Question about Welding Tools
At take off my miata moves slow
Car take off slow but picks up speed after a while
    Scholar:
  • 81 Answers
You dont say if the car is a standard or automatic but betting it is a standard or manual shift I would say the clutch is either out of adjustment or worn out causing it to slip at startup or this will happen going up a hill in high gear also, the only solution is get it adjusted or if its worn out replace it, and take care when replacing it you replace the pilot bearing, clutch, Pressure plat, and throw out bearing. Also check the flywheel for cracking or scorching, or roughness and get it resurfaced if any of these conditions sre found. Hope This Helps Don
Posted on Dec 07, 2009
Wont pick up speed
in limp mode check for codes
Mar 02, 2015 | 2003 GMC Envoy
Why does my truck move slow in the morning and when sit for a time and then picks up speed after. Then idle jumps around at1500 rpms up and down then it settles.
Does the engine rev up when you press on the gas or bog down?
Do you smell a funny smell when the truck is running?
Sep 18, 2014 | 2000 Chevrolet S-10
Acura intergra Stickshit picks up speed slowly.
sounds like a worn clutch, when you are taking off is the engine reving up and the car is moving slow on take offs? if so then the clutch is worn out and needs replacing.
Jun 29, 2013 | 1993 Acura Integra Hatchback
Slow in picking speed from gear 1
Slipping clutch disc.you need a complete transmission job
Nov 18, 2017 | 2001 Mitsubishi Lancer Cedia
I have a 97 miata w/ 5 speed. When I push in the
Yes you most likely have a bad throw out bearing. If you replace the bearing you would do yourself a favor and replace the clutch and pressure plate while you are there.
Oct 07, 2009 | 1997 Mazda MX-5 Miata
Miata steering feel
Some cars have progressive power steering, light at slow speeds for parking etc. But at speed a heavier feel so you can feel what the grip is like on the front tyres when driven hard. But check the power steering fluid level as well, the pump could be leaking.
Sep 02, 2009 | 1991 Mazda MX-5
Lack of power when climbing hills and slow to pick up speed
It sounds like your vehicle needs a major tune-up. Try putting in some fuel injector cleaner gas additive and a new air intake filter.
May 18, 2009 | 1994 Toyota Camry
Power steering problem when moving slow or rpm drop
no it is the power steering pump. the pump is worn so at low rpm or low speeds it is real tough to steer. but when the rpm is picked up the steering gets easier.
Also check belt tension but at high rpm speeds the belt would slip and squel real loud. so i would point the problem to the power steering pump.
hope this fixs ya!!!!!!!!!!!!!!!!!!!!!!
Feb 18, 2009 | 1995 Saab 900
Moves very slow backing up, and it takes awhile to pick up speed
automatic or standard? if its an automatic check the fluid level if it is a standard the clutch may be worn out
Jul 19, 2008 | 1996 Mercedes-Benz C-Class
Welding Tools Logo
117 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
