Question about Canon Cameras
Broken canon A640 LCD
I dropped it. It was in a case but the LCD is history! Can I get it replaced...or is it new camera time only? Thanks, Stuart
Found the answer on other web sites... at no charge. Thanks
Posted on Feb 19, 2009
I need a new screen for my canon powershot A640 ASAP.Mine is smashed for the second timme. Where could I possibally get1?
If you're confident you can do the job yourself, you can order the part from
http://uscamera.com/ck9-1241.htm
Dec 11, 2010 | Canon PowerShot A640 Digital Camera
How to replace battery door on canon a640?
I not completed this yet but I have the new door in hand. I got this from online.
Battery door replacement on this model will require removal of both front and rear case,fairly straight forward remove all screws and seperate case.You will see that door is kept in place by a small metal rod,which will slide out and allow defective door to be removed and new door to be installed(note location of spring before removing).
Apr 21, 2010 | Canon PowerShot A640 Digital Camera
My canon powershot A640 wont turn on despite having new batteries installed, also the USB connector socket has fallen inside the camera, will this cause a short that will stop it powering
Yes, you are probably right. A short within the camera could make it "un-startable. Take it to a local electronist or a Canon dealer and they will help you solve this problem. Also check if the batteries are good and fully charged. Some new batteries could be faulty from the factory.
Apr 07, 2010 | Canon PowerShot A640 Digital Camera
CANON POWERSHOT A640 LCD VIEWFINDER STOPPED WORKING
nice camera ... the button at the bottom left is marked Disp ... each time you push that button it will change the display mode ... there are three modes .. OFF, ON , and NIGHT ... night turns down the brightness a bit ... push the button several times until you get the display you want ..
Oct 06, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
How to select date stamp on canon powershot a640?
You can print the date on image when Postcard is selected. The date will be printed on your images even if it has not been set at the computer or printer.
* Ensure that the camera's date/time is set beforehand.
* Set the camera to a shooting mode (except (Stitch Assist) or Movie).
* Press the <DISPLAY> button so that icons show on the LCD screen.
1. Check that appears on the LCD monitor.
- If it does not, click here to view the procedure for changing the resolution.
2. Press the <MENU> button.
3. Select (Date Stamp) in the [ Rec.] menu using the or buttons.
4. Select [Off], [Date] or [Date & Time] using or .
5. Press the <MENU> button to exit the menu.
6. Shoot the image.
- The Date or Date & Time will be embedded into the actual image.
Jul 27, 2009 | Canon PowerShot A640 Digital Camera
LCD Screen not working, but camera still takes pictures
Looks like the contacts of the LCD of your camera are loose. Be advised that this repair would require you to take it apart and may vvoid your warranty. If there are no faulty contacts then you will have to replace the LCD screen. Should cost you around 100-150$
Nov 14, 2008 | Canon PowerShot A640 Digital Camera
How torReplace LCD display on Canon A640
Hi there, you could buy the lcd panel from canon for about $50.00 but it is a little tricky to replace. If you do open the unit, discharge the flash capacitor first other wise you may be in for the shock of your life if you accidently touch it!
mr cicmo
Aug 19, 2008 | Canon PowerShot A640 Digital Camera
Canon A640 flash problem
I sent my camera into Canon for repair. They said the flash was malfunctioning, and there was something wrong with the flash exposure control. The repair cost about $87. It took approximately 10 days from the time I sent the camera in until the time I got it back.
Jul 11, 2008 | Canon PowerShot A640 Digital Camera
Need to replace the circuit Board.
You can call Canon tech support and be transferred to the parts department.
Hope this Helps!
Jun 08, 2008 | Canon PowerShot A640 Digital Camera
The lcd
It is likely a new camera will cost only a little more.
If it still takes pictures leave it at that
or buy a new camera
Check out makers website for repair costs
Nov 26, 2007 | Canon PowerShot A640 Digital Camera
Cameras Logo
24 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
