Question about Frigidaire Dishwashers
Water not draining
Fridgidaire diswasher seems to be clogged somewhere as water will not drain out of it.
  • Frigidaire Master
  • 19,396 Answers
You need to access to the drain hose, located under the bottom panel, and check that this is not clogged, if you do not find anything in there, check that the connection to the drain line outside the machine is not clogged.
If still no luck, then check that the drain pump is not faulty, that is possible.
You can find schematics and replacement parts by entering model number here.
Posted on Feb 18, 2009
  • 13,433 Answers
How do I fix problem with water "very slowly" draining from the washer?
The "somewhere" you describe is the pump. It could be clogged.
May 12, 2014 | Kenmore Washing Machines
Diswasher water isn't draining?
It is most likely the drain pump. If the drain pump passes a tech's test ok, have the drain passage checked for clogs.
Apr 17, 2012 | Dishwashers
My whirlpool quiet wash plus diswasher is not draining water. How do I fix it?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 14, 2011 | Dishwashers
My diswasher has alot of water in it after we run the dishers thru. May be a clog? How can i check if there is a clog?
Hi
Daniel
Jun 19, 2011 | Hotpoint Dishwashers
The water will not drain out of the diswasher.
Hi
Daniel
Jun 16, 2011 | Dishwashers
My diswasher will not drain, it seems to have completed the cycle but the basin is full of water when it finishes.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Daniel
Mar 25, 2011 | GE 24 in. GSD6200G Built-in Dishwasher
Water is left in the cavity beneath the base filter
water under the filter is normal. Most diswashers do not drain completley- this acts as an air lock to prvent odours coming thru the drain hose
Jun 29, 2009 | GE Nautilus 24" Built-in Dishwasher
Diswasher airlock
By the airlock , you mean the air gap? .If the water is coming out of you air gap that means the hose that connects the air gap to your drain is clogged or your drain itself is clogged.Check the hose that connect the air gap to your drain(or disposer), check air gap and clogged disposer opening
Dec 01, 2007 | Bosch 24 in. SHU66C05 Stainless Steel...
Dishwasher did not drain all the water
Your sink drain is clogged and the back pressure is not allowing the dishwasher to drain competely. Do not use a liquide drain cleaner, it will damage your disposal. take apart p-trap hopefully the clog is there, otherwise the line will need to be snaked.
Sep 22, 2007 | Roper 24 in. RUD4000M Built-in Dishwasher
Bosch Diswasher not draining
Soyben, you need to check to see if either the drain hose or syphon break at the sink is clogged. The drain motor on this model is not a bilge pump that will remove water from the base. Therefore Im leaning on a restriction somewhere. Other than that you may have to check for debris in the drain sump. Check these areas out first...Catriver...post back
Aug 27, 2006 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
141 people viewed this question
Top Frigidaire Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
