Question about NEC MultiSync VT540 Multimedia Projector
NEC MultiSync VT540 not turning on - Temperature error
I found an old NEC MultiSync VT540 and I am unable to turn it on. The Power light is steady Amber & the status light is blinking red (4 sec interval).
-The projector is not warm
-Cleaned the both air filters
-Pressed the HELP remote when the projector was in standby for 10 seconds
-Removed & re-inserted the projector Bulb (It does not look burned out or broken)
The user guide does not state how to fix this issue. Any tips on what else I can try would be appreciated. I do not know how many hours are on the bulb itself.
if the status light is blinking red in 4 sec interval it means that there is something wrong with cooling system. you shold check if there is a thermostat failure or if there are any switches that are not turned on. i suggest you to open the device (using screwdriver) and check if there are any switches broken or damaged.
i had pretty much the same problem (one second interval). i took off the cover and there was a broken switch and i just short-circuit it and now it works
Sorry for my english
Posted on Mar 06, 2009
Lost remote for projector VT540 and need to reset lamp
only by using the remote to reset the timer
Press and hold the OFF button on the remote panel, for 10 seconds
Mar 27, 2013 | NEC MultiSync VT540 Multimedia Projector
VT540 projector does not receive the input impulse from the laptop..... just a blue screen
try the Factory Default that's located in the User Menu... located at Image Options Menu, which is in the Advanced Menu. what this does is reset the settings and/or adjustments to factory preset levels.
May 31, 2011 | NEC MultiSync VT540 Multimedia Projector
How can I reset a VT540 without a remote it has steady orange and red lights on so is in standby after bulb change
Press the Help button on the remote control for a minimum of 10 seconds while in standby mode. When the lamp time clock is reset to zero, the STATUS indicator goes out.
Apr 04, 2011 | NEC MultiSync VT540 Multimedia Projector
Steady red status light on NEC VT45 projector. Would not POWER ON. LAMP was replaced with a new one
the power supply on that model seem to go bad after a while. the caps aren't properly reted it's power needs. they dry up. if you are good at soldering, replace c1 on the board (big cap) with a cap that has a slightly higher voltage rating. or replace the whole power supply. you might not be able to get one from nec, but you can try
Dec 16, 2009 | NEC MultiSync VT45 Multimedia Projector
Picture will not appear from cable box to nec projector
try the signal(picture)first in television.if it is ok.check projector for right input selection.if it is not check your cable company and ask for help.
Dec 06, 2009 | NEC MultiSync VT540 Multimedia Projector
I hooked my new computer up to my NEC Multisync 1700V moniter. When I power the moniter up the GREEN light comes on until I get a "no Signal Message" and then the amber lihgt comes on.
hi, hook up your old one and change the refresh rate to 60 or 70 hertz, go 2 display properties, then the settings tab, then advanced,then monitor. and set it as i said. turn off computer after you change settings. hook up the nec, you then should be good 2 go. good luck! and please rate this solution. if you need further help, reply.
Apr 13, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Nec projector vt440 wont turn on
Hello. First check the lamp! From your description, it sounds like the projector is telling you that the lamp needs to be replaced. In "eco mode", when the power is green and the status is steady orange, that is the error message. In "high brightness mode" the status will be steady red. Hope I helped you.
Feb 22, 2009 | NEC MultiSync VT440 Multimedia Projector
Power light steady green but monitor goes dark after 4 secs of video
The video card in the computer could be going bad too or the driver for the video has corrupted. Try reloading the video drivers in the PC first.
Mar 29, 2017 | NEC MultiSync LCD1770V - Flat panel...
Pink tint when usig the RGB component cable
Check the green signal lead - if one of the RGB leads doesn't make good contact, the picture will take on an odd tint that doesn't always look like it's missing one of those colours. For some reason, the green is always the most common one to fail.
Feb 28, 2008 | NEC MultiSync VT540 Multimedia Projector
VT540K Won't power on
needs new lamp
Feb 13, 2008 | NEC MultiSync VT540 Multimedia Projector
NEC MultiSync VT540 Multimedia Projector Logo
862 people viewed this question
Top NEC Office Equipment & Supplies Experts
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
