Question about Epson Stylus CX7800 All-In-One InkJet Printer
How do i change cartridges in epson stylus sx205?
  • 3 more comments
  • Anonymous Mar 02, 2009
    i have the same problem xD
    can't seem to get the cartridge compatment open. all ink is run out and need to chenge it. tried for weeks. please help.
  • Anonymous Mar 22, 2009
    same
  • Anonymous Mar 31, 2009
    I am unable to figure out how to get the ink cartridges to stop at the opening so that I can open the compartment and change them. Manual instructions seem to be written for another model. Online "help" is useless. I, too, am now out of ink. If anyone out there has figured it out, please share. Thanks.
  • Anonymous Apr 15, 2009
    same
  • 3 Answers
The SX205 is a bit of a pain to use. There doesn't seem to be a way of changing an ink cartridge unless the printer decides it wants to let you. I managed it by employing fairly brutal tactics. I opened the lid to expose the works, switched the printer on, and with my finger over the switch at the mains socket I waited while the printer went through its start-up procedure, then when the ink carrier was in the right position to make a change, I quickly switched the power off. You have to be really quick to catch it in the right position, and you might need to try more than once to get it right. After changing the cartridge, I switched the mains back on, then switched the printer back on, and everything worked OK after that. It seems crazy that Epson hasn't incorporated a way of doing this into the design. Its certainly the worst Epson printer I have owned from the point of view of ease of use. Photos from it aren't very good either. Dinty
Posted on Aug 28, 2010
Hi
My sx205 is feeding the paper through when i ask it to print but it is not putting any ink on the paper - even though the cartridges are full man it recognises they are full. Any ideas?
Posted on Apr 07, 2011
  • 54 Answers
SOURCE: ink changing
Click HERE for the User's manual.
See page 34 on the manual to see how to replace the inks. There's also illustrations and explanations on how to get the ink chamber to the center so you can replace it.
Posted on Apr 14, 2009
Rossiman46
  • 50 Answers
SOURCE: Epson stylus sx205 won't print on my macbook pro
Def sounds like a driver error, do you get a yellow mark next to your printer driver or is it ok?
You could try & see if there is a more recent driver from epsons website
Posted on Nov 06, 2009
  • 2692 Answers
SOURCE: How do you change ink cartridges on Epson Stylus cx 7800
Download your users guide for instructions.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=58773&prodoid=56291070
Posted on Jan 20, 2009
cns assoc
  • 677 Answers
SOURCE: EPSON Stylus SX600FW printer. Recently changed
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Jan 30, 2010
SOURCE: changed black ink cartridge for epson stylus d120 but not working
Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
i.                     Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii.                   The Cartridge electronic panel  is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning.  This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Posted on Mar 24, 2010
Epson Stylus SX205 Printer. i have replaced all 4 ink cartridges and it says all 4 has not been recognized. I have noticed that if i take 1 of the cartriges out, it will recognize the 3 remaining...
You are cetain you have put the correct cartridge in the correct slot? Snapped them all into place properly? These are new, Epson cartridges? Review the instructions found in the printer for installing cartridges. If yours are Epson cartridges and you still have trouble, return the cartridges for replacement where you bought them. That is the benefit of using genuine OEM products.
Thank you for your question @ FixYa.com
Aug 15, 2011 | Office Equipment & Supplies
Hi there i have lost my epson stylus sx205 installation cd - how can I get the printer to work please
Hello and Welcome to FixYa!
You can download the driver for your product from the vendors site, kindly navigate to this link and see under driver tab, you can also download the easy print software.
Concerned, Nooh.
May 12, 2011 | Office Equipment & Supplies
I have bought epson sx200 ink instead of sx215 will this still work as if not i will have to return it unopened???
Just have a look at the generic cross reference chart for aftermarket ink jet cartridges & you will see the one cartridge suits ten different Epson models
BLACK >>> T0891 Compatible; Ink contents 19ml
Stylus S20, S21, SX100, SX105johncsuk123
Stylus SX200, SX205, SX215
Stylus SX400, SX405, SX415
Jan 07, 2011 | Epson Office Equipment & Supplies
I have an epson stylus sx205 device all in ane, at
Please go the link and download the drives and softwares related to the epson stylus sx205 all in one device. Its for Win XP
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=YZnBT5wk60ZylQ3Jsb6xH7slmxZVvulh&tc=6
Jul 07, 2010 | Epson Stylus CX7800 All-In-One InkJet...
Replace ink cartridges
1 - Open the top lid 2 - Open the ink cartridge carrier 3 - Shake the ink cartridges 4 - Unpack the ink cartridges 5 - Remove the yellow tape from each cartridge as you get ready to install it, but not before 6 - Install each color cartridge into its corresponding color slot pressing down all the way until it "clicks" 7 - Close the ink cartridge carrier 8 - Close the top lid
At this point the printer should charge its ink cartridges. Let this finish before using your printer.
Hope this helps!
Feb 18, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Nov 06, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Can't change the ink on my Stylus SX205
OK... based on your use of English, I'm guessing you are in the US, but I may be wrong... The point, your printer was not intended for the US market, and was sold in Europe, and other places, but not the US... That's why the US site has nothing for you. If you go to the Netherlands site, or any other market where this printer was sold, you can find the downloads of the manuals and setup guides:
http://esupport.epson-europe.com/FileDetails.aspx?lng=nl-NL&data=YZnBT5wk60ZylQ3Jsb6xH2uqBNxDB+em&id=323243
Note that most of the documents include English.
Good luck.
Jun 28, 2009 | Epson Stylus CX7800 All-In-One InkJet...
I have an Epson stylus sx205. When I try to print a document (i.e from a web page) only the pictures/photos and limited text as in the titles and maybe sub headings print. All the other text is missing. ...
My Epson SX205 shows ink cartridges empty, when they are not and or does not recognise them as being compatible. Is there software available to over ride this problem
Jun 19, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Printing Problems: Epson Stylus SX205
UNPLUG THE POWER CORD AND AND THEN PLUG BACK IN IT NEEDS TO ''RESET'' ITSELF.
Jan 24, 2009 | Office Equipment & Supplies
Epson Stylus CX7800 All-In-One InkJet Printer Logo
2,673 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
