Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
No sound at when I set SAP to English
No sound at when I set the primary audio to English. I can get audio in English if I switch to the digital Spanish channel,SAP And once I tried that trick, and it was in actual Spanish. this is only on the primary stations.
If I tune to .2 or .3 the audio is in english.
This is on several stations in my viewing area.
the problem is this set. toshiba 26HLV66
on another TV set audio functions ok
Took set 26HLV66 to service center to have tuner replaced
Posted on Feb 25, 2009
Brand new, connected to new cox cable box, video works great but no sound
if just running HDMI cable try adding audio cables too, check all your volume and mute settings in the system setup.
If you have audio on most channels, but have silence on some or all of your local network channels, you may have the Secondary Audio Programming (SAP) turned ON. Complete the following steps to turn off SAP.
  1. Press the Settings or MENU button on the digital remote.
    Result: The Settings screen displays.
  2. Choose from the following options.
If... Then... Disable SAPdisplays Press the Select button. Choose SAP Languagedisplays Use the left or right arrow buttons to choose the English setting and press Select. PREFERENCESdisplays Scroll to the Language option, select Audio, then select the option labeled Primary or the one labeled English. If the above quick fix doesn't work, there may be a problem with MTS, Stereo, or another SAP issue. Try the following:
  • Verify in the program listing guide that the program has MTS, Stereo, or SAP features.
  • Check to see if the MTS, STEREO or SAP light on the TV or VCR is on.
If the light is not on, try the following:
  • Push the MTS, STEREO, or SAP button on the TV or VCR.
  • Adjust the fine tuning on the TV set to restore the stereo or SAP.
http://www.cox.com/residential/support/tv/article.cox?articleId=81da8760-5c47-11df-ed4d-000000000000
Jan 20, 2016 | Televison & Video
We bought a universal remote to increase our access to cable channels. Some of the channels display the symbols S.A.P. and have no volume. How do we disable the S.A.P so we can hear the volume.?
S.A.P. Means Secondary Audio Program.
SAP, Mono, Stereo, Etc. You should be able to switch this from your remote. Even universal remotes should have this button to adjust sounds. Otherwise you need to go into the TV menu (not the remote) and change it from there. The only way you can change it on those channels is to switch manually. Happens a lot on these older TVs. No worries. Very common.
On many sets, the audio channel can be switched by remote control or through a SAP switch located around the tuning panel or "on screen programming." Usually, there is a setting labeled SAP, AUDIO SELECT, B-AUDIO, MTS, or MENU. By changing the setting, you should be able to select SAP. Not all TV sets are alike, so you might want to check your instruction manual for all the details.
Mar 10, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
There is no sound from the unit. I have no remote but it says it is in sap mode. can I correct this?
SAP means "Separate Audio Program" - usually SAP mode is for changing the language of the broadcast (i.e. from English to Spanish) and is also used to enhance the sound broadcast of some programs.
Not having a remote may make this difficult.... you need to find a way into the set's menu- some sets have a "menu" button on them..... some require two buttons be held down together.... look at the set carefully.... if you have the manual, it is a good time to look at it.
When you get into the menu, find the AUDIO menu and de-select SAP. Your sound should be restored.
If you cannot get into the menu, you will need a remote. Write down the brand and model of your set, go to a decent electronics store, and browse the "universal remotes". Find one that supports your set and follow the instructions to set it up for your television. You will then be able to access the menu and turn off SAP.
Jan 28, 2011 | Televison & Video
No sound on a few channels. all others have sound. 26 in vizio.
Since you have sound, the audio circuits are working. The most common cause of this is to have the TV set to use SAP. There are many channels where this is an unused option and others that broadcast the same audio on the standard channel as well as SAP. If you change the channels and get Spanish rather than English for example, you have SAP turned on. Check the audio menu for SAP status.
Let us know what you find.
Dan
Dec 06, 2010 | Vizio L32 32 in. LCD HDTV
Tv has sound on all channels but one. Had sound but 30 min later no sound. When watching two tv's on same channel the one with no sound was lagging behind other tv not in sync as all other tv's in house...
Check to see if your audio source is set to SAP. This stands for secondary audio program. For example, some stations broadcast english and spanish. Some stations broadcast english and nothing. If you are on a channel that broadcasts english and nothing, and you are SAP setting, you will hear nothing.
Jul 03, 2010 | Sony KDF-E42A10 42 in. LCD Television
Model #VV2000 S # BOAA20050 CHANNEL SPEAKING SPANISH... NEED TO CHANGE TO ENGLISH QUASAR TV
Use your remote control to check the TV SAP settings. This is "second audio program" and is often used to carry the TV sound in another language. If SAP is turned on you won't notice it unless you tune to a channel where the SAP signal is present. Most remotes have a single button to control the audio settings, so it's easy to turn the feature on without knowing it by bumping the button. Turn off SAP and you should be back to English.
Mar 06, 2010 | Televison & Video
Vizio gallivea some tv channels are in spanish and no sounds
GO into the customer menu with the remote and look at the audio settings---I would bet you will find SAP has been selected; this will give you some channels in spanish( SAP means secondary audio program) Monday night football and some other programs offer this for Spanish speaking people. Change the setting to Stereo or Mts away from SAp
I do this here for free so if this helps you give me a vote here---if you have questions or need help contact me by replying to this post.
SD TECH (SAN DIEGO)
Aug 29, 2009 | Vizio GV42L 42 in. LCD Television
Sharp Liquid Crystal TV - Flat Screen - 1.5 years old
Go into the menu and under AUDIO and make sure that the sound is set to STEREO, and not SAP (second audio program). If you have a separate setting for SAP then shut it off.
Apr 23, 2008 | Televison & Video
Problems with Emerson EWC27T3 27 in. TV/VCR/DVD Combo
You'll need to set your audio options to back to normal, not SAP...accordianman
Oct 12, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
No Sound on TV
I did not answer the original question you posed but the SAP is the acronym for Separate Audio Program and is used to provide spanish for instance on a show which is broadcast in both english and spanish. The problem is not all stations have audio on the SAP. If your audio processor is set to SAP and you switch to a channel which has nothing on SAP you loose audio. I'm guessing someone suggested this prior to this post. If you checked your TV and it is not on SAP that eliminates that. I would look at the audio circuit for problems. Either no power to the audion circuit, bad solder joints, blown output IC or possibly a blown speaker. I know the last one is remote but it does happen and it never hurts to check the simple problems first. Besides you aren't embarrassed later when you find out it was something simple. If you are going to check these issues out remember safety. Good luck.
Jun 08, 2006 | Philips TS2746C TV
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
196 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
