Question about Frigidaire 22.6 cu ft Side By Side Counter Depth Refrigerator, FSC23F7D
FRIGIDAIRE FSC23BBDSB0 lIGHTS AND LED's FAIL IN REFRIGERATOR SECT
TO GO ON WHEN DOOR IS OPENED IN REFRIGERATOR SECTION. ALL BULBS ARE TESTED AND FOUND TO BE
GOOD AND ALL OTHER FUNCTIONS ARE NORMAL IN
BOTH FREEZER AND REFRIGERATOR COMPARTMENTS.
SOURCE: Top Freezer section working Bottom Refrigerator not getting cold
I have a side by side jenn-air refrigerator, the freezer compartment working fine and making ice like it should, however the refrigerator compartmant is not cooling, no cold air is felt, I need advise.
Posted on Mar 23, 2009
tborn6
  • 700 Answers
SOURCE: Freezer door not sealing well (Frigidaire side-by-side)
your house may be settling and now the refrigerator needs to be tiloted back slightly. take run the adjusters on the front in a little until the doo closes by it self.
Posted on Mar 29, 2009
  • 190 Answers
SOURCE: Frigidaire Side-by-side not cooling or freezing
Dear customer,
We suggest u to do the follwoing checks,
  1. Hissing and popping is normal on frost free refrigerators, it is the defrost heater
  2. Check that the refrigerator is level
  3. Check the drain pan
  4. Check the condensor fan
  5. Check the evaporator fan
  6. Inspect the compressor mounts
As for th freezer's problem checkout the,
  1. Check the temperature setting
  2. Assure that there is enough room for air flow in the freezer or freezer
  3. Check for air flow restrictions in vents
  4. Test the temperature control
  5. Clean the condensor coils
  6. Check the door seals
  7. Test the door switch
  8. Test defrost heater
  9. Test defrost timer
  10. Test evaporator fan
  11. Check for a clogged drain tube
  12. Check for refrigerant leak.
Thank you. Plz rate the solution..
Posted on Apr 08, 2009
  • 105 Answers
SOURCE: refrigerator door pops open, frigidaire top
The refrigerator needs to be perfectly leveled side to side dn should pitch back slightly. Also look at the plane of the doors, that is to say that they should be squared to the cabinet. If they are sagging, you may need to adjust the hinges.
Posted on Apr 17, 2009
  • 7 Answers
SOURCE: Maytag side by side Model MSD2756GEW Freezer OK, Food sect hot
First you need to see if the venting from fzr to refrig is blocked......then check to see if there's frost on back wall of fzr. Frost would mean defrost heater is not working. *** It helps a lot also to know which model & serial you have. Those numbers can be found inside the refrigerator section on the side wall or ceiling on a tag.
Posted on May 05, 2009
The fault warning sign is beeping when i open the fridge door
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
http://www.appliancerepair.net/refrigerator-repair-1.html
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
Feb 19, 2017 | Refrigerators
Why would the LED indicator light illuminate for the water and crushed options, but not for the Ice option. The icemaker is working and dispensing ice.
I appreciate your post, Cindy!
From what you have described your LED indicator will light for water and crushed option but not for the ice option on your Frigidaire refrigerator. This could be a possible issue with the light on your display. Unfortunately you are unable to change out the light and the whole display would need to be exchanged. If you need assistance replacing the board I would recommend seeking help from a professional technician. -Matt
Aug 12, 2015 | Frigidaire FGHF2366PF French Door...
Model E402b. Why is the alarm going off?
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jun 02, 2015 | Fisher and Paykel Refrigerators
Open door 18 beeps lights flash red green fridge not cooling
Mar 14, 2015 | Refrigerators
Beeps about 6 times when fridge door is opened.
Mar 11, 2015 | Refrigerators
Why does my Hotpoint ff187e frost free fridge freezer lights flash and the alarm sound even after reseting them as per manual. rest them ok for a while but then restart what's the problem?
Jul 27, 2014 | Hotpoint Refrigerators
How do I reset the temp on my frigidaire professional series fridge
Hi the best is to refer to your booklet or operational manual.However if it has been misplaced,open your door and you will see a button indicated TEMPERATURE CONTROL. when you depressed this button,corresponding temperature LED will illuminate say one for fair.two LED ,three LED and so if all LED are on that is too cold
Jun 09, 2014 | Frigidaire Professional Series PHS68EJSB...
Inside led lights of KitchenAid KSF26C4XYY not illuminate
There is a switch (somewhere on the door frame) that has to close to turn the lights on when a door is opened . They are pretty reliable, but if a switch fails due to a mechanical problem, you can sometimes tell by the feel when you operate it manually. If your switch seems OK, then I'd wonder about the power supply for the lights (which I know nothing about).
Apr 15, 2014 | KitchenAid KSF26C4XYY 26.0 cu. ft. Side by...
No water at door (or ice!)
first off manke sure t hat yo keep the paddle depress fpr a few mins, it will need to fill a resevoir inside the regfrig sect, may take am in beofre the water flows freely
Mar 08, 2009 | Frigidaire Refrigerators
Frigidaire 22.6 cu ft Side By Side Counter Depth Refrigerator, FSC23F7D Logo
46 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
