Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Door/drum seal has split causing a major leak also had probs for last few months where it gets to last 10 mins of cycle then it just counts down and doesnt complete the cycle it then gets stuck on 1 min and i have to cancel the cycle and put it on a spin only cycle and the washing comes out warm?! Hotpoint aquarius wf740
  • Anonymous Mar 19, 2014
    The cycle should last 65 mins but is taking 2 hrs to complete
    President:
  • Hotpoint Master
  • 662 Answers
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Posted on Jun 08, 2010
I have a kenmore HE 2t washing machine. It is leaking out the bottom of the front loading door, especially on the delicate cycle. The gasket and door seem to be fine.
Do check the rubber door seal again.
Often you can get a few months' extra life out of the door seal by removing it and replacing it upside down, if it will fit.
Feb 11, 2015 | Kenmore Washing Machines
Washer leaks
the door seal is gone check around the inside of it for a tear
you can slide a bit of newspaper under it and run a cycle on
then pull out the paper and you can see what part of the machine its coming from
if its near to the front its prob the door seal
quite easy to change by heating it up before fitting
do the drum end first
Dec 20, 2014 | Kenmore Washing Machines
My 1wd7145k (uk) has stopped working mid cycle, I have restarted and it fills with water ok but does not start to spin but continues to count down on the program timer. the motor does not spin and I
May be the rubber belt is gone open the screws behind the washing machine and check if the belt is worn out or cut replace by buying the belt of the same code number printed on the belt
Nov 15, 2014 | Indesit Washing Machines
We have a Whirlpool Duet Sport Front-Loading Automatic Washer and it makes a pretty loud noise when in the spin cycle. The volume is directly proportional as to how fast the washer is spinning. It's a...
The symptoms that you describe are caused by bearing failure. The water seal in the wash tub has failed, allowing water to leak into the bearing causing the bearings to rust. As the bearings start to rust, they will not roll properly and start to make a rumbling sound. The sound get louder the faster the bearing turns.
It a major job to repair since the washer has to be taken apart and the wash drum needs to be removed to replace the seal and bearings. Get a few estimates before deciding whether the washer is worth the cost to repair or replace. Sorry.
Oct 04, 2010 | Washing Machines
Hi I got an HE2T front loader. its 1 yr 1 month old. i place clothes turn to cycle door locks drum turns they get wet they sit there drum turns once or twice they sit there few min it drains then goes to...
was the trip in house knocked of at any time ,sound like it was knocked of its cycle.Push and hold the on/off button in for about 5 secounds this should reset the program and if tha fails push and hold the on/off botton plus one other botton and hold the both of them in for about 5 secounds.adrian,,,,,,,,,,,,
Aug 11, 2010 | Kenmore 46462 Front Load Washer
I have a wma 10 which is a couple of years old. The door seal now leaks when the machine goes onto a spin? Is there anything that you can suggest?
Sounds like there is too much water left in the drum as it goes into the spin cycle, and the centrifugal force of the drum spinning is forcing the wate past the door seal probably, needs the filter cleaning, or the door seal itself may require replacing.
Aug 04, 2010 | Hotpoint First Edition WMA12 Front Load...
Leaking at each wash cycle
this sounds like the door seal has split,,,there not very pricy but a pain to fit,,,so here go's,,,
open the door,,look at the door seal pull it off the back of the door and you should fine a spring wire holding it there,,,undo this wire,,,now fold the seal into the washer over the inner drum,,,,there you will find the inner wire,,undo that wire and pull the seal out the washer door,,,,
to fit the new seal,,,turn the seal inside out and push it through the hole in the door then fit the inner wire on the inner drum first,,,unfold the seal and pull it through the door,,,now fit the outer wire,,,,not put the kettel on,,have a cup of tea take the pain killers for the head ache you just got,,, and think about how much money you just saved ????
now was it realy worth the trouble,,,i wonder? am i good or what?
Jul 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint aquarius 1000 WM62 leaks from the bottom at the front of the machine towards the end of the cycle. How do I fix this?
Carefully exmine the door seal for a hole or split, remove the clamp ring round front and pull seal of front of cabinet and check it carefully, if no sign of leak from seal, then it is going to be leaking from the plastic drum front of washer.
This will entail removing tye front panel.
Hope this helps.
Jan 17, 2010 | Washing Machines
Hi, there i a knocking noise during the spin cycle on my hotpoint aquarius 6kg wma56 washing machine?? How do i fix it?
I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. Also another way to check is to move the inner durm up and down to see if there is any play in it
Check for bearing failure by seeing if there is any vertical movement between the moving stainless drum and the fixed outer drum. There should be no vertical movement between them - if there is the bearings have failed and will soon collapse. Check for rusty spray around where the pulley shaft enters the outer drum - early indication of seal and bearing failure. Another method of checking is to remove the drive belt and rotate the drum by hand - there should be no noise, roughness or resistance to rotation. Changing bearings is an involved job, only attempt if you are mechanically competent.
As for changing the bearings.
Power off, remove covers. Disconnect drive belt, remove drive pulley. Remove heater, thermostat and pressure switch. Check if drum splits at front, rear or the middle. If the drum is a plastic welded one- ie one which doesn't split, then its game over. If it splits at front or middle, drum will prob. need removal from machine. This involves dismantling the suspension and damping system and removal of door seal and concrete weights. Undo the drum fixing system - either a clamping ring or a series of peripheral bolts and split the drum. If the drum splits at the rear, removal from machine probably not required. Remove the clamping system and pull off the rear plate. Seal and bearings will come away with the plate. Seal needs to be dug out with a suitable lever and the old bearings hammered out with a punch from opposing sides of the backplate. Refitting is, as they say, a reversal of the above process.
However Unplug the appliance and take the top off.
Check the weight on the top to see if it's slack.
Open the door and with your palm upward put it on the edge of the drum.
Lift it until the weight comes on. Is there a lot of movement?
Press down on the inner drum and swing it side to side, does it sound/feel rough?
Finally, tip the machine rearward a little and from underneath check to see if the front weight is loose.
If all of the above are ok then it's likely the drum support spider has broken one of it's legs and the inner drum is knocking as it spins.
To sort this out you would need to strip the appliance down and remove the inner drum to try and change the bearings and the inner drum support.
This is a major strip down of the appliance.
Hope this helps
Thanks for contacting fixya.com
Nov 12, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Water Leakage Under Front Load Washer
most likley cause of your problem is the grey bellows has a tear in it. Inspect the bellows to check for tears. Or you can remove the lower panel and run the washer and look for the leak that way. Im sure it is a tear in the belows. Not a diffacult part to replace if you are mechanicly inclined. Good luck.
Nov 20, 2006 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
139 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
