Question about Microwave Ovens
Everything works except the microwave? could it be a fuse
  • 544 Answers
Hello thank you for using Fixya.com..
try to check the cord of your oven connecting to your a/c if it is working properly and flowig the current..
if not i prefer to suggest you that take your oven to a technician and ask them to chabge the fuse because one of the reason why it is not working is busted of fuse....
hopefully you will follow my suggestion.
Posted on Feb 18, 2009
  • 10,594 Answers
Yes, it can be a fuse, rectifier and even megnatron tube.
  • Microwave Ovens Master
  • 13,433 Answers
If everything works on the microwave but theres no heat, then its unlikely to be a fuse, if you got lights and motors are runing the lcd is lid, then its not a fuse problem.
it could be a defective door switch or a problem in the high voltage section
  • 19,396 Answers
There must be a fuse on the MW control board.
  • Ginko
    Ginko Feb 18, 2009
    Microwaves often have a fuse on the control board.If this is a unit with oven and microwave , there may also be a fuse unit connecting to the wiring harness behind the rear panel.
    Give me the make and exact model number to know more.
  • Ginko
    Ginko Feb 18, 2009
    If the problem is a fuse, or the wiring harness to the MW, then you will have no power at all on the microwave.
Everything working but no heat
Timer working but not heating - Microwave - iFixit
https://www.ifixit.com/Answers/.../Timer+working+but+not+heating
iFixitMy fridgadire microwave oven is not heating, it acts like it is heating by the timerworking and .... I have a GE Profile and everything worked but it would not heat.
Microwave Not Heating Troubleshooting Guide - YouTube
? 2:45
https://www.youtube.com/watch?v=_3SbJueEn1w
Aug 31, 2012 - Uploaded by Repair.com
If the water is not consistently warm, you've confirmed there's a problem. ..... Everything works except the microwave- it wontheat anything up. ... How to Fix a Microwave Oven - Simple Fuse Replacement - Duration: 18:04. by
Nov 28, 2015 | Electrolux E30SO75FPS 1000 Watts Microwave...
Frigidaire microwave fmv156dcc
There could be an open fuse inside or a failed magnetron.
Mar 27, 2014 | Microwave Ovens
It does everything except heatinig up food. Model # JVM 3660 SD 001
The magnetron is not working. This open it and check to see if it has a blown fuse. Some microwave would have seperate fuse for the heating power. If fuse is good. You may be able to get a used magnetron from another microwave. Somtimes pawn shops would sell microwave for 5 or ten dollars just because it doesnt have a turnplate inside.
Jul 07, 2010 | General Electric Microwave Oven
Everything seems to be working except food won't get hot
your 5kv fuse connected to the magnatron is probably blown..it looks like a white casing with two wires coming out of it..fuse is inside this..be careful please
Apr 21, 2010 | GE XL1800 1100 Watts Microwave Oven
Everything on our microwave still works( Clock,lights, fan) except it will no longer heat anything you put in it
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Oct 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Everything works except the heating of food
Try replacing the fuse first. Cartidge ceramic fuse.
Aug 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Everything works except heat
Sounds like you've had a failure in the microwave portion of the unit.
Microwave not heating problems when the timer/controller board appears to function properly, are related to the following components -
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
Jan 24, 2009 | GE JE1540 Microwave Oven
Everything works perfectly (oven, grill, etc) on my combi microwave except the microwave is it only a fuse? if so how do I change it? or should I just bin it
It is a safety fuse !but somthing has made it blow,and needs checking by microwave engineer.Possibly door interlock fault.Micros can kill even when UNPLUGGED be carefull. If you live in cheshire we can FIX IT Grandadfixer
Nov 05, 2008 | Microwave Ovens
Everything works... except the heat!
Maybe one of the fuses, get an engineer to look at it, for safety reasons.
Mar 03, 2008 | Kenmore 66469 / 66462 / 66464 Microwave...
Everything works except it doesn't heat anything
no, just 1 main fuse for everything. there are temp safety devices though, and door closed safety switches. Most likely failure though is the magnatron.
Dec 30, 2007 | Kenmore 64002 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
