Question about Coleman Powermate Powermate 5000W Generator
I have a UST GG5500 Generator practically new will not start
Only has about 30 hours on it, full of gas and oil. Checked plug disconnected low oil sensor wire and nothing. All I can figure is bad Carburetor Assy....but have no idea where to find this part. Called number on manual and the phone just rings...Any suggestions or know where I can order this part.
  • allen kmiecik Dec 27, 2012
    my gg5500 will not start after sitting all summer. I put new gas in it, tried the tilt switch suggestion, sprayed starter fluid in the carb, checked the spark with plug out to find a very weak looking spark any ideas on the weak spark?
    New Friend:
Hi, carburetor can be found at amazon, click here and take a look: Portable Generators from Briggs Stratton. I hope this was helpful. Cheers
Posted on Dec 21, 2014
I had the same problem with this generator. I tried all of the usual suspects: fuel level; fuel valve; oil level; air clearner, spark pluge etc. The problem is a "tilt" saftey shutoff --I was using the generator on a pea gravel patio and it settled about 2" out of level... The tilt switch is not mentioned in the manual and it apparently does not reset itself once the generator is leveled.
To reset the switch, ensure that the generator is on level and stable ground, the find yellow wire that goes from a switch on the front side of the engine crankcase to the bundled wiring harness behind the panel. Disconnect the yellow wire at the in-line quick-connect coupler, which can be found by following the yellow wire from the switch on the crankcase toward the wiring harness. Once disconnected, start the generator as normal. The engine should start right up. Let the engine run for a minute, then kill the engine and reconnect the yellow tilt-switch wire and try to restart. I had to go through the disconnect-start-reconnect process twice before it reset, so if it wont restart after you reconnect the wire, disconnect it agian and let the engine run a few more minutes.
I hope this sovles your problem.
Posted on Mar 05, 2009
  • gunkulator Nov 06, 2011
    The tilt safety shutoff was the problem for me. I had tried everything else: new spark plug, new gas, topped off the oil, air cleaner. I even squirted some gas directly into the cylinder - nothing. Disconnected the yellow wire and it started after only a couple more pulls. You'd think something that important would be in the manual!
My GG5500 sat over the summer and had been used after it was purchased during poer outage, so I knew it worked once. I performed the maintenance when not using for extended period of time. I was getting it ready for use this winter and when I pulled the rope it woulod backfire every couple of pulls, but not on regular intervals. I changed the sparkplug and the gas just for extra measures, but it still would not start and still backfired only. I have a car mechanic buddy that went straight to the cylinder head cover and removed it. He loosened one of the rocker arm bolts reassembled and it fired right up. He made another minor adjustment to the rocker arm bolt and everything was set. This is probably not the problem you are/were having, but I wanted to mention it just in case this happens to anyone in the future.
Posted on Dec 04, 2009
When you look at the generator where all the switches and guages are there is a sheetmetal cover plate remove this plate and under it is all the wiring andcapacitors, there are two capacitors one on the far left and one on the far right. I think the far left capacitor is part of the ignition the one on the right is how the generator makes electricity, Check the capacitor to see if it is good
Posted on Dec 25, 2009
  • 169 Answers
You don't say if you've confirmed that you have spark. Try this:
Remove the air cleaner, make sure the choke is open.
Spray a bit of either carb cleaner, ether, or brake cleaner into the intake.
Make sure the switch is on and pull the rope, If you've got a bad carb you'll hear some sort of attempt to start when the spark plug ignites the stuff you sprayed in, otherwise you've got ignition problems.
Regards,
Carl
Posted on Feb 23, 2009
  • John Pouncy Aug 27, 2011
    I have a coleman powermate 5500. PMO645500. My carb is bad only after 20 hours, cant find a replacement !!!!!! Im totaly frustrated. Can anyone help us !
If the tilt switch solution doesn't help (and I hope it does!), there are carbs available for this engine. First, however, try directly priming the engine with gasoline. (Remove the spark plug and use something to get a small amount of fuel into the cylinder.) Replace spark plug and try to start. If it fires and runs only a couple of seconds, it's burning the gas that you put in the cylinder and that's all. None is coming in through the carb. If it doesn't start, it's more likely an electrical problem (which could be a sensor grounding the system, as with a tilt switch would do).
If you need a carb, run a Google search on "UST GG500 carb" and you'll find a place that sells them for $24.
BTW, I've always gotten ahold of them and they've been somewhat helpful. 866-797-2738. M-F, 0700-1530 PST.
Sam
Posted on May 11, 2009
  • tphilip60
    tphilip60 Nov 03, 2012
    where did u find it for $24??
    New Friend:
Mine did the same, exact thing. I used it once and would not start. For whatever reason, the thing has been working fine for 4 years now - but I have to pop the plastic cover off the carb area and prime the thing (I use a little syringe to shoot gas in horizontally) every time it needs to be started (unless it's hot). if I don't prime it, it will not start - period. But it's been very reliable, otherwise.
Posted on Jul 09, 2016
    New Friend:
Yellow wire. Thanks for the tip.
