Question about Epson TM-U220 Matrix Printer
EPSON TMU200D PRINTER not printing whole ticket on large orders
My POS system has an issue that their support cannot fix. for large orders, the printer stops in mid order and does not print a complete ticket. is there a way that i can set the que for the printer to stop this issue or does the printer have an internal mechanism that need to be changed? DIP PINS, etc
4 Suggested Answers
  • 10 Answers
SOURCE: Epson TM-U220 Matrix Printer not printing in WinXPP
hi basiime
possible issue is port configuration. if the generic text driver works, apd driver should work too.
what may be happen is that when you install the apd driver the other printer drivers that you have were still using the same port that your apd driver were using. example, you have generic txt assigned to lpt1 and then the apd were assigned on the same port, this is were you get the trouble.
what you must do is, first, check any printer driver that you have using the lpt, say for example, you generic text is using lpt1, when you install the apd driver set it to lpt2. apd drivers will create a new port normally called esdprt. try to use that port but if that will not work reassigned the port of your apd driver to lpt2 printer port then uncheck bi-directional support. from there you should be able to print..
hope that resolves your issue.. =)
Posted on Feb 24, 2008
SOURCE: EPSON LQ - 2180 paper settings
I HAVE CUSTOME SIZE OF PAPER WHICH IS NOT AVILABLE IN THE PRINTER LIST .WHEN I DEEL WITH WINDOS XP
BUT WHEN DEEL WIHTH WINDOS 98 ITS OK
NO I DONT HAVE WINDOS 98 . MY QUESTION HOW I CAN ADJUST PAPER TO CUSTOM SIZE
Posted on Nov 24, 2008
57 varieties
  • 1653 Answers
SOURCE: TM-T88III print speeds and other issues
Try setting both switch 1-7 and 1-8 to ON for 38400 baud, set switch 1-2 to OFF to give a 4k buffer, set switch 2-5 to OFF to release the busy buffer at 256 bytes, set switches 2-3 and 2-4 to ON & OFF for medium print density and OFF & ON for dark print density or OFF & OFF for normal print density.
Also remember that the thermal TM-T88III also prints faster when the print head is cooler and slower when it heats up. The print speed is adjusted automatically depending on the voltage applied and head temperature. So make sure your power supply is providing a steady 24VDC at full load and has enough capacity to provide a peak of 7.7A in full speed mode. If you are using the printer in high temp and humidity you might want to swap the unit out for a Star Printer which performs faster and uses the same protocol or use a cooling fan.
Also make sure you use a good quality paper and that the humidity is within range at 10 – 90% RH although the paper performance will be greatly diminished at higher humidity levels.
Specifications:
High-speed = Approx. 150 mm/s {5.9"/s} max.; 47.2 lps, max. (3.18 mm {1/8"} feed);
35.5 lps, max. (4.23 mm {1/6"} feed, at 24 V, 28°C {82°F}, density level 1).
Low-power: Approx. 16.5 lps (4.23 mm feed {1/6"}); 70 mm/s {2.76"/s}
Ladder bar code: Approx. 42 mm/s {approx. 1.7"/s}
High-speed mode: Mean: Approx. 1.8A Peak: Approximately 7.7A @24VDC
Low-power mode: Mean: Approx. 1.2A Peak: Approximately 6.6A @ 24VDC
Operating temp = 5 to 45°C {41 to 113°F}
Operating Humidity = 10% - 90% RH
Posted on Aug 29, 2009
Will not print longer receipts. How do I fix this problem
PDF]TM-T70II Brochure - Epson
www.epson.com/alf_upload/pos/pdfs/.../brochure_tm-t70ii.pdf
EpsonThe TM-T70II prints receipts and graphics at the same fast ... Print technology, the TM-T70II can print ... It also offers Serial, Ethernet and USB options ... long-lasting autocutter and all-front access. ... are easy to use and do not affect print ... Space-Saving Thermal Printer with Easy All-Front Access ... Epson Dark Gray (EDG).
Epson C31CD38A9971 TM-T70II Front-Access Thermal ...
www.newegg.com > ... > Receipt Printer > Epson America
Newegg(Do not use your browser's "Refresh" button). ...... Streamline your POS system withEpson's space-saving TM-T70II printer. ... Ethernet and USB options, enabling flexible mobile and web-based receipt printing. ... including drop-in paper loading, long-lasting autocutter and all-front access. ... Color, Epson Dark Gray (EDG).
Epson TM-T70II Series - Epson
www.epson.co.uk > Home > Retail
EpsonEpson TM-T70II thermal receipt printer for barcode, ticket printing is for ... The latest innovation in Epson's long line of receipt printers are its series of smart ... same
Jan 27, 2016 | Epson T70II - SPACE-SAVING - PUSB & USB -...
Kitchem printer misses items or sometimes an entire ticket.
It sounds like a software glitch. I would begin looking for new programs, and possibly a new system for the tickets entirely.
Jan 24, 2014 | Pc America Restaurant Pro Express
Printer print blank print is blank
its a thermal printer.... which may have defects already.... when the printer prints blank its either its not heating up or the thermal mechanism is already damaged... try calling epson tech support... i think they have a warranty offer for your type of issue since its a POS system. hope this helps you with your issue. :-)
Aug 11, 2011 | Epson TM L60II Printer
Pc America stops talking to the kitchen printer. after setting up the kitchen printer numerus times and running test prints through the POS software, Pc America will just decide to start printing the...
You have not given enough info but I'll assume you shared the printer as a standard network printer. This will not work with RPE and Epson. You must install the Epson Ethernet Configuration Utility. This acts like a print server and delivers the print jobs over the ethernet (network). You also must have the proper Epson driver installed for your operating system (not given). This is not always the newest driver!! Repeat, not always the newest driver.
But if this is a new setup, why don't you have their tech support doing it. You paid for it.
B Mattern
sysadmin@ccybernet.com
Please return and give me a favorable rating if this helps or is of value to you.
Jun 10, 2011 | Pc America Restaurant Pro Express
Where can i find a driver for this printer
this printer can emulate several others like the epson tmu200d ... you can get its native drivers here
http://www.posguys.com/receipt-printer_12/POS-X-Xr200_570/
look under downloads and click on drivers .. you can also get a manual there
Sep 28, 2009 | POSX POS-X XR-200 Matrix Printer
Need open drawer sometimes
It depends on the software, every time the sw sends the signal to
print a ticket, it is accompanied by an impulse the printer relays to
the drawer. Notice how when performing a self test the drawer
doesn't open? That's why. My POS sw has a selectable parameter
to send or not send the drawer open impulse. You would need to
mod your sw to have that selectability.
Nov 27, 2008 | Epson TM-T88III Thermal Printer
Epson TM-U220 Matrix Printer Logo
83 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
