Question about Arctic Air R22CW Refrigerator
The fan makes a lot of noise. - Arctic Air R22CW Refrigerator
The fan's motor bearing is shot.  You have to replace the whole fan motor unit.  There is a good exploced drawing of unit.  Google Frigidaire publication #  5995342655.   The part number you need is: 216690400.  The unit can be accessed by removing the stainless cover at the top of the inside of the refrigerator.  There are 4 stainless, philips head screws to remove and then the cover pulls down.
Posted on Apr 22, 2009
Why does my bed make a lot of noise
Most systems have cheap fans with cheap bearings that wear out easily. It may be time to replace the fan.
Aug 16, 2014 | Computers & Internet
My computer when left on is making a lot of noise and funny sounds. I read it is the fan but could it be getting information from the internet while it is not in use?
If you Processor is access info the CPU fan can also make lot of noise, Kindly check SMPS fan also due to Dust formation on both these fans can result in making sound.
Mar 15, 2011 | Computers & Internet
My computer is becoming really hot and noisy. After turning on the computer, everything is good (no noise). Once around 15 minutes passes by or I open up a lot of programs together, my computer starts...
Sounds like the fan is wearing out, as it heats up the fan needs to spin faster and if the bearings are wearing out it will start getting louder and it will also get hotter because the fan cannot keep up the heat being produced. You can replace the fan, most computer shops will carry replacements, also get a can of compressed air and give the inside of the computer a good cleaning. This will help keep things cooler as well. Also make sure that the air vents on the outside of the case are clear as well.
Jan 07, 2010 | Vantec Fan Vibration Dampener Noise...
The fan in modem makes loud noises at times
Modems don't have fans.
I think you mean your fan in the computer makes a loud noise. Some computers have settings where the fan speeds up if you are doing a lot of things--making the computer work harder.
Some fans make noise just before they fail. Depends on the type of noise. If it's a sound that has a lot of rattling in it or maybe a high screeching sound, I'm thinking you'll be needing a new fan. Probably a CPU fan is the culprit. Also, fans on video cards often go bad--so you'll have to open the case and listen to where the sound comes from.
Oct 25, 2009 | Dell Dimension 8400 Desktop P4 630 3G 1GB...
Fan started making noise
I have one of these, and every so often, the fan would start making a loud clicking noise. I discovered that if I shut the fridge off for a while and left the door open to defrost it, it'd work fine again for a while before the noise came back. Apparently, some ice was building up between the metal heat-sink and the fan, causing the fan blades to scrape against the ice/frost build-up and make the "tick, tick tick" noise.
There is no compressor in the Avanti EC15W-2 mini fridge. It uses a simple Peltier junction device to transfer heat from the inside of the fridge to the outside/rear of the unit. So it should never get very loud at all, unless one of the two fans in it is acting up in some way.
Aug 15, 2009 | Avanti EC15W-2 Compact Refrigerator
this could be normal operation of viscus fan hub, it is engauged when you 1st start up when cold then a minute or two out of drive way when taking off they cut out
when idling it should cut in and out also
Aug 09, 2009 | 1998 Isuzu Rodeo
Fan/ engine whining sound
If the fan is only making wind noise it is ok. If it is making matalic noise replace fan. It would be a good idea to clean (blow)out the dust and dirt for the inside of the computer at this time.
Jan 12, 2009 | Computers & Internet
My CPU is making lot of noise especially when I'm using programs like Adobe reader
The CPU wont make noise unless its frying. So its either your hard drives, cd drives, or your fans.
If its your fans i sugest buying newer "Cool Master" fans that are powerful but less noisy
Oct 20, 2008 | Mesh 80mm Aluminum Fan Filter Fan Kit
Ps2 fan
Is your machine a old one or a slimline version??
Slimline version have a micro fan and can be replace it.The old one is even better because are cheap and you have a lot choice.Just make sure you get the right one.I believe is a ball bearing fan so if the balls inside get dirty or sticky ..or just defective from nature....nothing more you can do then get a new part.the noise is cming from micro vibration in rotation and all that micro..in 2000-3000 rpm in a minute make a lot noise
Jun 04, 2008 | Sony PlayStation 2 Slimline Console
Arctic Air R22CW Refrigerator Logo
227 people viewed this question
Top Arctic Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dennis Boxerman
Are you an Arctic Air Refrigerator Expert? Answer questions, earn points and help others
