Question about Power Acoustik LT-980/2 Car Audio Amplifier
Wiring the hi input wires on my power acoustik plasma sphere amplifier
Yes
Posted on Feb 19, 2009
How to install a power acoustik 30th anniversary version series 4 channel 1200 watt amplifier
Power to battery. Ground to something in trunk. Remote to blue lead on radio. Rca to line or sub out on radio.
Sep 14, 2017 | Power Acoustik Car Audio & Video
Where can i buy a Power Acoustik TS1920-2 2 Channel 1920W...
you will get from
Sonic Electronix 28340 Avenue Crocker
Suite #202
Valencia, CA 91355
Nov 03, 2011 | Power Acoustik TS1920-2 2 Channel 1920W...
Got a service manual / circuit diagram for an OV2-800? I have one keeps blowing input fuse when remote wire is energized.
Hi, are you using the blue wire from the head unit to turn on the amp? The turn on voltage is more like 5 volts--not battery voltage, so you have to use the blue wire to turn on many amps.
Feb 09, 2011 | Power Acoustik GOTHIC OV2-800 Car Audio...
It keeps blowing a fuse
Generally, if you are using the manufactures fuse rating you can use a slightly higher rating and it will resolve the blowing fuses. Fuses supply resistance, if there isn't enough resistance you'll fry the system board in the amplifier. But if you have 25 amp fuses installed, install 30 amp, if you have 30 install 35 amp, 35 install 40. Anything higher will damage the amp.
Hope this helps.
A rare chance, something may be internally wrong with the amp and shorting it out which will blow the fuse.
Use the incorrect wiring of subs to the amp, you'll blow fuses and damage the amp from it turning off consistently. The amp should be running at 2 ohm stereo stable or 4 ohm mono stable.
Very few amps are designed to run at 1 ohm or less. Not to mention the subs can't handle it.
Jul 28, 2010 | Power Acoustik TS980-2 2 Channel 980W...
Power Acoustik PWM-16 Equalizer Help
You should be able to use your RCA output (Line Out) from your Pioneer to the input of your PWM-16. Then take the PMW output to an amplifier and then to your speakers. Your EQ only uses RCA's so an amplifier after
it would really bring the sound to life. The amp need not be huge as you have an output for subs also. You could try a line converter to change the RCA lines to speaker wire connections. Not sure if the output would be enough to power a speaker but it's worth a try.
Sep 28, 2009 | Power Acoustik PWM-16 Car Audio Amplifier
Watts
one is peak power the other is the more accurate RMS power.
Sep 09, 2009 | Power Acoustik TS1440-2 Synchronized...
Amp Not working!
If the amp goes into protect mode, it's likely due to shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protect Mode - Troubleshooting
If the problems are not with the wiring, follow the link at the bottom of the page to the Amplifier Repair Primer page.
Let me know if you have any other questions.
Sep 20, 2008 | Power Acoustik TS620-2 Synchronized...
WIRING
You need to order extra components in order to use the optional GPS function.. you can try checking circuit city or the Authorized Acoustik Suppliers for the products like the websites or you can check Ebay as someone might have the product
Nov 18, 2007 | Power Acoustik LT-980/2 Car Audio...
Power Acoustik LT-980/2 Car Audio Amplifier Logo
175 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
