Question about FIC AM 35 Motherboard
I CAN UPGRADE MEMORY IN MOTHERBOARD FIC AM35, TO DDR (2)512M 444MHZ
  • 13,433 Answers
Hey,
Yes, here are the details
Memory Max Supported RAM2 GB Memory TypeDDR SDRAM Supported RAM Speeds100 MHz · 133 MHz Number of Memory Slots2 x 184 Pin DIMMs Let me know if you need anything else. Thanks, Ekse
Posted on Feb 18, 2009
  • Ekse Feb 18, 2009
    The system Supports DDR SDRAM SPEEDS 100- 133MHZ
  • Ekse Feb 18, 2009
    DDR-200
    and
    DDR-266
    are supported, DDR 2 is not supported.
I have a Hp Pavilion 733b with chipset 845g, i have 1gb of ram but just recognise 256mb
Product: HP Pavilion 733b Desktop PC
http://h10025.www1.hp.com/ewfrf/wc/product?product=296502&lc=en&cc=us&dlc=en&lang=en&cc=us
Motherboard: FIC VG31
[ First International Computers ]
Motherboard specifications;
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07722&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=296502
Memory Type: DDR Sdram
Memory Speed: DDR Sdram at 266MegaHertz, or 200MHz
(PC2100, and PC1600, respectively)
Memory Sockets: Two. For Dual Inline Memory Module/s.
Maximum Memory: -> Maximum TOTAL Amount for motherboard.
2GB.
Maximum Amount for EACH ram memory slot: 1GB
So far looks good, BUT;
1) Is the Ram Memory Non-ECC?
http://en.wikipedia.org/wiki/ECC_memory
2) Un-Buffered? (Un-Registered)
http://en.wikipedia.org/wiki/Unbuffered_memory
3) Voltage: Does it use 2.5 Volts?
JEDEC standard for DDR Sdram ram memory voltage is 2.5 Volts (DC)
FIC is going to set the ram memory default voltage at 2.5 Volts.
Point? DDR Sdram at 2.6 Volts, or higher, may not work.
Betting the motherboard doesn't have SPD, and the ram memory may not either.
http://en.wikipedia.org/wiki/Serial_presence_detect
4) Ram Memory frequency rate:
What frequency rate of ram memory are you using?
(Excuse me,...'Speed')
The Intel 82845G Northbridge chip, will only support DDR Sdram at a -> Maximum <- frequency rate, of 266Megahertz. (266MHz),
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_chipsets
I have seen websites offering DDR Sdram at 400MHz for this board.
Maybe there is a BIOS update, I don't know. But going with the standard BIOS program that is installed, and info for the Intel 845G support, I would say this = No.
Processor Front Side Bus (FSB) support is either 400MHz, or 533MHz.
Ram memory typically operates at HALF of the Processor's FSB.
That would be 200MHz (PC1600), or 266MHz (PC2100), respectively.
[Half of 533 = 266.5
It's just rounded down to 266 ]
Can you read a manufacturer's label on the ram memory modules?
If so post what you see in a Comment.
Regards,
joecoolvette
[Sometimes when upgrading ram memory, it may take you to turn the computer completely off, and wait 1 minute. Then turn it on, and let it run for a couple of minutes, then turn it off. Wait 1 minute, turn it back on.
IF, the motherboard does have SPD, and IF, the Ram Memory has SPD, it may take a couple of 'Cold Boots', for BIOS to recognize the Ram Memory.
Some of the old mobo's were just like that.
{MOtherBOard ]
Jul 11, 2012 | Computers & Internet
Motherboard fic am35
Hi Mark
http://www.fic.com.tw/support/motherboard/motherboard.aspx
website / techsupport page for FIC
you will find links for drivers / manuals toward the bottom of the page
Jan 02, 2012 | Compaq Computers & Internet
I had just one memory module on this motherboard which was kingston ddr, 256mb, pc2100. Then i upgraded my mobo with one stick of pc3200 ddr ram, and it keeps restarting and sometimes it just turns off...
PC 3200 is not supported by this motherboard. It will cause problems. You need to use PC2100 RAM.
http://www.motherboards.org/reviews/motherboards/988_2.html
Hope this helps.
Sep 27, 2010 | FIC VC 11 Motherboard
Hello Tech Support, what is the max DDR memory per slot on this motherboard ? Thanks.
It supports up to 2Gb PC2100 DDR memory (you can install PC3200 modules too, but it will run only at 266Mhz.).
If this is the solution for your problem, please rate my post, otherwise give us more details.
Regards,
Andras
Sep 20, 2010 | FIC AM 35 Motherboard
I got intel 845 gl motherboard having ddr 256mb pc3200 ram. there are two slots availble. i want to upgrade
If you want to upgrade your ram, buy the same memory frequency like your current ddr 256 mb pc3200 memory. You can upgrade your memory up to 4GB and be sure they have all the same frequency to avoid system complications.
Dec 19, 2009 | Intel Motherboard
DDR or DDR2
DDR 266 is DDR, not DDR 2 . The 266 is the frequency value in Mhz.
Try having the memory refunded or resell it on Ebay, so that you do not lose your money.
Here is supported memory, many older motherboards do not accept modules of over 512Mb each, ask to the seller:
PC2100 Memory DDR266 DDR-266 184-Pin Upgrade (266MHz) Memory Upgrades
Aug 22, 2009 | Computers & Internet
Memory upgrade, download upgrade to run 400
According to the specs of this motherboard, it only supports 333, 266 and 200 MHz DDR SDRAM. It does not support 400 MHz DDR SDRAM.
This motherboard has only 2 memory slots, each can accommodate a 1 GB memory module. Higher capacity memory modules are not supported by this motherboard.
No BIOS upgrade is available to provide support for 400 MHz DDR SDRAM memory modules.
Jun 04, 2009 | Intel D845GVSR Motherboard
Memory upgrade issue
Most ram has to go in pairs. Buy another stick of the 1GB, and it will run fine.
Jan 23, 2009 | FIC K8-800T Motherboard
RAM upgrate
you can upgrade to a max of 2gb on that board. These are your 1gb options: 1GB PC2700 333MHz DDR Memory, 1GB PC2100 266MHz DDR Memory, and 1GB PC3200 400MHz Non-ECC Unbuffered 184-pin DDR DIMM Memory. Install a set of any of these and your off and running.
Dec 22, 2007 | FIC P4M-800T Motherboard
FIC AM 35 Motherboard Logo
181 people viewed this question
Top FIC Computers & Internet Experts
David
David
John Anderson
John Anderson
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
