Question about HP Photosmart C3180 All-In-One InkJet Printer
I have a HP C3100 print cartridge cradle cannot move
The print cartridge cradle cannot move."
Please turn device power off. Check device for a paper jam or other obstruction. There is nothing in the way that I can see. I have to repeatedly turn off the printer and restart it which will work for one time and the problem starts all over
  • 1 more comment
  • delta22ya Mar 27, 2009
    same problem..........duhhhhhhhhh.........that's why I selected the "same problem" tab
  • mlay09 Apr 01, 2009
    ditto - is it time for a new printer? Do they only last 2 years?
  • Anonymous Apr 09, 2009
    Same problem
I'm glad to see that I'm not the only one who has had this problem without a solution. I found that by moving the print cartridge (with the power on) all the way to the left, closing the door, powering it off, then powering it back on, then doing the test print (cancel and color start copy key), it would print. Had to do this 2-3 times. Then tried printing a document and it printed. So far, it 'appears' to be working OK. Hope it keeps working, otherwise I will just have to get another printer...
Posted on Dec 20, 2010
HP PSC 1500 series print cartidge cradel cannot move?
Does is look/sound like the cradle is attempting to move? Make a loud popping sound? There is small belt that is used to guide cradle across the platen. Take a closer look to see if anything is obstructing that belt. It's rubber and looks like it has gear teeth on it and fits around white gear wheels on side of cradle.
If it doesnt' move at all, a hard reset might clear it. You'll have contact HP support for that as each printer model is different. Some you just hold the power button in for a certain number of seconds.
A soft reset can be tried by unplugging power cord from printer and waiting 15 seconds then reattach power.
Oct 05, 2009 | HP PSC 1510 All-In-One InkJet Printer
Print cartridge cradle cannot move & theirs no paper jam.
Kindly check inside if there are mechanical problems. Something stuff that blocks the cartridge...dirt for example...
May 12, 2009 | Office Equipment & Supplies
HP C3100 Printer, changed black ink cartridge and I have done this several times but this time both error lights come on and say check paper & check print cartridge, plus the print cartridge does not...
I did not get problem fixed by your expert, he did not know C3100 printer and how to fix the problem,
I had check all areas of the printer for screws he said to undo and there NO screws then the session ended and I did not get the answer. Please do not charge my American Express for a none solution and a person who did not know my printer.
Dec 16, 2008 | HP Office Equipment & Supplies
"The print cartridge cradle cannot move."
I fixed this problem by disconnecting the power cord from the power-strip and connecting it directly into the wall. My printer was not getting enough voltage from the power-strip. I hope this helps.
Nov 18, 2008 | HP Photosmart C3180 All-In-One InkJet...
Change ink cartridge
Here is the procedure to change the ink cartridge
  • First Press the POWER button to turn on the printer.
  • Open the top cover.The cradle moves to the center of the printer.Open the cradle latch.
  • Slide the print cartridge out of the print cartridge cradle and discard it.
  • Remove the replacement print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strip is on the bottom
  • Slide the print cartridge firmly into the cradle. Ensure that the copper contacts the print cartridge meet the copper contacts of the print cartridge cradle
  • Close the cradle latch.
  • Verify white paper is loaded in the printer, then close the top cover. The printer automatically prints a calibration page for optimum print quality.
good luck:-)
Oct 08, 2008 | HP Office Equipment & Supplies
Print cartridge cradle is stuck ican't find where it is jammed
This might help . . . Mine finished printing one doc & then made a terrible noise & sent a message to my screen that "print cartridge cradle is stuck." When i opened door, i could see it was stuck off to the left side so left cartridge was obscured. I could not get it to budge, although i kept turning it off, gently pushing & turning it back on. Finally, i got my hand inside & determined that the little door to the left-side cartridge had popped open & was causing it to remain stuck. After some struggles (turn off printer first!) i was able to maneuver it around & close it tight. Now, all is well . . .
Apr 16, 2008 | HP Office Equipment & Supplies
HP Photosmart C3180 All-In-One InkJet Printer Logo
2,571 people viewed this question
Ben Johnson
