Question about Sony Ericsson W850i Cellular Phone
Sims lock have the code but cannot get the simbol * or # only num
Have code but can only put in numbers ,no*or # functions on display says sims lock
Was just reading about codes for 850i. all say to use star button to enter letters and symbols such as p and +, (repeatedly pressing * until letter shows). sorry don,t really know a lot about this stuff hope it helps. where did you get the code? remember 5 entry attempts before locking out is common apparently.
Posted on Feb 19, 2009
Unlock number lock
On a laptop, the "Num Lock" key has a function slightly different than the one it performs on full-d desktop keyboards. Activating "Num Lock" on a laptop usually transforms a set of central keys, including many letters, into number keys, allowing typists used to entering numbers on a keypad to type efficiently. While on desktop keyboards "Num Lock" usually has a dedicated key, on laptops it often shares a key with another function on MacBooks, for example, it shares the "F6" key and you must hold down the "Shift" or "Fn" key to activate it.
Look for the "Num Lock" key on your laptop's keyboard. This is usually near the top of the keyboard. If the key says nothing on it except "Num Lock" if that's the only function the key performs you can just press it to activate the lock; a light will probably go on somewhere to indicate that "Num Lock" is on. If the key has multiple functions, you'll have to hold down a different key while pressing it. Hold down "Shift" and press "Num Lock" if the writing saying "Num Lock" appears above some other writing on the key, the way various symbols appear above the numbers on the keyboard's number row. Hold down "Fn" and press "Num Lock" if the writing saying "Num Lock" appears in a different color often light blue that's shared by the "Fn" key.
Feb 28, 2013 | Acer Aspire Computers & Internet
Tip
Laptop LED Blink on Startup There are many reasons that a computer does not...
There are many reasons that a computer does not startup or boot into the Windows operating system. If your computer will not start or boot, you will see or hear symptom to indicate the general area of the problem.
Startup Symptom: LEDs blink but does not start
The blinking LED lights on newer computers, or the beep tones on older computers, will help support agent determine what hardware component is not responding properly. The exact meaning of each code varies with the model, and the user cannot change any of the blink or beep codes.
DO THESE FIRST - Perform a hard reset.
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
2. Disconnect the AC power adapter, remove the battery and then press and hold the power button for at least 15 seconds.
3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Identify the number of blinks or beeps
When there is a start-up problem and you see LED lights on the keyboard blink a few times (between 1 and 8 blinks) do the following actions.
Table of Sample Blink Codes
The following table illustrates the meaning of blink codes used on some notebooks. The blink or beep codes on your computer may have different meanings.
Meaning of Sample Blink Codes for some EFI Notebooks:
1) Number of Blink: Continuous Glow, Blinking LED: Battery power LED, Component: Battery,
Error Condition: The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
2) Number of Blink: 1, Blinking LED: Caps Lock/Num Lock, Component: CPU,
Error Condition: CPU not functional
3) Number of Blink: 2, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS corruption failure
4) Number of Blink: 3, Blinking LED: Caps Lock/Num Lock, Component: Memory,
Error Condition: Module error not functional
5) Number of Blink: 4, Blinking LED: Caps Lock/Num Lock, Component: Graphics,
Error Condition: Graphics controller not functional.
6) Number of Blink: 5, Blinking LED: Caps Lock/Num Lock, Component: system board,
Error Condition: General system board failure.
7) Number of Blink: 6, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS authentication failure.
8) Number of Blink: Continuous blink, Blinking LED: AC power adapter LED, Component: Power adapter,
Error Condition: Insufficient power
Common solutions for issues that cause blinking LEDs or beep tones
When the computer can boot into the BIOS, run the memory test to identify other issues.
Check for loose connections and test the memory
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. The problem could be that the stick of memory or one of the memory slots has a bad connection.
Check for loose memory modules
If a memory module is loose or is not making good contact with the memory slots, the computer does not recognize all of the memory. Reseating the memory module may resolve memory failure errors.
on Mar 21, 2011 | Computers & Internet
My phone says enter PUK and i do not know what it means. It only lets me have an emergacy call.
hi! nothing to worry!
i think that ur sim locked that is due to entering wrong unlock code for more than three attempt..!
now move to solve that problem!
try to get ur sim card pouch that you got with at the time of sim purchase! in that puk code is printed on it! simply enter that code ur phone unlocked!
if wont get puk cod or missing that sim pouch ! dont worry! simply call ur mobile network operator by using other num plz note the same operator number is used for calling( i.e need code for aircel num u need call another aircel num to get code) then call to customer care and ask puk for ur number before that u make note that the number quoted on the simcard..! then collect ur puk number! kindly save that number for future use!