Tried placing spark plug with wire onto a screwdriver, it sparked. Tried fule in spark plug hole. It went ? 10 seconds. Wont stay running. Dont have a hard copy manual. An didnt know of yellow wire, so I will try that before I decide to take it to a shop. Got it second, first guy ran it one day for power, couldnt pull the cord sold it to me an an ive tried most things I could think of myself. Only got 15 seconds once few months back. Ive struggled, an it has to be minor. Its hardly ever ran an not been full of fuel going bad, everything seems in order. Attempt to get back to report on yellow wire later thanks again
Posted on Aug 03, 2015
I am completely stumped....Pressure Washer will not start I feel like I have tried everything. Please help
buy a new carburator on ebay for 20.00,the diaghram and all the rubber hoses are shot,that is what ethanol does,eiher try a rebuild kit or wait 2 days for a new one
May 07, 2015 | Cars & Trucks
Tip
Riding Mowers When fuel solenoids go bad causing fuel to drain in engine
hello sir, check to see if the engine is over full on oil and gas in the engine .this will make starter drag eventually ruining starter.this is the only thing i can think of other than engine having high compression or valves not opening and the pressure relief valve not working,or engine low on oil SAE 30 WT for summer, SAE5W30 for winter, is also important to keep good oil in engine and full. the solenoids under the carburetor will go bad,and cause flooding, if you have one. make sure you keep battery charged. if it is bad follow these directions ,well it is a simple fix,but a lot to correct problem, parts needed,1 new spark plug,1 new solenoid,1 quart of 30wt oil,1 pan to catch old oil in. tools needed,1 spark plug wrench,1,7/16 or 1/2 or 9/16 open wrench,pen&paper. ok, empty fuel tank or clamp off fuel line,make a drawing as how the wires are connected to the solenoid,white & black wires,unplug wire fittings,remove solenoid, in stall new solenoid,plug wires in. now drain oil & gas out of engine,remove old spark plug,important so follow directions,after oil is drained plug is out crank engine so to clean out cylinder of excess oil & gas,it would be a good ideal to let oil drain for a while. add oil & spark plug,engine will smoke for a while but should clear up.when you go to the parts store you will need engine horse power,engine brand,model number,type number,parts should cost around 50.00. including everything you need,check oil often you can put a inline fuel shutoff in the fuel line about $5.00, or replace solenoids for $40.00.hope this helps,DON'T FORGET THE 4 THUMBS UP,, up,any comments welcome,thank you.
on Mar 12, 2010 | Garden
Dewalt
was it stored .if so clean the carburetor.may also have a faulty low level sensor or diode box
.try disconnecting the black wire from ignition coil if it starts find the short to ground
Aug 07, 2014 | Garden
Troy Bilt self propelled lawmower won't stay on. It's been fine this year, today all I did was add gas and added the mulch shoot. I turned it on, it was fine. Started mowing, got halfway across...
The trouble you are experiencing could result from several different things. First, check the oil when the engine is cold and completely settled in the sump. You do not want to overfill the engine with oil. If the oil is on the full line (not above it),then the low oil sensor is not shutting off your engine. The oil level should be exactly on the full line-not above or below. Second, remove the spark plug and clean it with a small wire brush or sandpaper. If you are unsure about how to clean the spark plug, replace it with a new one. If both of these procedures have been performed and the mower still doesn't run correctly, the problem is almost certainly with the fuel supply, fuel quality and/or carburetor.
Jul 30, 2017 | Troy Bilt 5.5hp Self Propelled Mower
Did a tune up, new plugs, wires, pcv valve and oil change. I wa gettimg almost 400 miles to a tank of gas, now after I did tune up I am lucky to get 280 miles to my full tank of gas. Not sure why, thinking...
Maybe you should do it next time!! Could be a crossed wire, but it would run really bad and might backfire as well. Wrong plugs? Accidently disconnected or broke a vacuum line or fitting. Wrong oil? Oil and/or additives that are higher in viscosity than specified, will reduce mileage, period. Have the oxygen sensors checked. They can gas mileage to suffer as well....maybe one got bumped or something.
Aug 24, 2011 | Toyota Corolla Cars & Trucks
My machine runs for a few minutes and then abruptly quits. It sounds like it's running out of gas, but it isn't. It has plenty of gas. I'm not a mechanic and don't have a clue what's...
Yes it could be the gas cap. Check the cap and see if there is a vent hole. Use air compressor and blow out the cap. If this is not working check the oil level, if your machine is equipped with a low oil sensor and your oil is low it will shut it down. If you look on the side of the engine block towards the bottom you will see a plastic housing with a wire coming off, this will be the oil sensor. Remove the wire and see if it will run, but make sure you check the oil before running if it's low add the proper oil check your owners manual. If the oil was low don't remove the wire try to run it. If it still won't run then remove wire and try because the sensor could be bad. It also could be a carburetor problem. If you try the steps above and it still won't run remove the carburetor and clean. Let me know how you make out.
Jul 26, 2011 | Honda Garden
Wont start only used one time warranty is out changed spark plug /plug is firing can lay on side of engine and arcs at gap/took off muffler its clean tried to crank with out it on no luck/disconnected off...
I would recommend looking at the exhaust side of the piston and checking it for scoring. This unit is meant for no more than 50-75 hours of use. My guess is that you did not use it one time for 75 hours straight so I would recommend a new carburetor and fuel lines.
To check this you can modify an irwin clamp with a nipple to pressurize the inside of the carburetor.barterjoe_0.jpg If air leaks out of the check valves in the brass fittings of the metering chamber they need to be cleaned In a jewelry cleaner or just replaced as a whole carburetor. $30-40 for the cleaner vs $40-50 for a new carburetor and lines. barterjoe_1.jpg
call a local shop like www.arcolawn.com to get details about the special tools to test carburetors or to get carburetor parts. They may even be willing to clean your carburetor if you ship it to them. Good luck Joe
Feb 14, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Engine won't stay running
check the fuses which are under the seat
Also it will not run unless the parking brake is set when your not setting on the seat
May 02, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Have a colemene powermate that will not stay started
bad fuel? or varnished inside of carburetor needs to be removed all ports and jets thoroughly cleaned out should solve your problem
Jan 08, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Powermate 5000W Generator Logo
8,009 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
