Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My poulan chain saw will not start 42cc 14"bar.
  • 2,176 Answers
K, I just looked at their site for another reason but they indicate that you need to make sure of the fuel, the on/off switch and also the spark plug (which I have personally seen) and dirty or clogged fuel lines. If you need to view the manual for the troubleshooting you can go to Poulanpro.com or call 1-800-554-6723. Good luck and let me know if you need more help
Posted on Feb 18, 2009
Your fuel cap isn't venting properly. The tiny sintered bronze pellet cast into the center of the fuel cap is plugged, allow a vacuum to form in the tank as the engine runs, finally starving the engine. That's why you hear the hiss of in-rushing air when you open the fuel cap. The pellet is too small and quite useless.
Remove and completely disassemble the fuel cap, including the rubber breather nipple retainer. From the outside of the cap, drill through or punch out the breather pellet. Assemble the cap and install.
Posted on Aug 17, 2009
Poulan Pro 42cc 2-Cycle 18'' Gas Chain Saw excess oil on chain
are you using a chain bar oil as this is a lot thicker than normal engine oil
Jul 16, 2012 | Poulan PP4218AV 18" Chain Saw
Purchased like new PP4218 from local, bought for his son, after one tree, son lost interest. No manual with saw. What chain and bar do I buy as replacements? He replaced chain, not sure it is correct...
it's an 18 " poulan bar and chain...just a standard bar and chain for poulan...most of the aftermarket brands have a cross reference that will give you an idea on which to use
Jan 23, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How to put the chain back on a 14" Poulan electric chain saw
Remove the cover that cover the rear of the chain bar.Now,loosen the nuts that attach the bar and slide the bar reward.Now set the chain in the slotted part of the bar,pull it forward until there is abut 3/8 of an inch slack in the chain an tighten the nuts.Re-install the cover.
Sep 12, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Where can i find a service center to purhase a chain adjusting assembly for a poulan 2055 chain saw in the tampa area
Poulan Service Locater
http://www.poulan.com/node6604.aspx
An example of an IPL for a "2055 Gas Chain Saw Type 7" follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2055-Gas-Chain-Saw-Type-7/75.2055-Gas-Chain-Saw-Type-7.1.59.1.html
See the "Handle, Bar and Chassis Assembly" print, item 29, $2.53
If not your saw, yours can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type. HTH
Lou
Feb 24, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Yes i cracked the oil housing for my poulan pp4218avx 42cc chain saw and I was wondering if they sale a replacement housing to repair the saw.
A Poulan PP4218AVX Gas Saw link follows:
http://www.ordertree.com/modelinfo/PWE/PP4218AVX-Gas-Saw/75.PP4218AVX-Gas-Saw.1.59.1.html
See the "Handle, Chassis and Bar Assembly" print, item 38. Is this what is broken? If yes it is possible to replace it, it is not terribly expensive, it is a great deal of precision work. I hope you already removed the clutch (left handed thread). I would probably keep this for parts and purchase a PP4218AVHD Gas Saw Type 2 as a replacement. HTH
Lou
Feb 23, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 2 cycle gas chainsaw 18 inch. Was real
no bar oil should just hurt your chain and bar. remove them and try to start saw. if it still won't start you have other problems you may have to buy a new bar and chain
Feb 02, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chain moves while idle
Hello there. Regarding the bar oil, many loggers plan their work so that they are out of bar oil at the same time that they quit for the day because bar oil has a tendency to leak. Another method that has some success is to mix your bar oil with a heavier oil but the trade off might be less lube getting to the chain when you need it.
Regarding the chain moving in idle, this is another common problem. You can usually slow the idle down until the chain stops, as you indicated, but I too have had chain saws where I finally just decided to live with it and be extra attentive to what was going on.
Jun 11, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan PP4218AUX will not start
I have a 42 cc 14"bar will not start. poulan chain saw.
Feb 18, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
758 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