! thats it now ur phone unlocked.! Cheerz......!
Jun 01, 2011 | Cell Phones
How do I use the Blue simbols on my satellite laptop?
Press the Num Lock (number lock) on the right hand side of the keyboard to use the blue symbols. Remember to turn it off again when you are finished.
Regards.
Apr 21, 2011 | Computers & Internet
Sir, my number is 7894954970.& my sim is lock. & it need PUK num. so sir can you give me the PUK num.
PUK codes can be obtained through the following ways - The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.
Feb 22, 2011 | Computers & Internet
Power light comes on but not working
First you need to determine how many blinks you are getting when you try to power on the laptop. Check the blinking codes below and reason behind that for HP Compaq laptops Blinking battery power LED Battery Insufficient charge on the battery Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional Blink: 5 - Caps Lock/Num Lock - System board General system board failure Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure You need to first Remove the memory module (RAM)- Try to power on the laptop ? then again reset it and try to power on. Check whether it is coming on or not. try the same procedure with Hard drive. If laptop is getting power on after removing one of the device then we can be sure that that particular device is faulty and we can change that then? Let me know if you find any difficulties doing this.. I hope this will help you to get it work. Plz vote for me..Dreamkam
May 27, 2010 | Computers & Internet
Hp compaq powering and nog display what do i do to
First you need to determine how many blinks you are getting when you try to power on the laptop. Check the blinking codes below and reason behind that for HP Compaq laptops Blinking battery power LED Battery Insufficient charge on the battery Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional Blink: 5 - Caps Lock/Num Lock - System board General system board failure Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure Well Check for the below link it will provide you the steps which you need to perform to isolate the cause so that we can determine which hardware of the laptop is causing this issue. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&cc=us&lc=en&dlc=en You need to first Remove the memory module (RAM)- Try to power on the laptop ? then again reset it and try to power on. Check whether it is coming on or not. try the same procedure with Hard drive. If laptop is getting power on after removing one of the device then we can be sure that that particular device is faulty and we can change that then? Let me know if you find any difficulties doing this.. I hope this will help you to get it work. Plz vote for me..Dreamkam
May 21, 2010 | HP Pavilion dv6000z Notebook
HP DV6110us: 4 beeps, no boot
besides the beeps which indicate a motherboard timing issue. There should be LED blinking codes given on the front LEDs. I will include the blink codes below, but lets try to at least get the system up and running. First, I would like you to remove the RAM sticks from the laptop and just reseat one stick back in the machine. Try to boot with that one stick, if it does not, try the other alone. There have been issues when reseating the ram or re-installing it have temp. fixed the issue. If it does reboot, go to the HP support site, put in your model number of your laptop and download and install an updated BIOS. Below are the blink codes that may narrow down the problem.....
HP DV6000 LED Blink Codes
LED Component Error Condition
Blink: 1 - Caps Lock/Num Lock CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock System board General system board failure
Blink: 6 - Caps Lock/Num Lock BIOS BIOS authentication failure
Oct 22, 2009 | HP Compaq Pavilion dv6110us Notebook
No keyboard instructions
You need to press the Function button, then the num lock button. The function button may be labeled FN or F in a different color, the same color as the num lock button.
If that doesn't work, go to start, all programs, accessories, accesibility, on screen keyboard....it will display a regular keyboard on your screen, then click on the num lock key on that keyboard.
May 24, 2009 | Compaq TC1100 (/) PENTIUM M 753 1.2GHZ...
My Logitech EX110 wireless keyboard has no light indicators for CAPS LOCK and NUM LOCK. Should it have those indicators?
Your EX 110 receiver has 3 indicator lights (LEDs) that display the status of the Caps lock, Function key, and the Num lock during normal operating mode. These lights will also flash when the connect button on the receiver is pressed.
LED A: Indicates that the Caps Lock (Capital lock) key is on when lit.
LED F: Indicates that the F keys are in Standard F Keys Mode when lit and in Enhanced F Keys Mode when the LED is off.
  • Your EX 110 keyboard has an Enhanced F Keys Mode for F keys that provides additional functions you can program. See Knowledge Base article 9526.
LED 1: Indicates when the Num Lock (Number lock) key is on. This function allows the number pad to produce only numbers
Mar 27, 2009 | Logitech EX110 SP CORDLESS Keyboard/Mouse
Sony Ericsson W850i Cellular Phone Logo
42 people viewed this question
Top Sony Ericsson Cell Phones Experts
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
