Question about RCA P56950 56" Rear Projection Television
I have a RCA 60 inch TV and its about 12 or 13 years old. It has never been serviced or cleaned on the inside. The problem I'm having is the picture is starting to fade (quite a lot)and I was wondering if I need to clean or dust anything inside the tv. Also it turns itself off, I though it was getting hot so I took off the front cover and place a small fan in front of the tv. That stopped the tv from cutting off. Anyway do you think my tv needs a good cleaning or do I have something burning out?
  • minnow4u2 Feb 18, 2009
    thanks, I'll try cleaning it. Do I need to take off both the upper and lower rear panels to do this?
  • 505 Answers
You probably have a little of both. the shutting off is definately heat related but could be too much dust on heatsinks, etc causing it to shutdown. cleaning may eliminate problem but could be a sign of an underlying issue..
the dust can really cause the picture to dim. most of these tvs you can pull the "lightbox" or guts out of the cabinet to clean all 3 lenses, and clean the mirror if needed. don't mess with the screens except cleaning the front from outside. usually a 1/4" driver will be all you need, and a soft cloth for the lenses. use compressed air or a vacuum to clean out dust which will help with cooling, but the picture is only effected by dust on lenses, mirror, and screens.
Posted on Feb 18, 2009
My mitsubishi tv is almost 3 years old and it has no picture but it has sound
Video board malfunctioning....Get a honest TV tech. Only three years old? It is worth repairing, will deliver several more years of excellent service. A quality television.
Mar 31, 2013 | Mitsubishi WD-62526 Projection TV
I have a 10 year old RCA 50 inch big screen TV with marks on the screen that seem to be on the inside. How do I clean the inside of the screen, thanx Lon
marks inside the tv glass should only be cleaned by a professional because you may damage the extremely sensitive parts of the television, if its not to bothersome to you , you should ignore it as you will probably be charged an arm and a leg for this,(i know from experience)
you can also try adjusting the picture settings until it becomes less noticeable
Mar 05, 2011 | RCA HD50LPW175 50" HDTV
I have a 60 inch RCA tv rear projection digital. the picture is like seeing 3 of everything. I have being able to fix this in the past by using the convergence option on the setup menu. but now the...
what it is the tvs like this are mento be serviced every 3 years or so the convergence settings are in the back only user ones are in the settings dont try this yourself though i broke mine lol it will cost 120 pounds tops to fix dont worry its worth it if this has helped please give me thumbs up because people are just taking answers and not voting
Jan 15, 2011 | RCA P60921 60" Rear Projection Television
I have a 35 inch older model.heavier than heck....
this is fixable, normally it is caused by a capacitor or an ic, but it is fixable
Sep 04, 2009 | RCA 32V550T 32" TV
52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Jun 19, 2009 | RCA HD52W56 52" Rear Projection HDTV
Darker picture
Clean the lenes inside of the TV and the mirror and screen (a little dust build up on these three things adds up quick!) also if you smoke that can build up too! these tvs have too be cleaned inside
Nov 28, 2008 | Hitachi 57F500 57" Rear Projection...
Sony 52 inch hd widescreen projection tv
You need to pull the top back off be very carefull that you do not break mirror clean mirror and all 3 tube lenses this should make a diffenrents in picture.
Feb 19, 2008 | Televison & Video
Rca 52 inch keeps shutting off and picture is curved
The curved picture indicates failing parts in the pin amp section and probably some faulty parts in the scan amplifier sections. The set is being turned off by the uPC because there is a fault indicated, and it is going in to protect mode.
The set will have to be properly serviced.
Jerry G.
Aug 21, 2007 | RCA 32V420T 32" TV
Rca 61 inch tv
that "pop" was the flyback transfor, a resistor, or a capacitor bloweing up. if your not a technician this is considered a circuit repair and ther are no serviceable parts inside this set for you to replace without the proper tools , service manuals, and schematic diagram. Sorry man your gonna need a serfvice pro to help ya with this repair. Good Luck
May 24, 2006 | RCA P61927 61" Rear Projection Television
RCA P56950 56" Rear Projection Television Logo
266 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
