Question about Black & Decker CHV7202 Handheld Wet/Dry Vacuum
CHV7202 When I vacuum with it, the dirt and dust sprays back in my face.
  • 134 Answers
Youve either mis fitted the cup or the seal around it is no good
Posted on Feb 19, 2009
Why is it not picking up dust and dirt from carpet. pipes clear. Can you help
How to Fix a Vacuum That Lost Suction - Quick and Dirty Tips
Oct 3, 2013 - It's true, a vacuum that doesn't have suction is not very useful ... The first and most basic reason a vacuum isn't picking things up off the floor is if the ...The lower your carpet, the closer the dial or lever should be to the bare floor setting. off and shaking the dust off put the power right back in my vacuum!
Common Vacuum Issues - and what you can do to solve them
Oct 4, 2013 - Your vacuum's job is to pick up dirt, dust and debris - so when it stopsdoing ... Often when your machine is not picking up it is due to loss of suction. If yourvacuum cleaner turns on but won't pick up on carpet or bare floors, ...
Is your vacuum cleaner not picking up dirt and debris ...
Jan 7, 2015 - But many times it does not pick up or suck the dust as effectively as it is supposed to do. ... If the vacuum cleaner fails to pick up dirt and debris and has no ... Deep clean your expensive carpets to restore their original look.
Jan 24, 2016 | Vacuums
Vacuum is spewing dust out of the front vent! We have the Dirt Devil 12 amp bagless upright. Hoses are clear, brushes turn, everything fine except dirt blows OUT instead of going into canister. How
Hi! We actually don't recommend opening the motor compartment. It sounds like there may be a clog somewhere in the vacuum that you are unaware of. Please try following the steps below.
  • Remove the hose from the vacuum from both ends and check it for clogs.
  • Lay your vacuum face down, remove the bottom guard and brush-roll
  • Use a wooden spoon or something similar to help break up and remove any clogs from the lower hose.
  • Check and clean all the filters on the vacuum. If they are really dirty they may need to be replaced.
Hope this helps, if not we can be reached here on Fixya, or Twitter @DirtDevil
Oct 06, 2014 | Dirt Devil Vacuums
Dust Tank overfilled
yes you can just make sure it's completely dry befor putting it together
Jul 12, 2013 | Dyson DC14 Animal Bagless Upright Cyclonic...
When I use it dust shoots out the top.
It's suppose to keep the dirt inside! Joking aside did you run it without the filter at one point? I've seen them where the motor compartment is full of dirt from one use without a filter. If it's shooting dust out the likely reason is dirt has made it past the filters to the motor compartment. Otherwise they generally dont shoot dirt outwards. If this doesn't help what brand of vacuum and model would give me an idea where to start.
Feb 05, 2013 | Vacuums
Power head is spraying out dust. No particles are going into the water
You can check the belt. If you rainbow belt is broken the power head will seem to spit dirt back out.
May 15, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Dust will blow out of the front vent of my Dirt Devil Featherlite Bagless Vacuum. It seems to be shooting out dust that I just vacuum up, but I can't be certain.
Dust blows out of the filter vent is usually caused by a plugged filter drop the filter door on the back, replace or for a temporary fix blow out the filter
Jan 17, 2011 | Dirt Devil Featherlite Bagless Vacuum...
I received a NEW dyson ball vacuum for Christmas. I have noticed when I vacuum with it that dirt collects all over the ball and the vacuum beater head. Is this normal. I have had the regular upright...
This may sound silly, but it sounds like that you a have static electricity problem. If the dust is collecting on top (outside of the brush head that is probably the static attracting it. This is common during the colder months. You know how during these months when you walk across carpet and then just someone or a metal objest, you get a shock.
You might try lightly spraying a little "static guard" on the top of the brush head before using it, or using a carpet dusting product that smells good, and may reduce the static.
Jan 01, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
Took apart my electrolux 6500 sr. How do I get my fan shroud off to clean the blades? Thank you.
Oops. Don't. First blow it out with another canister vacuum or air hose. That's usually sufficient for removing dirt and dust. For dust/dirt in the motor, use a motor cleaning spray that can be picked up at most auto parts stores. One that evaporates quickly and doesn't leave a sticky residue. One's called Electric Motor Contact Cleaner by Gunk ( There are others.
Hobby shops may also have one available called Dynamite Magnum Force 2 Motor Spray.
It shouldn't be that dirty unless someone has been using generic "made to fit" Electrolux bags. Or if water or other liquid has been vacuumed, resulting in rust, etc.
Keep in mind that reassembling the vacuum is more difficult than taking it apart. If not done so correctly, various problems may result. While you have it apart, it would probably be a good idea to use pipe cleaners to clean out the tubes connectiong the "control valve assembly" to other parts of the vacuum. Also, unscrew the knob at the top of the "cva" to check for wear and breaks. Clean dust thoroughly from all interior parts.
Oct 05, 2010 | Electrolux Epic 6500 Vacuum
When on the carpet setting, the dirt sensor stays on red all the time.
two possibilites can be thought of , either there is dirt on the system filter reducing the vacuum or the said vacuum level is low.
It will be good to remove and clean up the bag, the pump and reset . Use a good air jet spray but do it out of the house please, use a good face mask as there canbe fine dust within.
Sep 18, 2010 | Kenmore 25812 / 25813 Progressive Bagged...
What causes a vacuum to make lots of dust and throw back out what it vacuumed
It sounds like the airducts that lead to your dirt chamber are clogged. The dirt can't get through to the dirt cup so it spits it back out and blows dust everywhere.
Nov 27, 2009 | Eureka 5892AVZ Bagless Upright Cyclonic...
Black & Decker CHV7202 Handheld Wet/Dry Vacuum Logo
76 people viewed this question
Top Black & Decker Vacuums Experts
Greg Cann
Greg Cann
Are you a Black & Decker Vacuum Expert? Answer questions, earn points and help others
