Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
HP C4100 photosmart all-in-one
Get error recycle power when trying to scan. Also on printer itself get ...scanner failure-unable to scan or copy.
Printer is 2 yrs old and this is something new that is happeneing. When turn printer on, and it is "booting" up, receive an error message on the printer view screen "Scanner Failure - Unable to scan or copy". Have to press OK to allow the printer to complete its "boot-up" so it can print.
  • 4 more comments
  • pastorcasey Feb 28, 2009
    exact same problem but mine is on the C4180
  • djhachey Mar 01, 2009
    The same problem/error message with HP C4180 All in One
  • Anonymous Mar 20, 2009
    Same deal with the C4180 ... wtf
  • Anonymous Mar 23, 2009
    i have the same problem but when i restart it, i am able to make a copy before if fully boots up. After the copy is made it says again "scanner failure: unable to scan or copy"
  • Anonymous Mar 27, 2009
  • Anonymous Apr 06, 2009
    no detect scanner , and
    up in the team, said a model ( C4180 all in one) and when you install someone else's model. ( C4100 series).
My HP Photosmart C5240 will print from computer but will not scan or make copies.
Is there any error message displayed on the control panel of the printer just like one of the following:
Scanner failure, power off and on
Scanner System Failure
Scanner failed, cannot make copies or fax
Scanner failure. Unable to scan, copy, or send a fax
Scanner failure, cycle power
You may want to try following these steps:
1. Check if the scanner light does turn on when you initiated the scanning process, if not you need to reset the product.
2. Try using your other electrical outlet because your AVR or Surge Extension may not be providing enough voltage for the printer.
3. Try using dirty cycle, meaning you need to directly cut the power of your printer by pulling of the power cord from the rear side of your printer and wait for about 30 seconds before inserting again and turn it on.
If all these steps do not improve your printer functionality, you may want to call the HP online help and ask for replacement.
Job Espinosa
Feb 15, 2011 | HP Photosmart C5280 Printer
My hp Photosmart 3210xi all-in-one printer is giving me an error message. It says "scanner Failure Unable to scan or copy Press ok" I hit ok then copy and the same error comes up again and again and...
Since you replaced the Yellow cartridge, did it go thru the alignment process and printed the alignment sheet ?
If Yes, Disconnect the power cord from back of printer ( while printer is on ) and while holding the # and 6 key on front panel, connect the cord and follow the instructions on printer screen.
NOTE : if you have setup the printer on wireless network, the printer will loose network signals, you will have to re-setup the printer on network.
If No, Press setup button, Scroll to TOOLS, Choose Align Cartridges, and follow the process.
If the Printer does not let you thru SETUP button, follow the first step to do Semi-full Reset on printer
Jul 03, 2010 | HP PhotoSmart InkJet Printer
When attempting to scan document or copy a document on Photosmart all in one seriers I receive an error message "Scanner failure unable to scan or copy"
try to remove and re install driver, and look into device manager if scanner detected. if not restart you pc and when found new hardware popup browse driver manually.
Apr 10, 2010 | HP Photosmart 3310 Printer
Screeching while scanning
it may be want to lubricate the scanner rode
Mar 23, 2010 | HP Photosmart 3210xi InkJet Printer
Error msg says scanner failure.
ensure the printer was correctly enstalled, check all connections ensure a tight fit. if it is connected to a network make sure the network cable is plugged in and blinking green
Nov 03, 2009 | HP Photosmart C6100 All-In-One Printer
Message says "Scanner Failure" and "Unable to scan or copy"
Obviously its scanner error,the whole scanner assembly needs replacement.It could be the bulb or the scanner board, but upon replacing it needs both.
Sep 17, 2009 | HP Photosmart C5280 InkJet Printer
Scanner failure error code
You can try a reset on the printer using the # and the number 6,holding them down
while plugging in the power cord at the back of the printer.if it still does not work
then you can try the same with the # and the number 9.If it still does not work,get
your printer serviced.
Jan 06, 2009 | HP Photosmart C7280 Printer
Scanning and Copying problem.
This is a hardware problem. I would suggest that you would replace the printer.
Aug 11, 2008 | HP Photosmart C4150 All-In-One InkJet...
HP photosmart c7180 scanner failure
you can run a reset on the printer and clear the scanner failure yourself. You can find the instructions at: http://www.inkbank.com.au/webcontent21.htm
good luck...
L.C.
Apr 04, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
779 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
