Question about Intel D865PCDL (735858167413) Motherboard
No power to motherboard Intel D865PCD, replaced pwrsupply with known good one, no power to cooling fan. Blue board light comes on. I removed all connectors, this is a new board.
  • jhoya1 Feb 18, 2009
    Thanks for the quick response. Pwr connector is connected. Front switch is ok. I have come accross this once before but it has been a long time and I don't remember what i did to fix it.
  • Intel Master
  • 4,806 Answers
Hi there.
make sure that the power connector (it will say PWR on it) is connected to the pwr on the front panel >>No power to motherboard Intel D865PCD, replaced - 3f59fa1.jpg it will look something similar to this.
Post back if no results
Good luck and thanks for using Fixya!!!
Posted on Feb 18, 2009
  • Lee Hodgson
    Lee Hodgson Feb 18, 2009
    Hi again
    Go here and use the information to troubleshoot that intel motherboard, it should help with pics and diagrams:
    http://support.intel.com/support/motherb...
    Good luck with it
P8P67 EVO Won't Boot with power to board
This is almost always the power supply. How exactly did you "check the power supply"? You checked all 12 or so voltage outs under load?
If replacing the power supply doesn't work, replace the motherboard.
Dec 24, 2012 | ASUS P8P67 EVO LGA 1155 Intel P67 SATA...
I plug it in, and the fans spin briefly, but the computer doesn't seem to get power. When I unplug the power supply, however, the green light in the back of the power supply turns on, as well as a green...
Because the capacitors in the PSU retain a charge, the LED lights will glow after the power is switched off, these will fade out after a few seconds.
It would appear that at first glance, the PSU is indeed bad and the only way to eliminate this is to replace it with a known working one (I'm also assuming that the 4 pin yellow and black CPU plug that comes off the PSU is plugged into the motherboard?)
If this works than it was your PSU
If it does not work, there are several other possible reasons why this is happening:
Before doing the tests below, physically inspact the motherboard. Look for blown or buldging capacitors (the small cylinder objects), brownish residue, bulging sides etc are symptoms of a dying mobo. Check there are no objects causing a short on the board (you may need to remove the board to check) also, check the brass standoffs are not contacting the uninsulated parts of the board
  1. Faulty hardware: remove all the power rails to the drives and optical drives and test
  2. Bad Ram: remove all ram modules reboot and see if it beeps several times, replace each ram module in turn and retest
  3. Bad CPU (common fault), replace CPU with a known good one, retest.
  4. Bad Motherboard power regulator: No solution for this other than to replace the board
Feb 07, 2011 | Gateway 556GE Intel Pentium 4 630 3GHz(HT)...
FAN OK BUT NO DISPLAY
I like that. Kinda' rhymes. "Fan OK but no Display"
Problem is your Processor isn't turned on.
You have a bad Power Supply.
> Weak voltage power rail.
You probably have a 200 to 300 Watt power supply. (SMPS)
1) ALL of the LED lights together use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts.
3) A typical Processor can use 51 to 125 watts. Depends on what Processor it is.
The Intel D845GVSR motherboard uses a Socket 478 processor socket.
Supports Intel Celeron, Intel Pentium 4, and Intel Celeron D, that utilize a Socket 478 processor socket, and have a maximum FSB of 533MHz.
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_Chipsets
Utilizes the Intel 845GV motherboard chipset.
[ Intel 82845GV Northbridge chip, and Intel ICH4 Southbridge chip ]
89 Watts is the maximum wattage, that can be used by a Processor for the Intel D845GVSR motherboard.
Power Supply has enough power to light LED lights, and spins fans, but not enough to turn the Processor on.
No Processor operating, No computer.
No computer, No video signal to the monitor.
(No Signal)
Do you have access to a KNOWN to be good, compatible Power Supply, for a test unit?
Motherboard Manual in PDF file form:
http://www.intel.com/p/en_US/support/highlights/dsktpboards/d845gvsr
Under the heading > Documents and Guides, left-click on > Product Guides for D845GVSR.
Then left-click on the first file listed.
