Question about Hasbro Fur Real Friends Smores Pony
Butterscotch Fur Real Pony's Head is broken-Hangs down at neck
My older son accidentally ran into butterscotch and it fell over braking his neck. Who can I go to to have this repaired?
4 Suggested Answers
  • 8 Answers
SOURCE: Looking to repair the tail on Butterscotch pony
Had the same problem and the fix is easy. Hopefully, the tail snapped off at the base of the plastic plate on the tail. If so, go to a hardware store and buy 1 ft. of CLEAR plastic tubing with 3/16" inner diameter and 5/16" outer. Cut off a piece about 1 1/2". Now, look at the base of the tail and you should see a small screw that holds in what remains of the stub that broke. Unscrew the screw and remove what is left of the stub. KEEP THE SCREW. Now drill a small hole thru the plastic tube about 1/8" from the end. This will later be inserted into the tail and the screw will go through the holes. Next, take a hair dryer and heat the undrilled end of the tube to soften it and push it on to what is left of the broken stub inside the pony. It will be a tight fit which is what you want. You will probably need to twist the tube gently while applying firm pressure on it to make it slide over the stub. The end of the tube with the holes should be about even with the outside top of the white plastic hole and the tube holes should be level, looking at it from side to side. This makes the alignment of the screw hole to the tail correct. Now slide the tail over the end of the tube and insert the screw. I just did it today and it works good as new! If the tail is too far away from the body of the pony, carefully twist and remove the tube and shorten it. Since you bought a 1 ft. tube, you can have several trys to get it right if you cut it too short! Total cost for the tube was 21 cents. Good luck! Kip V. Tryon, NC
Posted on Jul 23, 2010
SOURCE: I need a battery compartment for butterscotch fur
good luck, me too and they stopped making parts :-(
Posted on Nov 08, 2011
jacksparr689
I found one of this on a garbage deposit. I opened the battery box and it was completly destroyed. A good technician could restore all the conections on this...not a big deal, but I'm not LOL, so I took out th two main cables (red and black) by take out the three screw placed where the battery box snaps in. The I conected a 9v battery directly on this two wires and voila! the pony is alive again
Posted on Apr 16, 2013
How do you take the head off
This video shows exactly what you need to do. Requires a little handyman skills.
Hasbro FurReal Friends Smores Butterscotch Pony Head Removal How To...
Jan 10, 2015 | Hasbro Fur Real Friends Smores Pony
Butterscotch pony head not working
First, calling poor Grace at Hasbro will provide fruitless. Hasbro does not make any parts for the full size FurReal Ponies, they have nothing in stock and cannot help you. I, however, can. I am going to post a link to a distressing site that turns the normal FurReal Pony into a fire breathing demon. However, in the process, you can see the diagram of the skeleton of the pony and head. You can search for other links but this is pretty comprehensive. Just don't open when kids are around.
Lisa
http://www.instructables.com/id/Make-a-Fire-Breathing-Animetronic-Pony-from-FurRea/
Dec 08, 2013 | Hasbro Furreal Friends Butterscotch Pony
How to get into and fix tail doesnt move anymore
Here is a link to instructions for removing the fur from the FurReal Friends Butterscotch Pony. Beyond that, I have no idea how to fix a broken tail. If you can find somebody who works on robotic/animatronic toys, or a good handyman, they can probably fix it for you.
http://www.instructables.com/id/Make-a-Fire-Breathing-Animetronic-Pony-from-FurRea/?ALLSTEPS
Dec 22, 2011 | Hasbro Fur Real Friends Smores Pony
Saddle, carrot and brush for butterscotch pony
Check oksanas*heirloom*treasures on eBay for replacement tack. You can get replacement carrot and adoption certificate on eBay from bet_em on eBay.
Nov 16, 2011 | Hasbro Fur Real Friends Smores Pony
I replaced the batteries in my daughters "Butterscotch" but she still does nothing. No sound or movement at all. HELP!
make sure the batteries are in the right way and contacts are clean , try new batteries from a fresh pack,make sure switch is on if it has one, then if that doesnt work, beat butterscotch on the floor a few times, may get him going (seriously)
Jul 30, 2009 | Hasbro Fur Real Friends Smores Pony
Furreal pony, Butterscotch, Head floppy/leans left
There is a smaller "u" shaped spring in the middle of the neck mechanism that I found one side was snapped off. Looks normal, but it's broken. I made one out of a coat hanger for temporary purposes and it works like new! I will order one from Hasbro. Hope this helps!
Dec 09, 2008 | Hasbro Fur Real Friends Smores Pony
Hasbro Fur Real Friends Smores Pony Logo
305 people viewed this question
Top Hasbro Toys Experts
thegtw
Antony
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
