Question about GE Microwave Ovens
Microwave won't run
Everything else seems to work, can this be a fuse
  • 52 Answers
Open the casing and look for a control fuse replace and all should be fine
Posted on Feb 21, 2009
Ge jvm1650wb005
one of the internal door switches, the high voltage circuitry or the circut board may have a problem to resolve this you need a qualified appliance technician
Jul 28, 2008 | GE JVM1650 1000 Watts Microwave Oven
Electrolux microwave model fgmv185kfa made a loud pop and now won't heat anything and sounds louder than normal when running. Everything else seems to b working fine
SOUNDS TO ME LIKE YOU BLEW A FUSE WHICH IS INSIDE THE UNIT. IF IT'S UNDER WARRANTY TAKE IT BACK BECAUSE IF YOU OPEN UP THE CASING & FIX YOURSELF THIS VOIDS ANY WARRANTY
Dec 24, 2012 | Microwave Ovens
Won't run
see this causes and fix it. God bless you
No Lights or Power, Unit seems Dead First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
Test the switchs door see diagram
Oct 10, 2012 | Frigidaire FMV156DC Microwave Oven
Microwave was run empty and now it won't run. Display works but no fan or microwave. What to do?
The magnetron does not fair well when running empty, the thermal fuse usually kicks in if a metal object was put in by mistake, but should be checked along with the door switches.
May 31, 2012 | Panasonic Microwave Ovens
I am having problems with my Maytag microwave MMV1153AAWMaytag microwave MMV1153AAW. Everything seems to be working except it does not heat up the food. Light goes on, plate rotes, timer works, but at the...
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
If it is the type with an "Invertor", they are not user serviceable and should be directed to an authorised repair agent for continued safety, otherwise if conventional;
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Apr 21, 2011 | Maytag MMV1153A Microwave Oven
EVERYTHING WORKS NO NOSIES SOUNDS LIKE IT IS WORKING WILL NOT HEA
could be the power fuse inside the microwave, you have to remove the casing to access these.large power fuse would seem to be the problem, this is normally 10 amps but could be 13 amp. there is also a control fuse that control the power relays
if this is blown the relays could be at fault
Feb 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have Problem with my microwave
it may be just a fuse , but if the fuse inside the microwave blows again then there is something else wrong and it would need to be tested to find the problem and fix it
so the fuse inside needs to be check and or replaced and if the microwave powers and works ok after replacing the fuse , then the other fuse was just bad
Jan 11, 2009 | Emerson MW8108P Microwave Oven
My micro wont heat the food but everything else seems ok
I have a GE Spacemaker Microwave, model # JVM1650WB008
The lights work and everything runs in a normal operation, it will not heat the food. I have changed the fuse and still the same, no heat.
Oct 05, 2008 | Microwave Ovens
Microwave stopped working
Generally, you get something unless the fuse inside is blown. There is generally a fuse inside the unit when you remove the button package. First, make sure that the outlet you have is good. Plug something else into it and see that it works.
Dec 16, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
78 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