Product Guide - PDF File Name: D845GVSR_ProductGuide_English.pdf
Nov 03, 2010 | Intel D845GVSR Motherboard
Motherboard Cpabilities
Look at the large chip next to the CPU slot. If you see 865G then click on this link
http://www.intel.com/support/motherboards/desktop/D865GLC/sb/cs-008974.htm
The manual can be found at:
http://downloadmirror.intel.com/15206/eng/D865GBF_D865GLC_ProductGuide02_English.pdf
If the notation is 865P then click on this link:
http://www.intel.com/support/motherboards/desktop/d865pcd/sb/cs-010434.htm
The manual for this board can be found at:
http://download.intel.com/support/motherboards/desktop/d865pcd/sb/cdenglish.pdf
The boards are very similar. The G chip board can handle 4MB RAM. The P board only 2MB.
If you can give me the model number or the Service Tag number of the computer, I might be able to give you more info.
Thanks for using Fixya.
Feb 05, 2010 | Dell (E210882) Motherboard
COMPUTER WON'T POWER UP
Three are a couple things you can check/try. Remove the memory, (If you have more than one DIMM load only one). Boot the system. Try each dimm in turn one by one. If your board is old. I see three ISA slots on the board, so it's old. It is possible the thermal tap or thermal grease may have dried up. (This will cause your CPU to overheat & shut down). The grease is located between the heatsink assembly & the CPU. Remove the heatsink assembly. Take a clean rag with a little alcohol on it & wipe off all old thermal grease. (Care full, do not over soak the rag & do not scratch either surface, heatsink or CPU). Double check all connections while in the case. Try booting again. Most CPU fans last for 50,000Hrs or five years. If the steps above did not help, you may need a new heatsink assembly, this will come with a new fan. Lastly, if all of the above has not helped. Check the voltage of the cmos/bios battery. It should test 3volts DC. If it test under replace it. On the outside shot, if you have done all of the above try another known to be good power supply. (If your CPU was bad nothing would turn on, not even the fan).
Give it a once over!
Good luck lieutenant_1!
Thank you for using fixya!
More question, post here.
Mike
Dec 09, 2008 | Intel Motherboard
I bought a mother board from a swap meet but it didnt come with the wiring up diagram and im lost as to how to wire it up only for the power reset etc.. not sure which way they plug into i think i have...
Hi kjstenny, not sure where you saw the board E210882. This is not a valid Intel model number. The Intel D865GLC is a valid model number & you can download the manual for this at the link below:
http://download.intel.com/support/motherboards/desktop/d865glc/BFLC_English.pdf
Main Intel link for D865GLC:
http://support.intel.com/support/motherboards/desktop/D865GLC/LC_manual.htm
MB layout page 14 & 15. Than see page 13 block D, J9J1 Front panel pins. Page 43 for jumper connections.
Intel D865PCD (Matched). Front panel, page 34 & 35. Download manual at this link:
Main link: http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1671&lang=eng
Intel D865PCK - (No Match). (Or no longer listed).
D865PE50 - (No Match). (Or no longer listed).
The most common wire color for each 2-pin connector will be negative, including the color black.
Good luck kjstenny!
Still need help, just post your question.
Mike
Dec 03, 2008 | ASUS A7S333 Motherboard
Intel motherboard replacement
Did you check to make sure the connector for the front panel buttons are connected?
Lou
Aug 30, 2008 | Intel Motherboard
Asus 945 motherboard is in stand by mode. When I power on , the LED of mother board is glow The cpu fan just jurking and stop. And the LED of motherboard is still now glow.
Hi kausik, that green led you see on the motherboard is just letting you know there is power to the board. (This is normal).
You'r CPU fan jerking & stopping is a bad thing & has nothing to do with standby mode. Your CPU fan needs to be replaced.
There are a bunch of Asus 945 boards, just click the link to see.
http://support.asus.com/download/download.aspx?SLanguage=en-us
If you are able to remove the fan from the heatsink than you may be able to buy a fan from here.
http://www.tigerdirect.com/applications/category/category_tlc.asp?CatId=99&name=Cooling-Products
Most people replace both heat sink & fan.
Have more questions, feel free to ask.
Good Luck!
Mike
Apr 18, 2008 | Intel Motherboard
Toshibas are dieing on me.
How about if you boot with just the battery in? Does the battery charge? Possible solution include: remove and replace memory chips to make sure they are seated correctly. Check with a known good power supply. Almost sounds like a motherboard issue to me. Plenty of laptop problems are related to bad solder joints on the motherboard, unless you or someone you know can open it up and find a bad joint the only solution is mother board replacement. Try reseating the memory first.
Dec 07, 2007 | Computers & Internet
Computers & Internet Logo
65 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
