Question about i-mate K-jam Smartphone
Bluetooth headset with Imate K-Jam
I have a SonyEricsson headset that pairs with the K-Jam but will only ring once then lock up the K-Jam.
  • 50 Answers
Change ur bluetooth device setting which appears in ur paired device menu ...this will work
Posted on Mar 06, 2009
I need to know the bluetooth pairing code for sanyo M1
Well I know for sure the default pin for the M1 is indeed 0000. However I cannot tell you what the pin would be for your specific bluetooth dongle. If I where you I would try 0000, 1111, 2222 and so on
  • As with all Bluetooth headsets, the H700 needs to be paired with the device before it can be used, which is done in pairing mode. In pairing mode, the H700 makes a transmission so that Bluetooth-enabled devices can pick up the device and connect to the headset. Once connected, no other device can connect with the Bluetooth headset. To enter pairing mode on the H700, open the headset boom located near the microphone. After a few seconds the indicator light will turn purple. Once purple, the H700 is in pairing mode.
Searching for the Device With the M1
  • Once the H700 is in pairing mode, have the M1 search for Bluetooth devices. To do this, press "MENU/OK" and choose "Tools," "Bluetooth," "Add New" and "Search." A list of Bluetooth devices will show up on the screen. Highlight "Motorola H700" and press "MENU/OK." Choose "Add to Trusted," enter "0000" and press "MENU/OK." The devices are now connected and ready to be tested.
Testing the Devices
  • Once the devices are connected, test that both the phone and the headset are working properly together. First, place the headset in your ear. Dial a number on the phone and press "Send." If you can hear ringing, the devices are connected properly and ready for use.
    If the connection was not successful, repeat the previous steps and try again. Make sure the indicator light is glowing purple and is steady. If you have connected the headset to a previous device, make sure that device is turned off so as not to interfere with the connection procedure. Once the other device is off, close and reopen the boom to enter pairing mode.
Feb 16, 2012 | Sanyo Cell Phones
How to operate
"First, turn on Bluetooth and Bluetooth visibility in your phone. This makes your phone visible to other Bluetooth devices.
Headset instructions:
  1. Make sure that the headset is fully charged, turned off and within 1 m (3 ft) of the phone.
  2. Press and hold the On/Off button for at least five seconds, until you hear along high frequent beep and the light flashes red and green.
  3. The headset is now in pairing mode.
  4. If your phone supports auto pairing, press Yes when the question "Add device?" appears in your phone. If not, continue with the next step.
  5. Prepare your phone according to the phone instructions on how to add a Bluetooth device. Please note that for some phones you may need to enter a passcode. The headset passcode is 0000.
Phone instructions (NB: these may differ a little depending on phone model. For exact instructions, see Pairing instructions for the specific headset and phone model on
  1. Enter the main menu and go to Settings, then select the Connectivity tab.
  2. Select Bluetooth > My devices.
  3. When New device appears, press ""Add"".
  4. The phone starts searching for devices. Make sure that the headset is in pairing mode.
  5. When the headset becomes visible in the Devices found menu, highlight it and press ""Select"".
  6. Enter the Passkey (0000 by default) and press ""OK"".
The headset is now added to the list of paired devices and is ready to use."
Mar 26, 2011 | Sony Ericsson HBH-IV840 Bluetooth Headset...
I have my backbeat 903 synced to my ps3 and phone how do i switch to my phone when i leave the house and back to the ps3 when i want to use it in gaming
If you have the BackBeat 903 synced (or paired) to both devices, you should be able to toggle between the two seamlessly. The multipoint technology that Plantronics uses to pair its headsets to two devices at once works on a first ring basis. When you're out and about with your phone, the headset will respond only to it (33' bluetooth range for one thing). When you're paired to and having fun on your PS3, if your phone rings, you make the choice to keep playing or answer the phone. You're always in control, one doesn't override the other.
Good luck from Headsets Direct!
Jan 20, 2011 | Plantronics Backbeat 903 Bluetooth...
Can i pair k750i with HBH610a?
Yes. I have this old trusty combination and it works perfectly with auto-pairing. The phone also supports bluetooth v2.0 which means good sound quality and excellent link reliability.
Check out the instructions here:
Mar 24, 2009 | Sony Ericsson HBH-610a (Auto Pairing)...
Imate jamin song hearing problem
you can not hear any sound as the phone will not allow the bluetooth to play your songs through this devic the only way you can listen to your traks is with the headset for the phone connected
Apr 30, 2008 | Cell Phones
Pairing LG VX8700 with Motorola H700
try to power cycle the cellphone by turning it off and remove battery, then reinstall and turn it back on
For headset pairing
How to pair the phone with a Bluetooth™ headset The phone identifies and maintains up to 16 devices which are displayed in a list. To add a new device or pair a headset via bluetooth, turn Bluetooth™ on in both devices.
  1. Put headset in pairing mode. See Headset User Guide for more information, if needed.
  2. Turn on Bluetooth in your phone, Go to menu, [SETTINGS] > [CONNECTIVITY] > [BLUETOOTH] and press "Select"
  3. Choose [TURN ON] , press "Select"
  4. Choose [MY DEVICES], press "Select"
  5. Choose [NEW DEVICE], press "Select"
  6. Choose the headset to be paired and press ' Select '
  7. Enter the pass key '0000', press "Ok"
Link for headset setting, just choose the headset model
If you are using a different device the just set the Bluetooth to on on it as well
Apr 22, 2008 | Motorola Mobility H700 Headset
Pairing motorola h350 with sony ericsson w580i
All you have to do is-------- hold the call button on the bluetooth (make sure the bluetooth is off at first) hold it untill the light turns on steadily not flashing but steadily. now it is in pairing mode go to the phone turn on bluetooth, and go to handfree. now press add and it will search and hopefully pick it up.
P.S i had the same problem until i tried holding it longer :D
Dec 16, 2007 | Motorola Mobility H350 Wireless Headset
Pairing headset
you need to have the manual for hour jawbone headset and follow those instructions.  You have to put the headset in "pairing mode" and then once you do that (follow headset instructions) it's simple to just go to settings, bluetooth and tell iphone to search for the headset.
Instead of headset issues, we're having car speaker phone issues.  I have the iphone paired with a motorola bluetooth car speaker, and it works when you are making calls.  However when a call comes in, the speaker doesn't pick up, the phone just rings as normal.  That's a problem as you need to be hands free in our state, and if a cop happens to see you, you're in for it
Nov 21, 2007 | Apple iPhone Smartphone
Bluetooth headset hb600 does not pair up to k800i
Hold down the volume buttons on the side till the button on the front turns red. Then try to pair, your phone should find it right away...put in 0000 and push connect on your phone. I just paired it with my iphone.
Apr 21, 2007 | Sony Ericsson Akono HBH-602 Consumer...
i-mate K-jam Smartphone Logo
75 people viewed this question
Top i-mate Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
