Hi Elizabeth, yes you can certainly replace a fan on the external case of your tape drive.
These are not available from HP but if you go to www.tape-drive-repair.com , they can usually help with replacement external chassis for your unit or supply a fan for you.
You can also try removing the fan yourself and searching for the correct fan using the fan details. These can often be bought from RS components / CPC Tandy etc but you will need to get the right size (using the centre of the mounting holes) as well as the right thickness of fan. you might also need to make sure you get the right voltage and the correct number of outputs from the fan (some require a tacho wire)
Certainly this fan is required as the tape drives can get quite hot when they are working and should they get too hot (a common issue) then they will become unreliable.
