Question about Coleman Powermate Powermate 5000W Generator
Generator started, ran briefly, then stopped sending juice
It had been a while since I ran the generator, but in a recent power outage it started up, and for about ten minutes supplied power. In quick succession there was a brown out, a clunking noise, and it stopped supplying power, while the engine continued to run. The reset buttons indicating short circuit or overload were not triggered. Any idea what the problem is, and what to do about it?
  • Anonymous Feb 20, 2009
    THE GENERAC THAT I AM TRYING TO FIX,WAS HOOKED UP ON THE 240 VOLT PLUG AND HAD TO MUCH AMPERAGE PULLING ON IT AND IT QUIT PUTTING OUT 220 BUT ALL THE 120 PLUGS WORK AND I CAN ONLY GET 120 FROM THE 240 PLUG
    THANK YOU JJ
  • 169 Answers
crclarkphd has a problem that sounds like a brush failure. The clunking noise was likely the remainder of the failed brush getting knocked around inside the back end of the generator so you need to take it apart and inspect things closely. Here is a link to a general solution I posted some time ago that may be of help.
Guest jj has a fried breaker in one leg of the 220 outlet. Even though it doesn't look tripped it's failed, check it with an ohm meter.
Regards,
Carl
Posted on Feb 23, 2009
Generator is two yrs old only had a couple of outages maybe totaling thirty hrs Generator ran great and also ran every wk for its exerciser cycle. The generator didn't start on this cycle and the system...
Is this a natural gas fueled generator? Sounds like a fuel problem, i would go through the fuel system and find out whats wrong. If its a natural gas/propane unit its most likely a bad regulator or low pressure.
May 04, 2017 | Eaton Electrical Supplies
Generac 20,000kW Standby generator doesn't start shows message STOP ALARM OVERCRANKED
Overcrank means that it tried to start and couldn't. It will go through 5 crank cycles and then stop with this alarm. Switch to off, hit enter to clear fault and then try to start in manual. Check to make sure you have fuel and pressure is 11 to 14 in WC.
Jun 21, 2012 | Generac 13,000 Watt / 13,000 Watt Home...
Installed a generac 20kw about a year ago, ran fine untill 2 days ago. During a utility outage, generator ran for about 30 minutes and then stopped producing power while still running. All mains were still...
With the engine off, check the exciter brushes and slip rings which supply magnetic power for the alternator winding in the stator. Also, check the motor-to-alternator mechanical coupling. Check the breakers for tripping. To service beyond this point requires a schematic of the alternator, a voltmeter, plus knowledge of what the schematic is telling you. Good luck!
Jul 25, 2010 | Generac Power Systems Generac 5525 20 Kw...
Coleman sport 1850 powermate generator, no fire to sparkplug
is there an oilprotection on the gen. disconnect the cable and try again
Jan 18, 2010 | Coleman Sport 1850 Generator
Same problem, generator kicked in after power outage,
At the point the transfer switchis suppose to transfer put a dc volt meter across terminals 23 and 194 in the transfer if you do not show 12VDC. Then you have a relay hanging upon the PCB board in the generator, need to replace board. If you are showing 12VDC and the switch is not transferring the problem is in the switch itself.
Sep 08, 2009 | Generac Guardian 100 Amp Transfer Switch...
Coleman Powermate Powermate 5000W Generator Logo
301 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
