Question about Amana LEA11 Dryer
Dryer not hot enough
Just but three new thermo in still not dryer right
    Problem Solver:
  • 6 Answers
If you have tried all of that then the only other thing it could be is a ventilation problem. Try checking for any obvious clogs of lint in the vent line at the dryer or side of the house where air exits. If no obvious issues then attach an electric leaf blower to the dryer side of the vent and let blow for 5 min. This should break loose any lint in between and you will see the results at the end of the line on the ground. If your vent is really long and you still cant get it all out then you may have to consider replacing the vent hose.. Hope this helps.. Thanks
Posted on Feb 18, 2009
Kenwood KCD1W tumble dryer not heating up replaced element and all three stats still not getting hot ?
Check main cable connections and power from main circuit. Possible one leg is open because of circuit breaker defective, open circuit from breaker through connection on the back of the drier. Sometimes the connector internal at the power connection will fail (see second image).
Check Thermo-fuse. If this thermo-fuse fails it will need to be replaced. (see first image).
If only one leg that supplies 120 volts is powered then motor and controls can operate. the heater elements are the part of the dryer that requires the other leg for the 240.
Hope this helps?
Nov 29, 2016 | Dryers
Thermos Grill2GO gets warm but not hot.
Often the problem is pretty simple. I forget to turn off the control knobs when turning on the propane. This triggers the new safety mechanism in the regulators that restricts the gas flow. To re-set, disconnect everything, then reconnect with all knobs in the off position. Turn on the propane at the tank to "pressurize" the system. Sometimes I have to do it twice to get it to work right! If not - I'd suggest you contact customer support at Char-Broil (they make it) and get some tips.
Jul 12, 2010 | Thermos Grill2Go Gas Grill 4656110
Long drying time
check your thermo-couple
Sep 12, 2009 | Dryers
Dryer not blowing hot air
you either have bad element or bad thermo disk or thermo fuse
Jul 01, 2009 | Kenmore 63942 Dryer
I have a similar problem. But I will provide a little bit of history first. My dryer just doesn't get hot enough (approx 100 degrees just prior to the exhaust vent). Three years ago, I had the same...
If the gas cycles on and off I do not think the coils are a problem.  Sounds like the flame sensor is not working correctly.  The flame sensor keeps the gas valve open after the ignitor shuts off.  Then the temperature sensor shuts off the gas when temperature limit is reached.  When the dryer cools down the gas cycle starts again (usually much more than 30 seconds).
May 29, 2009 | Dryers
Over the weekend, I notice a bird flying in and out of my dryer vent... then our Kenmore electric dryer stopped heating. I'm think that there wasn't enough airflow and the thermo-fuse probably blew... What...
Ah Yes! the old bird in the dryer vent problem!
I would say you are correct. The thermo-fuse blew because of not enough air flow through the heat tunnel.
You probably have a nest in your vent line now.
Clear the entire line from machine outward, replace flex hose if needed and get a new outlet cover with the flaper door on it.
I avoid the ones with screens on the outlet, because it catches lint.
Except in severe cases where a mouse or some other varmit has figure out how to lift the door.
Apr 27, 2009 | Kenmore 62602 Electric Dryer
Whirlpool Dryer LEL8858EQ1
If the door switch was a 3 terminal device, and all three terminals had a wire going to them, did you get the NO and NC wires connected to the right place?
You should be able to follow the circuit that can be found on the back service panel or inside the control head.
Let me know what you find or if you have any more questions.
Jan 29, 2009 | Dryers
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Magic Chef Dryer model # CYE2000AYW
ck the thermo fuze and clean out the vent going out side ck the breakers to dryer
Mar 05, 2008 | Dryers
Dryers Logo
42 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
