Question about KitchenAid KAWS850LE Top Load Washer
I need to repair my washing machine Model KAWE577BWH1
How do you remove the cabinet? It looks the cabinet is one unit with three sides. Right side -Front-Left side
  • 10,865 Answers
To remove the cabinet safely, the washing machine should be turned off and unplugged. Next take out the control panel by removing the screws. Also take out the spring clips which are situated in the corners and after doing that remove the harness that is connected to the lid switch wiring. Pull the lid and also keep a hand on the cabinet opening that shows itself when you open the lid. Furthermore adjust the cabinets position and then pull the lid and the cabinet opening. It should be removed now.
Posted on Feb 18, 2009
How do I remove the back panel of Kenmore 90 series washer
You dont on this model u have to remove the whole cabinet. it pulls out as a whole unit. first remove the side plastic covers on the top panel. left and right side, then there will be 2 screws 1 on left 1 on right remove them, the panel should not pop up, under it u will see 2 gold color clips, near the middle u have to pry them up with a screwdriver or pc of metal. they pop right out with enough pressure. then you will be able to remove the whole cabinet pulling it up forward then out
Mar 28, 2015 | Kenmore Washing Machines
Hoover 201M 5.00Kg Heavy DutyTop load leaks slightly . I cant see any easy way of removing the outer case to look inside to find out where the leak may be. there are only a few screws holding the...
  • Unplug the washing machine from the wall outlet.
  • 2
    Remove the plastic end caps on the left and right sides of the control panel using your fingers, and then remove the screws under the end caps.
  • 3
    Lift the control panel up and rotate it 180 degrees.
  • 4
    Unplug the wire connector from the top of the cabinet and then use a flat-head screwdriver to release the spring clips on the left and right sides of the cabinet.
  • 5
    Tilt the cabinet toward you, then lift and remove. Set the cabinet aside.
  • New top load machines all have the cabinet where it comes off forward and the screws only hold the control panel on.
    Apr 04, 2011 | Washing Machines
    Need help raising top of washer.....so that contact going into hole to make washer operate can be repaired.
    Remove the left and right screws from the comtrol console base.
    Pull the control console forward and then rotate it to the rear of the machine.
    Use a flat blade screw driver to un-hook the S clips from the right and left sides of the cabinet.
    Unhook the lid switch wires.
    Pull the cabinet forward to remove it from the machine.
    Do your repair.
    Reverse the above order to re-assemble the machine.
    Jan 10, 2011 | Kenmore Washing Machines
    How to find the lid switch?
    lid switch is on right side of tub opening. if u need to change it unplug machine on each corner of console in rear u will fine a phillps head screw remove these pull forward and up on console. remove brass clips on each side of cabinet.remove three wire plug (this goes to lid switch.) tilt cabinet towards u and slid it toward u .
    Sep 19, 2009 | Roper RAS6233KQ Top Load Washer
    Leaking at front base of washer. Not a stream but a growing puddle as it goes through its cycles. Not sure where to look to find the cause. All water and drain connections are good.
    Remove the cabinet to access the water pump. It is attached to the motor front/center.
    It will be leaking.
    No repair, only replacement will stop the leak.
    Remove 2 screws on the right and left sides of the control console. The console is hinged. Fold it to the rear of the machine. Unplug the lid switch connector.
    Remove 2 clips holding the back panel to the cabinet base.
    Remove the cabinet. Motor and pump are at the bottom center.
    May 24, 2009 | Washing Machines
    Remoive the top/frgidaire ftfb4000fs1
    Under the top lip on the rear of the unit there are three screws securing the top to the cabinet. Remove them then stand in front of the unit grab both sides of the top and slide back. voila
    Dec 23, 2008 | Frigidaire ATF6000ES Front Load Washer
    Whirlpool duet washer model GHW9400PWO
    Removing the Washer Top
    Three screws secure the washer top at the back of the washer. Remove the three screws and lift the top from the washer.
