Question about Kenmore 22422 Top Load Washer
Kenmore series 70 will not fill
My kenmore series 70 washing machine will not fill... the water is running straight through the machine to the drain...
  • RachelLS Feb 24, 2009
    My Kenmore 70 series washer will not fill. I saw somewhere that it is either the lack of an air gap or that the drain pipe is not elevated high enough. There is definitely an air gap and I did straighten out the drain hose and elevate it and it helped temporarily, but is still not completely fixed. I need help!
    Problem Solver:
  • 6 Answers
Ive only run across this a couple of times in my years of appliance repair. This sounds like you do not have an air gap on the drain hose. Where the hose hangs into the wall drain pipe make sure you do not have that sealed air tight with duct tape around it or something. It needs to have a gap all the way around the hose and just hang freely. If it is sealed off then it creates a siphon effect and sucks the water right out of the washer tub into the drain.. Hope this helps.. Thanks
Posted on Feb 18, 2009
70 series top loading washer
probably no parts for a machine that old
consider getting a new unit that is more power and water efficient
Jun 25, 2017 | Kenmore 24032\24036 Top Load Washer
The wash machine will fill but wont stop filling
If it stops filling when you turn it off, the water level switch is malfunctioning. If the water runs in regardless, the water inlet valve needs replaced.
Dec 28, 2009 | Kenmore Washing Machines
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Kenmore 70 Series washing Machine won't stop filling with water
filling and never stops and never agitates? then check level switch and hose, any hole in the clear hose to the level sw can cause this. if airtight then replace level sw.
Apr 27, 2009 | Kenmore 22422 Top Load Washer
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Kenmore series 70 washer doesn't fill
check your incoming water supply, the buzzing sound is coming fromthe waterinlet valve , soundslikke its trying to fill. possible that the valve is no good as well,
Nov 23, 2008 | Kenmore 22422 Top Load Washer
70 series wont fill w/water
CHECK SCREENS IN WATER VALVES FIRST. CHANGE TEMPERATURE SELECTOR TO COLD ONLY, SEE IF IT WILL FILL. IF IT DOES FILL AND SCREENS ARE CLEAN YOU MOST LIKELY NEED A WATER SELONOID.
FXIT
Jan 26, 2008 | Kenmore 22422 Top Load Washer
Kenmore heavy duty washing machine 70 series
The most likely cause for water fill temperature problems is the solenoid has burned out, usually cold first, it gets used more. Not a repairable item , easy to replace
Dec 30, 2007 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
253 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
