Question about Epson Stylus C86 InkJet Printer
Epson cx7800 won't detect magenta ink.
Yesterday my colors all turned. I check the ink and they all seemed fine. I did a nozzle check and the magenta was blank. I checked the ink level and all was fine. For some reason the printer is not detecting the magenta ink, therefore my colors are all off. I have put the magenta in and out numerous times and checked the nozzels, aligned, etc... many times and still nothing. Please help!
  • 353 Answers
It seems likely that either your magenta cartridge is faulty (or empty - the ink monitor doesn't show how much ink is actually left, only the amount used subtracted from a presumed full cartridge when new). The first thing to be sure of is that you have a good cartridge - install a new one. You can save the existing one for later use once things are OK again. If this produces no results, you can now be reasonably confident that you have blocked magenta nozzles. Note that putting in a cartridge and taking it out again several times will aggravate the situation by getting air into the system.
You can now try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If nothing, repeat the process once more. If still nothing, post a new comment detailing what you have done and the results.
Posted on Mar 23, 2009
  • perk801 Oct 26, 2010
    I know the post is a couple of years old but I hope gwbm is still on line.
    My CX7800 has a small, about 3/4" square, box with foam in it. Is that the one to put dist. water in?
    Thanks for the help, Perk (:>)
Even with new inks, magenta and yellow won't print
The ink you replaced costs as much as a new printer that comes with ink. Get a new one.
Aug 27, 2012 | Epson Stylus 2200 InkJet Photo Printer
Hi i am having a epson t13 color printer but it is not printing pink color what may be the problem please anybody can help me
Hi
This normal with epson printers. The nozzles get blocked and some colors are not printed. Try to take the Nozzles print by Turning on the printer while pressing the ink replace button.
The printer will print a page with some lines, see if you can find all the colors. Cyan Magenta, Yellow & Black lines. if not hold the ink button for 5 sec., and it will clean the head try the 1st step again.
DO RATE MY SOLUTION
Regards,
Saleem
Jul 06, 2011 | Epson Office Equipment & Supplies
Replaced T0603 magenta ink with brand new cartridge. Ink levels show its FULL. But when do nozzle print check, no magenta line will print. Trying to pring something with red clip art and can't get the...
Depending on when you last used your printer it may take a few head cleans before the ink prints. Print a nozzle check after each clean (uses minimal ink).
Also be aware each clean depletes your other carts as well.
Jan 09, 2011 | Epson Stylus C88 InkJet Photo Printer
I just replaced my ink cartridges for my Epson Workforce 600 printer and the magenta and yellow colors do not print. The status shows that both are still full of ink, but when I do the nozzle check,...
Try "Nozzle cleaning" and if the problem persist, try "Deep nozzle cleaning". Try them only once or else the ink will run out very quickly.
If the ink cartridges are not genuine Epson, remove them and buy genuine cartridges. If needed, repeat the procedure with them.
Non-original consumables very often clog the printhead.
Aug 07, 2010 | Epson WorkForce 600 All-In-One InkJet...
My magenta ink will not print out. All other colors (including black) are printing out fine and alignment is good. I have run the nozzle check, head cleaning, status monitor, and ink cartridge replacement,...
Depending on the age of the printer and how often it is used it could be a dead piezo element in the magenta head or some dirt that is trapped in the feed mechanism to the head.That's why i never use refilled or poor quality substitute cartridges. Some Epson printers lasts for ages but unfortunately due to the head being permanent on all epson inkjets the only way out is for the replacement of the heads or a new printer. You could also try the magenta cartridge on another same model epson if you have access to one to see if the cartridge is perhaps a dud. Or alternatively purchase another cartdridge and check it out.
Aug 01, 2009 | Epson Stylus NX400 InkJet Printer
Epson stylus cx7800 nozzle check blue color missing. prints are all orange & yellow in color. My printer has a mind of it's own. After a few days it goes back to normal...been this way for ages.
In view of this being a CX7800 problem mis-posted in the C86 section, and, it seems, Smithbrother having lost interest in the problem, let's call it "solved by poster".
Feb 17, 2009 | Epson Stylus C86 InkJet Printer
Epson 9600 Magenta problems...
sounds like a problem with the damper/cleaning unit.
You need to clean the "pads" under where the print head parks.
Turn off power. open front cover. push it cutter (blue) and slide printhead to the left.
You will see a pad in there. this is the cleaning area. Remove and clean. Also next to this is a wiper. it is vertical and needs to be washed with some rubbing alcohol.
try these and get back to me.
Oct 27, 2008 | Epson Stylus Pro 9600 InkJet Printer
Epson CX7800 print head not working
it would be better if you get a new printer or the best to use is vodk and leave it over night to get rid of all the dryed ink
Aug 21, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Epson R800 Red Color Problem
Actually magenta is the weakest compared to cyan and
yellow using even K3 inks. Now epson is releasing
K3 with vivid magenta ink. Using any color management
I have found it very difficult to reach a real red without
a lot of tweaking in my color profiles. Now it appears
that Epson sees the problem and is changing magenta
out for vivid magenta ink to solve the weak magenta.
Jul 17, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus C86 InkJet Printer Logo
687 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
