Question about Samsung SyncMaster 240 T 24.1" Flat Panel LCD Monitor
I got problems..
Okay, Its a lenova 3000 c200. I looked in the trouble shoot booklet. No help showing. I've also searched around google, No help showing There is no menu button or buttons directly on the monitor part of laptop.
TO THE MEAT!! I woke up this morning turned on my laptop and Its all off center. down and to the right (looking at it) It was never that way before OR last night when I shut it off.
This start at my login page ..including my backround photo and any screens that open up. HELP I fiddled with resolutions ...and I just thought of one more thing ...BUT STILL HELP ME......
Now ,,,,Since im here...
Awhile back I had loaded an RangePlus wireless Network Adaptor Model wpc100 in this laptop. I then removed it.
I then when to put it back in ...I not paying attention put the card in before the Load C.D...(it says not to do that) Now the program downloads but it wont read the card so It dont work..
Did I fry the driver port or the card or what???? Help!!!
Can I Say HELP!!! again
SOURCE: problem with samtron 56v 15" monitor
IT IS REULATION COMPLIANT PLEASE CHANGE THE 7805REGULATOR IC NEAR THE MEMORY IC
Posted on May 12, 2007
SOURCE: Sasung 913n monitor
Same here. The unplug/inplug of the monitor seems to be the workaround. For now, I boot up Windows with the 913 unplugged and connect it after a couple of minutes when Windows has booted up. As mentioned before, this bug only happened to me after shifting to a PCIe card, Nvidia 6600 LE driver.
Posted on Dec 31, 2007
  • 19 Answers
SOURCE: Is my monitor dead?
Dear
The problem is main board inside monitor which is needed to be changed with new one. So I suggest you to take monitor in nearest samsung's service center.
Best regards
Posted on Jan 16, 2008
SOURCE: Screen goes blank when I move the mouse
Did it work properly using a VGA (analog) cable? If so, check your DVI (digital) cable against the pictures at the bottom of http://www.datapro.net/techinfo/dvi_info.html.
You probably have one of the two at the left. Each has a different bandwidth, translating to a maximum resolution. The native resolution for your monitor might be marginal if you have a single-link DVI-D cable.
My 204B seems very picky about signal-level. It blinks when connected by DVI, even though it should be fine with a single-link cable, and complains about the settings even though the settings are optimal. Maybe yours is similar. I have ordered a dual-link cable and will try that myself.
Posted on Mar 10, 2008
tantong
  • 138 Answers
SOURCE: Samsung Syncmaster 940n - white screen
I don't think the driver is a problem. This is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 26, 2008
My screen is off center...Posted as help
I don't have an answer, but I have what sounds like the exact same problem...
Feb 18, 2009 | Lenovo 3000 C200 Notebook
Help!!!
restart laptop in safe mode holding down the 'f8' key as soon as the power starts up. You will get to a black screen and at the top will be the safe mode option. Select the one form the top of the list at the top. Once there if your screen is back to normal it's just a graphics driver issue.
Change your display settings by right clicking on the dekstop screen and select properties>then click on the 'settings' tab. This is assuming you are not using dual mointors or a docking station.
Cannot reload factory settings on lenova 3000 model no 0768
Did not get which model 3000 you have from description. But if you have the restore disk all you need to do is put it in the system and reboot. It should then boot from the cd and ask what you would like to do. Hope this helps and have a good day.
Feb 01, 2009 | Lenovo 3000 C200 Notebook
Connectivity problems
Hello Erikkoehne,
We have Comcast tech support direct number on which you can call and get instant support for all the issues. We can fix any issue whether related to Comcast supported devices or services. Call us for more details.
Comcast Tech Support Internet Help Toll Free 1855 856 2653
Jun 16, 2008 | Lenovo 3000 C200 Notebook
Lenovo 3000 C100 missing "network adaptor"
yep got to Lenovo web site, customer support, serch the data base for drivers for your computer and select the drivers for you wireless device, and install them, without knowing the brand of wireless you have I am just stabbing in the dark, try that and let me know.
Dennis
Lenova laptop
there should be a slot on the side of the laptop.puch a tiny little button and the slot will slide out...install the wireless card into that...contact me if you have any more problems.
May 12, 2008 | Lenovo 3000 C200 Notebook
Samsung SyncMaster 240 T 24.1" Flat Panel LCD Monitor Logo
42 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
