Maytag Dependable Clean Top MAV5920EWW Top Load Washer Logo
Posted on Feb 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washing machine water comming out from bottom
MAV 5920EWW washing machine water comming out from bottom
Anonymous
Level 2:
  • Expert 132 Answers
  • Posted on Mar 26, 2009
Anonymous
Expert
Level 2:
Answers
132
Questions
0
Helped
58632
Points
395
Check the hose that connects from the tub to the water pump. Next time you do a load remove the front panel and set the machine for a "small load" so there won't be alot of water. When the machine begins to agitate shut off the timer and move it to the final spin mode and turn it on. Here is where you want to watch that hose (maybe with a flashlight) as the tub begins to spin and the water is being pumped out, focus on where the hose connects to the drum. Usually as the spin increases the vibration will cause the hose connection to become loose and water will start spitting out. If you don't see any leaks in the hose, check the water pump itself. NOTE: DO NOT PUT YOUR HANDS IN THE MACHINE WHILE IT IS IN OPERATION! JUST LOOK IN AT THE HOSE, DO NOT TOUCH ANYTHING AND KEEP YOUR HAND BEHIND YOUR BACK! THE OTHER HAND ON A FLASHLIGHT FROM OUTSIDE THE MACHINE.
1helpful
How to control water levels in Maytag TOP LOAD WASHER, model #MAV 6000 AWW
What is the problem?
Water level is automatically controlled based on what you set it to low, med, or high.
Hi, I have a Maytag Alantis Washer (model: MAV
Does it not spin just in the final cycle or not at all during the wash cycle? Also, does the wash cycle agitate normal?
Regards,Richard
1helpful
1helpful
Maytag Atlantis MAV-14
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
2answers
Maytag MAV 9600 grinding noise/no agitation. Tub
sounds like a transmisson problem expensive to fix
Model mav6000awu has a sound of water rushing when machine finished filling and running.started doing this recently.
most maytag toploader mav did have that sound if it drain & spin your ok i have the same washer and it has the same sound & work fine that washer will only last about 10 years (i work for maytag )
Maytag alantis MAV 9600
hi thanks for the question re set the water level control to see if it will add more water if it doesn,t it could be a bad water valve check that thanks the appliancedoc
Maytag Mav-1 Slow Spin
hi thanks for the question with any washer if you use a hi sud zing detergent it really slows down the spin cycle check this just fill & drain 2or 3 times use some veniger try this thanks the appliance doc
My maytag atlantis mav6200 only spins on whites cycle
Try running the machine in another cycle the very next time you use it. I'm trying to determine if this is machine fault something else.
If you just used the machine wait for about 1/2 hour before starting it again.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
