Question about HP Officejet 9110 All-In-One InkJet Printer
Keeps aligning printheads and printing blank pages
  • Anonymous Mar 03, 2009
    We had the same problem. We installed all new printheads. We were told at Hp support it was because one or more of the printheads was expired. Hope this helps
I had changed printer head, after changed printer head, printer take a align printheads after each and every print
Posted on Sep 07, 2009
How to remove printhead
Alignment shows black & streaky, only covers 3/4's of a line, color is good. The printer copies a document no problem; but only copies color (no black) from the computer. If the document is black print, I get a blank page. Do not know how to remove printhead
Jun 29, 2013 | Dell V313w AllInOne InkJet Printer
Intermec PX4i printing blank labels
I found the following item on page 3 in the printhead installation manual:
"Note: If you are installing the 400 dpi printhead on the PX4i
printer (Kit P/N 850-812-900 IPL Only), you must first
update the IPL firmware to version 2.74 or later."
I assume this is a partial exception to the general caution on page 1 of the same publication:
"When installing a printhead, make sure that the printhead
density and alignment is the same as in the one you replace
and that the printhead is designed for the type of printer in
which you are going to install it."
Also, the printer should not be powered when the printhead is being installed. The printer does not identify the printhead until it goes through a power-on startup.
Feb 27, 2012 | Intermec PX4I Label Printer
HP C4180 keeps telling me cartidge alignment failed,why is this
hpweb_1-2_plus.gifhpweb_1-2_minus.gifMethod one: Align the printer with Solution Center
  1. Load unused white paper (if needed).
  2. In HP Solution Center , click Settings , and then click Printer Toolbox .
  3. Select the Services tab, and then click Align Printheads . Figure 10: Align Printheadsc01950052.jpg The Align Printheads window opens.
  4. Click Align . The printer prints the alignment page.
hpweb_1-2_plus.gifhpweb_1-2_minus.gifMethod two: Align the printer from the control panel
Oct 26, 2010 | HP Photosmart C4180 All-In-One InkJet...
On my Test Pattern 2 the blue/light blue and green/yeallow have steeks in it. The documents that I print have streaks going across the page. I've cleaned everythign I can clean. The printer has 6,251...
SolutionFollow the given steps in the order presented to resolve the issue: Step one: Retry the print jobThe problem may occur only rarely. If you have not seen it in other printouts, try again. Step two: Increase the print quality modeIf reprinting did not help, try increasing the print quality mode.
  1. In the application you are printing from, click File , and then click Print .
  2. Make sure the printer is selected, and then click Properties .
  3. Select the Paper/Quality tab.
  4. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
Step three: Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE: This step does not apply to color printouts.
  2. Make sure the printer is selected and click Properties .
  3. Click the Color tab, and select Print Grayscale and High Quality .
Step four: Clean the printheadsIf the print quality is still bad, clean the printheads.
  1. Make sure the printer is loaded with unused white paper.
  2. Open HP Solution Center .
  3. Click Settings , Print Settings , and then select Printer Toolbox .
  4. Click the Service Tab .
  5. Click Clean Printhead , and then click Clean .
Step five: Align the printheads If the print quality is still bad, align the printheads.
  2. Open the printer Toolbox , and select the Printer Services tab.
  3. Click Align Printheads . The Align Printheads window opens. Click Align .
  4. The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK when the page finishes printing.
Step six: Calibrate the linefeed If the print quality is still bad, calibrate the linefeed:
  2. Open the printer Toolbox and select the Printer Services tab.
  3. Click Calibrate Advanced Linefeed . The Advanced Linefeed Calibration window opens. Click OK .
Step seven: Replace one or both printheads If the print quality is still bad after performing all the above steps, one or both of the printheads will have to be replaced. Print a PQ Diagnostic page to see which printhead should be replaced.
  2. Press the Setup button.
  3. Press 1 and * simultaneously.
  4. Look at the color blocks labeled Test Pattern 2. Some or all of them could show white horizontal streaks. If none of the blocks are streaked, the printheads are okay.
    • If the Black block has lines – replace the KY printhead.
    • If the Cyan block has lines – replace the MC printhead.
    • If the Magenta block has lines – replace the MC printhead.
    • If the Red block has lines – replace the KY printhead.
    • If the Green block has lines – replace the KY printhead.
Dec 21, 2009 | HP OfficeJet Pro L7580 InkJet Printer
Blank pages from Canon MX850 scanner
Try Removing the printhead of your printer and putit back, and do the clean nozzles and printhead alignment.
Oct 02, 2009 | Canon PIXMA MX850 Multifunction Printer
I have a Kodak ESP 7 that will not print. At first it printed fine but then it started skipping lines and then it completely quick. So rigbt now I;m at the point it doesn't print at all. When it begins to...
Us the printer stand-alone. Go to Maintenance do Printhead cleaning, Nozzle Alignment and Calibration. After that try printing a Test page.
IMPORTANT: You must have firmware version 6.011998 or greater on your printer. To upgrade firmware go to www.kodak.com/go/downloads.
TEST PAGE
Press the Menu and OK keys simultaneously.
The demo image will print.
- If the page still blank contact 1-800-421-6699 they can send you a printhead replacement.
Sep 11, 2009 | Kodak Office Equipment & Supplies
I have a X7170 it has recently began printing with vertical blank areas on the printed copy. In other words up and down on the page there missing copy. I have changed ink cartridges and this does not help....
Uneven vertical lines can be adjusted by
performing the printhead alignment adjustments.
The user is directed through the Lexmark Solution
Center to perform the printhead alignment
adjustments when replacing a printhead cartridge.
The alignment can also be performed from the
control panel by selecting the Maintenance Option,
then Align Cartridges.
Feb 01, 2009 | Lexmark X7170 All-In-One InkJet Printer
Streaks though the pages
Step one: Retry the print job The problem may occur only rarely. If you have not seen it in other printouts, try again. Step two: Increase the print quality mode If reprinting did not help, try increasing the print quality mode.
Step three: Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing. NOTE: This step does not apply to color printouts.
Step four: Clean the printheads If the print quality is still bad, clean the printheads.
Nov 25, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Adjusting printheads - won't stop and keeps printing blank pages
Hi Did you have any print jobs sent to the printer before replacing the printhead. It seems that the printer is trying to print a job and since the usb cable has been disconnected and reconnected the printer is printing blank pages or misc text.
Dec 03, 2007 | HP Officejet 9110 All-In-One InkJet...
HP Officejet 9110 All-In-One InkJet Printer Logo
474 people viewed this question
Seeker5211
Seeker5211
