr 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
2005 Acura TL Turns over - won't start - grey smoke coming out of exhaust when engine turns over
Check for water in your oil. The oil will look like a milky substance kinda white in color. If this is what you see I recommend you take it to a dealership or a certified mechanic and have your head gasket replaced.
Feb 21, 2009 | 2005 Acura TL
Having a problem with a white powdery substance Model 17602
The sump may be full of debris here is how to check it:
ok in the dishwasher you will see you lower spray arm. take it off. now going up the back is the supply tube. you need to pop it off of thed top then the back and turn it clockwise to get it off the motor. after you do that you will see 4 torx screws. take all 4 out and you will be able to remove the fine filter. thats the normally grey piece with all the slots. after you remove the filter you will see two more torx screws. remove them they are for 2 seperate pieces one is the foreigh food seperator and the other is the chopper cover. remove both of them and clean the whole thing out. as yiou are puytting it back together. let me know if you get stuck
Nov 28, 2008 | Kenmore 24 in. 17602 / 17604 / 17609...
Spots of Grey lint left on clothes after washing
Have you cleaned the filter on the front bottom of the machine?
May 11, 2017 | Bosch Washing Machines
A dark residue inside of dryer
Sounds like an ink pen was left in the clothing during wash and leaked out when put in the dryer
Oct 21, 2007 | Maytag HYE3658AY Electric Dryer
Maytag Neptune FAV6800AW Top Load Washer Logo
332 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
