Question about XFX NVIDIA GeForce FX5200 Graphic Card
I have a Dell Dimensions 8300 with a GeForce FX5200 graphics card (version C.14.10.4502).It has D-Sub and DV1 outputs. The monitor is connected to the D-Sub output. However anything connected to the DV1 output will not work. Is it disabled in some way (mechanically or electronically)? Please help.
  • a_ndownes Feb 23, 2009
    Thanks for the solution IT WORKED.
    Is it possible to have the same information on both screens at the same time?
    ie. the same internet info could be seen in different rooms at the same time.
  • a_ndownes Mar 04, 2009
    Thanks to Ekse - How do I get to the Nvidia Control Panel?
    Nigel.
  • 13,433 Answers
Hey,
in windows, right click on your desktop, select properties, then settings and then click on the 2nd monitor, make sure the 2nd monitor is attached to the dvi, when the computer was turned on. so the 2nd monitor will appear in the settings.
this will give image from the dvi output. to get objects to the 2nd monitor drag them out of a corner of the first screen. debending on what side the monitor is at.
Let me know if you need anything elsed.
Thanks,
Ekse
Posted on Feb 18, 2009
  • Ekse Feb 23, 2009
    From Nvidia control panel go to the same properties page, then to advanced. from there nvidia control panel.
    it will probably look diffrent on your computer but basicly, set it to clone to have same image on both screens.
    Let me know if you need anything else.
    Thanks,
    Ekse
  • Ekse Mar 04, 2009
    Hey, go to the display properties as in the first picture, then click on advanced, and find the nvidia panel from there.
    if you get the problem solved I'd love a fixya rating. Thanks again,
    Ekse
+I have a dell 4600, it came with a geforce fx5200 graphic card, i need a vga and a hdmi coneection, my monitor is vga and i want to hook up a tv monitor with hdmi
Dear civetscat,
Hello and welcome to FixYa!
I have research these converters/adapters before that can convert from the DVI port on the video card to an HDMI source. They are very exspensive for the type that truely work, and the cheap ones provide terrible graphics. Your best bet, is to research both the adapter and a replacement video card for your PC that will have the HDMI and VGA outputs you seek.
I have provided links to both below, from a site call newegg.com
Adapter/Converter: http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=DVI+to+HDMI+converter
Replacement video card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814161308
Happy hunting and have a great day!
Sep 01, 2011 | Nvidia GeForce FX 5200 Video Card Graphic
I am looking for the tv outlet on the geforce 5200
It is the s-video output in between the DVI and analog outputs.
Dec 19, 2010 | XFX NVIDIA GeForce FX5200 Graphic Card
Driver MSI FX5200-TD128LF GeForce FX 520
You can download the latest FX5200 drivers from nVidia Website.
Select
Geforce-
Oct 06, 2010 | MSI FX5200-TD128LF GeForce FX 5200, (128...
I have a Dell Vostro 400 and two video cards. Only one card will work and it is an Nvidia GeForce FX 5200.The other one is an ATI Radeon HD 2400 PRO. These are the specs from the two graphics cards:...
you cant join two different platform vga cards. simply because they have their own platform and have separate drivers, so they conflict each other thus causing one of them shut off or disable..
Jun 01, 2010 | XFX NVIDIA GeForce FX5200 Graphic Card
Dell s2209w with a GeForce fx5200 blinks black
Make sure your refresh rate is not set too high. for the 192N it should probably be not much higher than 60Hertz
Jul 31, 2009 | XFX GeForce FX 5200, Graphic Card
Monitor going to power save mode and freezing
Hi, i have had that problem before and its wasn't the graphics card drivers, it was loose, anyway for you case go to device manager and uninstall the graphics drivers from there then restart and install then manual by updating and locate the exact location from the cd or any other location that has them.
That should help
Cheers
Apr 27, 2009 | XFX NVIDIA GeForce FX5200 Graphic Card
Multiple monitors with 2 Graphics cards
dude you got to use sli or cros fire but if just 1 monitor
Jan 23, 2009 | XFX NVIDIA GeForce FX5200 Graphic Card
Blank Monitor
hey maby the onboard van on it dont work well with yoru pci slow ok so unplug the onbord fan try again ok
Jan 21, 2008 | PNY Verto GeForce FX 5200, Graphic Card
Proplem in Gigabyte GeForce FX5200, AGP Graphic Card in vista
Not quiet sure what you mean? The fx5200 will run vista and is aero capable as its the 1st dx9 card but it may struggle a bit. Could you clarify what you want to know? :)
Dec 29, 2007 | Gigabyte GeForce FX5200, (128 MB) AGP...
Dvi port not workink
Change monitor input on nvidia control panel and /or change the input on the onscreen display. mine uses the same thing
Dec 27, 2007 | MSI FX5200-TD128LF GeForce FX 5200, (128...
XFX NVIDIA GeForce FX5200 Graphic Card Logo
161 people viewed this question
Top XFX Computers & Internet Experts
David
David
Alun Cox
marley mcelhinney
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
