Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
HOW DO A SEND A FAX FROM MY ESP 3 AIO?
I DON'T SEE ANY INFO ON SENDING FAXES ANYWHERE?
It's a Printer/Scanner/Copier. Nothing about faxes.
The ESP3 does not have fax capabilities.
You would have to go three models up (5,7,9) to the ESP 9 to get fax capability.
Posted on Feb 22, 2009
Does lexmark x6575 send international faxes
Hi:
Any fax is capable of sending international faxes. You just need to make sure you have the correct dialing info, like the country and city codes which depends on where your dialing to.
Andrew
May 23, 2012 | Lexmark Office Equipment & Supplies
Lexmark Productivity Suite --the faxes don't go through -- error message
Are you able to send faxes when using the printer operator panel - not through Lexmark Productivity Suite application on your computer? Are you able to receive faxes without any problems? Make sure the fax line where the printer is connected is working properly. It could be a signal quality in the connection.
You can also try to decrease the transmission speed when sending faxes. On your printer operator panel:
  1. Press the Fax button, then press Options 15 times to get to ADVANCED FAX.
  2. Press Select.
  3. Press Options ten times until MAX SEND SPEED appears on the LCD display.
  4. Change it to 9600 BPS using the - (left arrow) button.
  5. Press Select.
Try to send your fax again.
Source: Problems Sending a Fax to Specific Fax Machines
Jun 23, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I can recieve faxes but i cant send any
These articles in the Lexmark website will help you identify and fix your problem with sending faxes using your Lexmark X4270: Problems Sending a Fax to Specific Fax Machines and Main Contributing Factors to a Fax Send Failure on an Inkjet All-In-One (AIO).
I hope these information has been helpful.
Apr 14, 2011 | Lexmark X4270 All-In-One InkJet Printer
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
I wanna send a fax
Sending Faxes.
* Flow of Sending Faxes.
The operation flow of sending faxes is as follows.
Step 1:
Load the original to send on the Platen Glass or the ADF.
Step 2 :
Adjust the fax quality and scan contrast.
Step 3 :
Dial the receipent' s number.
Step 4 :
Send Faxes
- Using the Platen Glass
1) Press the Color or Black button.
If you have two or more pages of the original, load the next page on the Platen Glass and press the Color or Black button
2) After scanning all the pages of the original, press the OK button to send the fax.
- Using ADF
The fax is sent automatically.
* Before sending Faxes
- Adjusting the Scan Contrast or the Image Quality (Fax Resolution)
** Adjusting the Scan Contrast
Contrast is the degree of difference between light and dark. Increasing the scan contrast setting further blackens dark areas and whitens bright areas, whereas decreasing the contrast setting reduces the difference between bright and dark areas. You can adjust the contrast among the 3 contrast levels.
1) Press the FAX button, then press the FAX Quality button.
2) Press right or left arrow ot select the contrast.
Pressing the left arrow button decreases the contrast, and pressing the right arrow button increases the contrast.
3) Press the OK button.
** Adjusting the Image Quality (Fax Resolution)
You can adjust the image quality (fax resolution) of the document you send. The higher you set the image quality setting, the better the output quality will be at the other end, but the longer it will take for the transmission. Adjust the image quality according to the type of document you are sending.
1) PRess the FAX button, then press the FAX Quality button two times.
2) Press the right and left arrow keys to select the resolution.
FAX RESOLUTION - STANDARD
Standard : Suitable for text-only documents.
FINE : Suitable for fine-print documents.
PHOTO : Suitable for photographs.
*Sending Faxes - There are 4 methods for sending functions
a) Memory sending
b) Manual sending
c) Dialing the coded speed dial
d) Redial
a) Memory sending
1) Prepare for faxing
a) Turn on the machine,
b) Load the original on the Platen Glass or the ADF.
Note : You cannot scan double-sided documents from the ADF.
c) Press the FAX bitton.
d) Adjust fax settings as necessary.
2) Start faxing.
a) Dial the receipient's number using the Numeric buttons or coded speed dialing.
b) Press the Color button for color sending, or the Black button for black and white sending. I
c) When the following message is displayed, lad the next page on the PLaten Glass.
Scan Next -> Start
Transmit-> OK
If only one document go to step f).
d) Press the same button as you pressed in step b).
e) Repeat step c) and d) to scan in all pages of the document.
f) Press the OK button.
Manual Sending
1) Connect a telephone to the machine.
2) Prepare for faxing.
a) Turn on the machine.
b) Load the original in the ADF,
c) Press the FAX button.
d) Adjust the fax settings as necessary.
3) Lift the handset of the telephone connected to the machine.
4) Dial the receipient's number on the telephone.
5) Talk through the handset to the recipient.
If you hear a high-pitched signal instead of the recipient's voice, go to step g),
6) Ask the recipient to set recipient's fax machine to receive faxes.
7) When you hear a high-pitched signal, press the Color button for sending color sending, or the Black button for black & white sending. Then hang up the handset.
Dialling The Coded Speed Dial
1) Prepare for faxing.
2) Press the Coded Dial button.
3) Press the Numeric buttons to enter the two-digit code (00-19) assigned to the number you want to dial.
4) Press the Color button for color sending, or the Black button for black & white sending.
Hope this helps. Please rate my response.
Thanks
Have a good day.
Nov 27, 2009 | Canon PIXMA MX310 All-In-One Printer
Just wondering on how to set up so u can get faxes from all area codes not just one
You will automatically receive faxes from anyone with a compatible fax anywhere in the world. You may be confusing receiving as you had to enter your area code in setup to send faxes. That does not keep you from receiving (or sending) anywhere you like.
Aug 11, 2009 | Lexmark X5495 All-in-One &USB...
01.12.2008 i fax to one number. now i want aknowledgement of that fax. its gone or not. How i can find on HP Officejet 5610 all in One System?
You can get the manual here if you do not have one - LINK.
Here is an exert form the manual on this:
Print fax confirmation reports
1. Press Setup.
2. Press 2, and then press 1.
Send &
Receive
receive.
Dec 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Cannot send fax
Fax machines are ANALOG devices and will not reliably work on digital phone lines.
Jul 03, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
My model Kodak 5500 printer/fax
Just found your post and I'm having the same problem. Everything else seems to be working correctly. I can copy, scan, print and I THINK I can send a fax correctly, I should have called the person and made sure it arrived. However, I cannot receive faxes. I have an answering machine on the line, but it is not plugged into the Kodak Pinter, it is in another room. The answering machine answered the call, the FAX noise came across, but the Kodak Printer never picked it up and printed out the fax. I think I have all the settings correct, but the instructions are not very clear. Do you think I HAVE to have the answering machine plugged into the Kodak Printer? That doesn't make sense, but I might try it.
Feb 02, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Lexmark X73
Sending a fax by DSL requires one of two methods: 1. You obtain a DSL line filter suitable for connecting a standard voice telephone to the DSL line, then connect an analog fax modem to the line through the line filter. 2. You hire an Internet E-faxing service. See · http://www.slipstick.com/addins/services/fax.htm#internetfax · http://www.slipstick.com/addins/services/fax.htm · http://www.savetz.com/fax Tim
Jan 30, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
98 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