    Removing the Console from the Cabinet
    Disconnect the Touch Pad/LED Assembly ribbon connector from the left side of the Central Control Unit and release it from the wiring harness brackets on the right side of the washer top
    Remove the detergent dispenser drawer by pressing down on the release tab at the back of the drawer and pulling it completely out of the washer.
    Once the drawer is removed, remove the screw in the recessed hole next to the drawer opening. Release the tab securing the right side of the console to the washer
    Open the washer door and place a flat-bladed screwdriver into the slot in the bottom center of the console. Push the console up to release center console tab. Be sure the ribbon cable clears the cabinet frame.
    Removing the Touch Pad/LED Assembly from the Console
    The Touch Pad/LED Assembly is removed as a single unit and contains the Push Buttons, LEDs, cable, etc. The buttons can be replaced separately
    Jun 28, 2008 | Whirlpool GHW9400 Duet Washer
    Taking off shell of washing machine
    Remove the shell:
    nplug the machine. Remove the end caps on both sides of the console by putting a flat screwdriver in the top of the end caps from the back and gently prying up. Remove the two Phillips screws holding the corners of the console down. Lift the console and gently fold back. Unplug the lid switch. That's the 3-wire quick disconnect below the timer. (If you have a high price model, you'll have three hoses under a plastic cover on the left. disconnect those hoses before going further.)
    Using a flat screwdriver remove the gold clips holding the cabinet to the back. Place the blade of the screwdriver in the indentation closest to you and tilt the handle of the screwdriver back.
    Open the lid. Lift and tilt the entire cabinet toward you. Look down through the hole to the front bottom edge of the cabinet. It is hooked under the front edge of the washer frame. Remove the cabinet and place it aside.
    Replacing the shell:
    Pick up the cabinet, hook it under the front of the frame, and tilt it back into place. Push the sides of the cabinet in as you are tilting it back to make sure the hooks in the frame (back, sides) line up with the cabinet. You can know it's in place when the edges of the cabinet line up evenly with the edges of the back.
    Re-install the gold clips. Hook them into the back panel, put them into the slots in the cabinet, and push down until they snap into place. Re-connect the lid switch. Lower the console. Replace the screws. Replace the end caps - bottom first, then snap them in at the top.
    Happy washing!
    Mar 11, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool
    If the motor makes no noise in the spin cycle only, it sounds like you need a lid switch.
    Unplug the machine. Remove the end caps on both sides of the console by putting a flat screwdriver in the top of the end caps from the back and gently prying up. Remove the two Phillips screws holding the corners of the console down. Lift the console and gently fold back. Unplug the lid switch. That's the 3-wire quick disconnect below the timer. (If you have a high price model, you'll have three hoses under a plastic cover on the left. disconnect those hoses before going further.)
    Open the lid. Lift and tilt the entire cabinet toward you. Look down through the hole to the front bottom edge of the cabinet. It is hooked under the front edge of the washer frame. Remove the cabinet and place it in a position you can work under it.
    The lid switch is held in lpace with two Phillips screws on the right edge of the hole. There is also a 5/16 in ***** holding the ground wire to the cabinet. Install the new switch using all the clips and screws that were holding the old switch in place.
    Happy washing!
    Kenmore Series 70 Washer Model 110
    That would be your lid switch that has went bad.  Remove the console caps, then remove the two screws that hold it down (sometimes these screws are in the rear of the console)  Rotate the console out towards you gently, then fold it up and over the top of the unit.  You see 2 gold colored hold down clamps on top, and either side of the unit.  You will also see a wire and disconnect going down through the cabinet on your right hand side.  Disconnect these wires (be sure unit is unplugged) and rotate the whole cabinet towards you.  You remove the two screws that hold the switch in place and a 5/16" screw underneith that holds the ground wire.  Unclip the connector from the rear top of the cabinet and remove the switch.  Be sure to bring your whole model number 110.************** when you get the new part, there are two of these, and they look the same except the wire ends are different.  Good luck    Jim
    Oct 16, 2007 | Washing Machines
    KitchenAid KAWS850LE Top Load Washer Logo
    472 people viewed this question
    Top KitchenAid Washing Machines Experts
    thinksewfast
    Paul Bade
    Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
