Question about Dryers
Our dryer gets hot how ever it takes forever to dry a load of clothes and it makes a huge thumping noise; what could this possibly be.
  • jdstiles18 May 11, 2010
    Sounds like a ventilation problem somewhere down the line. The air has to be able to circulate in order to dry the clothes well. Long vent lines are the worst for clogging up with lint. Main place for that to happen would be at the end of the vent attached to the side of the house. If it has one of those plastic screens on it to keep animals from crawling up in it.. They become clogged a good bit. If not we always attach a electric leaf blower to the dryer side of the vent. Turn it on and let it run for about 5 minutes. The air is moving at a much higher rate of speed and will help push any clogs out. As for the thumping noise the drum rollers are bad about going out in a Maytag or getting flat spots. That requires taking the cabinet, drum, and belt off to access. Front comes off first. Hope this helps and get back to me if that works
  • 547 Answers
The thumping is the drum not moving around right you need to change the felt the vent hose must be tight and stright up and out no slack moister needs to be blown out
Posted on Feb 18, 2009
Thumping noise
Sounds like the tub is unbalanced from either a bearing/pulley suspension problem or the unit has broken something off in between the tub and outer portion of the unit before you get to the walled panels, and you are hearing a rubbing and thumping noise. This is not a typical DIY job since the entire back panel of the unit needs to be pulled off and diagnosed.
Sep 18, 2012 | Frigidaire FEQ1442ES Electric Dryer
Dryer does not dry clothes but seems to be hot inside when i open the door
Most of these guys get a bad blower wheel. The heat melts the hub causing it to spin free and airflow is reduced. This makes it take fifty forevers to dry a load of clothes. More Here
Aug 18, 2010 | Crosley Dryers
Dryer gets hot but takes along time to dry
Make sure the lint filter is clean. If it is make sure the hoses leading from the dryer to the outside are not clogged. It sounds like it is not getting prober airflow through the tub.
Jun 15, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer gets clothes hot, but forever to dry them.
I have exactly the same problem. My unit is 2 years old and has suffered this same problem since the day I bought it.
HELP
HELP
HELP
May 14, 2010 | GE Spacemaker Washer and Dryer Electric...
Dryer takes forever to dry clothes
Check out this tip... it will help you to find out what is making it take so long..
http://www.fixya.com/support/r4312805-dryer_maintenance
heatman101
Mar 26, 2010 | Maytag PYE2300AY Electric Dryer
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
Dryer not heating
THE PROBLEM IS YOUR WALL VENT CLOGGED OR THE BACK OF THE DRYER VENT HOLE IS CLOGGED,IT KEEPS THE MOIST HOT AIR IN THE DRYER SO YOUR CLOTHS TAKE FOREVER TO DRY,THEY MUST BE CLEARED FOR THE DRYER TO WORK AGAIN-MIKE
Jan 05, 2009 | Kenmore Elite HE4 Electric Dryer
NOT GETTING HOT ENOUGH TO DRY TOWELS IN AN HOUR
It takes the dryer forever to dry a load of clothing, no matter how many pieces or thickness. Yes, I have already checked the vents out of the dryer, there not clogged. Any other suggestions?
Jul 09, 2008 | Whirlpool GEW9200L Electric Dryer
Dryer still gets warm but not as hot as it used to. Takes forever to dry clothes. Clothes used to come out really warm yo hot and dry butno more.
sounds like an airflow problem. disconnect the vent behind the machine and clean it out thoroughly. it might be kinked behind the machine, be careful when you push it back to the wall as to not kink the vent hose. if possible use a straight smooth metal duct to exhaust the air to the outside of your home.
Mar 10, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Dryers Logo
103 people viewed this question
Top Dryers Experts
