Question about Epson Stylus C46 InkJet Printer
EpsonC46 How can I do if my printer are flashing both keys?
  • Epson Master
  • 541 Answers
This means your printer wast pad is full this can be reset without puting new pads in but ink may come out you google scc download the software and this will reset your printer
Posted on Feb 19, 2009
Table mismatch error ibm 6400
Occasionally you willneed to reload the flash memory in the printer. To do this you will need a PCor laptop, a parallel or serial cable, and the correct flash code file. Thepart number for the flash code file can be found on the configuration printout.If the printer is not functioning and a current copy of the configurationprintout is unavailable you will need to gather some information to enable usto get the correct code for you.
In order to determine the correct flash code for the printer you will need toknow if the printer has any additional interfaces, the part number of thesecurity pal, the model of the printer, the amount of flash memory and draminstalled, and if the customer uses PGL, VGL, or IPDS graphics.
Once you have the correct flash code file you will need to copy it onto thehard drive of the PC you will be using to flash the printer.
Connect your data cable (parallel or serial) from the pc to the printer
On the printer, hold down the Start & Cancel keys while powering on theprinter. Continue to hold both keys down for 5 seconds and then release them.
The default download mode is parallel (Centronics). This is the easiest port toflash the printer through. If you need to change the download port to serial,see the note at the end of this article.
At this point the display should read "Waiting for Program Download".
On the pc, open a Dos window. At the command prompt, change directories to thedirectory in which you stored the flash code file.
At the command prompt type:
filename.exe -pb
where "filename.exe" is the name of the flash code file you areusing.
While the file is being copied into the printers memory the display will showyou the load process and status.
Do NOT interrupt the load process as this can damage the memory and controllerboard.
When the program has finished loading the printer will reset itself.
If after resetting itself the printer displays a Par error, table mismatcherror, or hangs on initialization reload the code again.
Once the code has successfully loaded and the printer has reset itself, poweroff the printer.
Disconnect your cables and reconnect the customers cables.
On certain 475 and 500 lpm models you will need to set the shuttle speed.
On 1400 and 1500 lpm models you will need to set the coil temperature.
On all models you will need to run a test print and adjust the hammer phasing.
NOTE: If you need to flash the printer through the serial port you will needto follow these additional steps.
When you see "Waiting for Program Download" on the LCD press theScroll Up key. The display will now show "Select DownloadPort=Dataproducts".
Press the Scroll Up key to cycle through the available download ports.
When the display shows the download port you would like to use, press the enterkey.
The display should now show "Waiting Download/Port=" and the port youhave selected.
At the Dos prompt type:
MODE COM1:9600,N,8,1,P
filename.exe -pbc1
Continue with the flash download procedure.
Nov 16, 2010 | IBM 6400 Matrix Printer
All the lights are flashing and it says to Reset power. I disconnect the power cord and reconnect. The system looks like it is resetting and then the same flashing lights appear and it again says to Reset...
Hi Joe,
Lets try 2 steps:
1st approach:
1. With the printer “ON” unplug the power cord form the printer.
2. With the printer now unplugged, press and hold “# and 6′ keys in the printer..
3. While still holding these keys down, plug the power cord back.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
2nd approach:
1. Unplug the power cord
2. Wait for 30 seconds.
3. Plug the power cable back in the printer and turn it on.
(repeat 3 times)
If none of these to approaches work, I’m afraid the failure is “fatal” as the main circuit board might be fried L
Nov 25, 2009 | HP Officejet 6310 All-In-One InkJet...
Printer flashes "Clean Unable 46 - refer to troubleshooting and routine maintenance in User's Guide". I went to the user's guide and did all the maintenance/cleaning that was reccommended. Nothing cha
Try resetting the purge counter:
1) Enter machine maintenance mode (on MFC240C all fourphoto/copy/fax/scan lights flash in maintenance mode). Care is neededin maintenance mode, otherwise critical settings may be inadvertentlycorrupted.
FAX models with numerical keypads:Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if youfail to complete the correct key sequence within two seconds, press theStop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys.Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenancemode to call up the machine’s log information list (function code 80).
3) Press the Black Start key several times to scroll through the loginformation list to reach the purge counter. The purge counter is the25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Jun 02, 2009 | Brother MFC-3360C All-In-One InkJet...
Error code: H 4 flashes.. Nothing works
Oct 23, 2008 | Sharp Office Equipment & Supplies
Check printer & alarm flashing.I cannot get it to reset.
Electric connection terminals scratched? Maybe short circuit. Use warranty from purchase for repair.
Sep 29, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Not printing the correct text / picture
your in line mode instead of page mode.
  1. Turn printer power off.
  2. Press and hold the feed key, then turn power back on.
  3. When light starts to flash, release finger from feed key.
  4. When light starts to flash again, press and hold the feed key until the light turns red (or amber), then release finger from feed key.
  5. Wait for light to turn solid and press feed key once.
  6. Check to make sure you are in the correct printer mode by printing a configuration label (Click here for configuration label example - Note item C).
Jun 23, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Tally 2250
switch off the printer then hold 1,2,3,4 key of the printer and switch on the printer dont lose those key the printer will show difault is loading. when the printer will go to the online then leave those key.
Aug 18, 2007 | Tally T2250 Matrix Printer
Blk 0 chksum error
fault "blk 0 chksum error" is attributable to a corrupt firmware. Fortunately the firmware can be reloaded and restore the printer in operating condition. You can download a firmware from the site under support and drivers then download it in your PC. Normally you need to put the printer is flash download mode also instruction can be seen from the site. If you cannot do this I can assist you with this.
Jul 27, 2007 | Tally Line Matrix T6100 Printer
Epson Stylus C46 InkJet Printer Logo
32 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
